EZTRAK won't cut circles
I'm using MasterCam X3 to program a Bridgeport EZTRAK. All works well except it will not cut circles. The program looks good, has G3 code but the EZTRAK will not perform the G3 command. Is there something I can change in the post processor to get the solved? Thanks
Is this a 2 Axis or 3 Axis EZ-Track? I made post for our EZ-Track long time ago. I will look it up tomorrow morning when I go back to work.
Ara,
'Eztrac- MMM'
'DATE=DD-MM-YY - 17-09-13 TIME=HH:MM - 07:11k Program Name '
'MCX FILE - T'
'NC FILE - A:\MMM.TXT'
'MATERIAL - ALUMINUM INCH - 2024'
N100 G0 G70 G90
' 1/8 FLAT ENDMILL TOOL - 1 DIA. - .125 '
' ORIGINAL IMPORT FILE NAME = C:\MCAMX\CNC_MACHINES\BRIDGEPORT EZTRAK_GCODE 3X '
' MILL.MMD '
N110 T1 M6
N120 G0 G90 G54 X.3125 Y0.
N130 Z.25
N140 Z.1
N150 G1 Z-.07 F30.
N160 G3 I-.3125 J0.
N170 G1 Z.1
N180 G0 Z.25
N190 G90
N200 M02
This is the program of a simple circle. G codes look good but EZTRAK will not perform the circle. Alll else works fine, just no circle.
I have both, a 3 and 2 axis and both will not perform the MasterCam programmed circle.
Here is the code I get and it works fine in our machines.
:0010.'EZ-TRAK'
N100 G0 G70 G90
' 1/4 FLAT ENDMILL TOOL - 1 DIA. - .25 '
N110 T1 M6
N120 G0 G90 X-.5376 Y.05
N130 Z2.
N140 Z.2
N150 G1 Z-.5 F10.
N160 X-.5876 F20.
N170 G3 X-.6376 Y0. I-.5876 J0.
N180 X0. Y-.6376 I0. J0.
N190 X.6376 Y0. I0. J0.
N200 X0. Y.6376 I0. J0.
N210 X-.6376 Y0. I0. J0.
N220 X-.5876 Y-.05 I-.5876 J0.
N230 G1 X-.5376
N240 G0 Z2.
N250 G90
N260 M02
