haas #[2400+
how to get post to output #[2400+tool num.=0 for every tool after tool list or no matter when..needed to automatically zero tools diameter in offset table.see example of what i need
(-----------TOOLS-----------)
(N11 T23-HM50-------------)
(N13 T9-RISUK 10----------)
(N14 T10-FINISH 10--------)
(N15 T6-DRILL 5------------)
(N16 T15-FAZA 90° D6----)
(N17 T22-BALL 1.5X6------)
(-------- MIN Z..-17.---------)
(TOTAL TIME:00:02:24----)
#[2400+23]=0
#[2400+9]=0
#[2400+10]=0
#[2400+6]=0
#[2400+15]=0
#[2400+22]=0
What am I doing wrong?
And now where I need to write buffer (ptooloff)
after tooltable ?
toolffsets
string2 = "#[ 2400 + ", tldia$,"] = 0", e$
string2 = wbuf (2, wc2)
ptooloff
pbld, "(==== OFFSET ====)", e$
size2 = rbuf (2, 0)
rc2 = 1
while rc2 <= size2,
string2 = rbuf (2, rc2)
pbld, *string2, e$
fbuf 2 0 80 0 1 #Buffer 1
In buffer def, change 80 to 255 (for strings in new posts)
toolffsets
It's OK, but a postblock have to be started with "p" so: ptoolffsets
When you pass a value to a string, you don't need to EOB char, so remove ", e$"
Well, change the whole line because of "+":) (you have to add strings together)
string2 = "#[ 2400 + " + tldia$ + "] = 0"
And make sure that your buffer is filled up!
I would make some similar stuff:
pwrtt$		  #Pre-read NCI file
  if tool_info > 1 & t$ > 0 & gcode$ <> 1003,
     ptooltable
     ptoolffsets
I made a mistake here... I guess your tldia$ value is not formatted (fmt....) so its a numeric value and you have to convert it to string
So: string2 = "#[ 2400 + " + no2str(tldia$) + "] = 0"
I only see it :help:
(==== TOOL LIST ====)
(T271 = 75 FACE MILL)
(==== OFFSET ====)
(T219 = 10. FLAT ENDMILL)
(==== OFFSET ====)
(T213 = 4. FLAT ENDMILL)
(==== OFFSET ====)
and i write
ptooltable
ptooloff <---------------
Yes it works great ! :thumbsup:
I am interested why 255 and not 80?
And I'm interested in how he writes and reads as buffer
Glad to help and hear it! ;) (Now you can dona.... :D :D :D)
255, because MP language and (MP.dll) has changed, the portfolio what I linked, that's a little bit old.
But except this, very informative and clear.
Now a string buffer can store 255 characters. (may work with 80, but...)
How do you mean how read/writes the buffer?
In this example we know that we need to write a line into our buffer @ every toolchange and at pre-read NCI file.
Pre-read, because we would output data's in the beginnig of NC code.
That's why I put the write postblock call into pwrtt$ postblock.
Peter, this has been one of my biggest issues for some time. Still fighting certain posts and tool tables have to just see what is going to break free. Once I can wrap my brain around the buffers then I might finally get it all done. Buffers are still puzzling to me even after seeing all your examples and reading all of your provided information I still do not get the calling and the using and then the output to be correct, I keep seeing decrease in my output in the tool table. I think it is coming from the rc1 = wc1 - one line in the post and since the buffer automatically adds 1 to items I think the addition and subtraction are throwing things in a tail spin.
Right here is what I am talking about:
[size=4]plast_recd	 #Update the last record(s) for min-max and point[/size]
 rc1 = wc1 - one [b] <---- Once used[/b]
 c1_gcode = rbuf (one, rc1)
 if prv_opcode$ <> 104,
	c1_x_min = x_min$
	c1_x_max = x_max$
 rc1 = wc1 - one			 #rc1 is used to write also [b]<--- Then Again why??????????????[/b]
[size=4]	 c1_gcode = wbuf (one, rc1)[/size]
The reason I question this is because of the use of rc1 in the pwrtt$ section of the post.
pwrtt$		 #Buffer toolchange information, tooltable = 3 calls on 1003
 if gcode$ = 1001, psetup
 pcut_cctyp
 if opcode$=104 | opcode$=105 | opcode$=three | opcode$=16, cc_pos$ = zero
 if gcode$ <> 1001, plast_recd
 pcur_recd
 if gcode$ <> 1003, cc_pos$ = zero
 !opcode$, !tool_op$
 if gcode$ = 1003,
 size1 = rbuf (one, zero)
 rc1 = one
 if rc1 < size1, preadcur_nxt
 if cc_1013$ = zero, cc_pos$ = zero
When I post I get this kind of output in my tool table:
(T0101 - N1 - OD 55 ROUGH		 - OFFSET - 1 - INSERT - DNMG-432 - HOLDER - MDJNL-164C)
(T0909 - N9 - OD 55 FINISH		 - OFFSET - 9 - INSERT - DNMG-431 - HOLDER - MDJNL-164C)
(T1010 - N10 - CENTER DRILL- .25 DIA. - OFFSET - 10 - INSERT - NONE - HOLDER - NONE)
(T0404 - N4 - 1/4 SPOTDRILL	 - DIA. - .25")
(T0505 - N5 - 1/8 FLAT EM		 - OFFSET - 5 - DIA. - .125")
(T0486 - N5 - 1/8 FLAT EM		 - OFFSET - 14 - DIA. - .125")
(T0485 - N5 - 1/8 FLAT EM		 - OFFSET - 15 - DIA. - .125")
(T0484 - N5 - 1/8 FLAT EM		 - OFFSET - 16 - DIA. - .125")
(T0475 - N5 - 1/8 FLAT EM		 - OFFSET - 25 - DIA. - .125")
(T1212 - N12 - 3/32 FLAT ENDMILL - OFFSET - 12 - DIA. - .09375")
(T0600 - N6 - M4-0.7 STI TAP RH - DIA. - .191")
(T0808 - N8 - 1/4 CHAMFER MILL	 - OFFSET - 8 - DIA. - .25")
(T0099 - N1 - OD 55 ROUGH		 - OFFSET - 1 - INSERT - DNMG-432 - HOLDER - MDJNL-164C)
(T0891 - N9 - OD 55 FINISH		 - OFFSET - 9 - INSERT - DNMG-431 - HOLDER - MDJNL-164C)
(T1100 - N11 - 1/4 FLAT ENDMILL - DIA. - .25")
(T1089 - N11 - 1/4 FLAT ENDMILL - OFFSET - 11 - DIA. - .25")
(T0202 - N2 - 1/4 CHAMFERMILL	 - OFFSET - 2 - DIA. - .0001")
I cannot get my FANUC Tool Number to come out correct. I can get the N Number process to come out correct. I can get the Offset number to come out correct and I can post out correctly at each operation, but in the tooltable I keep getting math error of subtracting the tool number and the offset number from the record to give me bad output.
Hi Crazy! :)
(Ron, am I right? :blushing: )
I just took a quick look into your snippets.
If you got the right N number in tooltable, you can go on a "rough" way, just simply make equal N and T at output.
But yes, you're right, it's not the real answer.
If you can share the write/read postblock here, it might be get us closer what/when cause this issue. Until this, I'll be the
second who confused about this "rc1 = wc1 - one" stuff :) Honestly ;)
For debugging (and understanding too) I can give you a good advice. (May be you know it, but I have to write here) ;)
If you switch on the keep flag in buffer definitinon (set second number to 1) then you got a file which represents the actual
buffer file.
See second 1 in definiton of Buffer-1 (with 12 number)
fbuf 1 1 12 0 0
At the same time (and in the next line for example) set filename and path for buff-1:
sbufname1$ = "D:\MyBufferFileForDeBuggggy.txt"
After first postprocess you have this file and you can keep open in your editor and it gives you a kind of visual feedback
from current buffer. It helps a lot, believe me ;)
Yes, you're right, at every read/write event, the counters are incremented by one. You always have to keep in mind that.
I see your tooltable. Do you want to output a line at every Operation in order? Or what is what you would like to see there?
May be I have some idea and easier to help then. ;)
Ron/Peter,
When using buffer files, the read/write counter variables get incremented automatically when a buffer record is written or read. This can be really confusing, especially when trying to add your own increment/decrement scheme to the post logic. (I believe you mentioned throwing things in a tail spin?)
To stop that behavior, you can set 'buf_no_index$' to '1' or 'yes$' in the top of your post. This stops MP from automatically incrementing your counter variables, and lets you control the process yourself.
Hope that helps,
Colin
Peter, here is more to look at.
 pcut_cctyp
 pcur_recd
 !opcode$, !tool_op$
 if gcode$ = 1003,
 rc1 = one
 #if you want repetitive tool output, keep the abs( ) in ptooltable and remove the >= t$ from the pwrtt call to this block
 #if (tool_info = 2 | tool_info = 3) & gcode$ <> 1003 & op_id$ <> last_op_id & last_tloffno <> tloffno$ & t$ >= 0, ptooltable
 if (tool_info = 2 | tool_info = 3) & gcode$ <> 1003 & op_id$ <> last_op_id & last_tloffno <> tloffno$, ptooltable #This allows us to see the same tool with different offset
 last_tloffno = tloffno$ #This controls the different offset tracking not to duplicate it when they are used in the operations
 last_op_id = op_id$
 last_t = t$ #Trying to save the tool to keep subtraction from happening in the tool list when the same tool is called
ptooltable # Write tool table, scans entire file, null tools are negative
	 toolno = t$ * 100 + tloffno$
	 tnote = abs(toolno) #use to be this abs(t$), but we want it to look different so we changed
	 tldianote = abs(tldia$) #Oct-20-08 AEH
	 [if spindle_no$ = 0, ntooltrack = t$],[if spindle_no$ = 1, ntooltrack = t$ + 1000]
	 ntooltrack = abs(ntooltrack) #See it used else where Figure why not
	 if opcode$ = 3 | opcode$ = 16, toffnote = tlngno$
	 else, toffnote = tloffno$
	 stinsert2 = ucase(stinsert2)
	 !spaces$
	 spaces$ = zero
	 if posttype$ = 2, #lathe tools
		 scomm_str, *tnote, " - ", *ntooltrack, " - ", plistcomm, " - ", *toffnote, pdspace, " - ", *stinsert, *stinsert2, " - ", *stholder, *stholder2, scomm_end, e$
		 #scomm_str, *tnote, ptspace, " - ", *toffnote, pdspace, " - ", *stinsert, *stinsert2, " - ", *stholder, *stholder2, scomm_end, e$
	 else,				 #mill tools
		 if tcr$ = 0, scomm_str, *tnote, " - ", *ntooltrack, " - ", plistcomm, " - ", *tldianote, punit, pdiamspc, scomm_end, e$
		 else,
		 if tcr$ > 0, scomm_str, *tnote, " - ", *ntooltrack, " - ", plistcomm, " - ", *toffnote, pdspace, " - ", *tldianote, punit, pdiamspc, " - ", *tcr$, punit, scomm_end, e$
		 if tcr$ = 0, scomm_str, *tnote, " - ", *ntooltrack, " - ", plistcomm, " - ", *toffnote, pdspace, " - ", *tldianote, punit, pdiamspc, scomm_end, e$
	 spaces$ = prv_spaces$
I got all my tool change calls worked out perfectly which is really bugging me since it has to be the buffer freaking out and doing it through add-subtract process that goes against any logical process since everything else is using the same stuff, but outside of the buffer calls.
ptoolcomment    #Comment for tool
     if tool_info = 1 | tool_info = 3,
       tnotelist = abs(t$)
       toffnote = tloffno$
       strtool$ = ucase(strtool$)
       !spaces$
       spaces$ = zero
       scomm_str, *tnotelist, " ", *toffnote, scomm_end, e$
       if posttype$ = two, # Lathe toolpath operation
         if tool_op$ = 64, # Drill operation
         scomm_str, *strtool$, scomm_end, e$
         else,
         scomm_str, *strtool$, " ", *stinsert, *stinsert2, scomm_end, e$
       else, # Mill toolpath operation
ltlchg$          #Toolchange, lathe
     toolchng = one
     gcode$ = zero
     copy_x = vequ(x$)
     pcc_capture   #Capture LCC ends, stop output RLCC
     c_rcc_setup$   #Save original in sav_xa and shift copy_x for LCC comp.
     pcom_moveb    #Get machine position, set inc. from c1_xh
     c_mmlt$        #Position multi-tool sub, sets inc. current if G54...
     *ntooltrack, ptoolcomment
     comment$
     if mr1$ > 0, pbld, n$, *mr1$, e$ #WAIT CODE CALLED FROM MISC REALS
     pbld, n$, "G0G18G40G80G97G99", e$
     pbld, n$, "G0G28U0", e$
     if lturret$ = 1, pbld, n$, *sg28ref, "V0", e$ #Had to add Upper Turret Support for Y axis Home Call
     #if tool_op$ <> 65, pbld, n$, "G0G18G40G80G97G99", e$
     #if tool_op$ <> 65, pbld, n$, "G0G28U0", e$
     #if lturret$ = 1 | tool_op$ <> 65, pbld, n$, *sg28ref, "V0", e$ #Had to add Upper Turret Support for Y axis Home Call
     if mr3$ < 0 ,
         [if spindle_no$ = 0, pbld, n$, *sg53,*mr3$],[if spindle_no$ = 1, pbld, n$, *sg53,*mr3$], e$ #Clearance is different on main and sub spindle
     else,
         [if spindle_no$ = 0, pbld, n$, *sg53,"Z-8.5"],[if spindle_no$ = 1, pbld, n$, *sg53,"Z-7."], e$ #Clearance is different on main and sub spindle
     if not(synch_flg & tool_op$ = 67),     #Suppress tool output if cutoff during part xfer
       if omitseq$ = 1 & tseqno > 0,
         pbld, [if home_type = -1, *sgcode], *toolno, e$
       else, pbld, n$, [if home_type = -1, *sgcode], *toolno, e$
     if home_type < two, #Toolchange G50/home/reference position
       sav_xh = vequ(copy_x)
       sav_absinc = absinc$
       absinc$ = zero
       start_xh = vequ(xh$)
       pmap_home   #Get home position, xabs
       ps_inc_calc #Set start position, not incremental
       #Toolchange home position
       if home_type = one,
         pbld, n$, *sgcode, pwcs, pfxout, pfyout, pfzout, e$
       else,
         #Toolchange g50 position
         pbld, n$, *sg28ref, "U0.", e$
         if home_type = zero, pbld, n$, *sg50, pfxout, pfyout, pfzout, e$
       pe_inc_calc #Update previous
       absinc$ = sav_absinc
       copy_x = vequ(sav_xh)
     else,
       pbld, n$, *pwcs, e$
     ipr_actv$ = c1_ipr_actv
     pbld, n$, pfsgplane, pfsgfeed, e$
     pcaxis_off_l  #Postblock for lathe transition
     pcom_moveb    #Reset machine position, set inc. from last position
     pcan
     pspindle
     #Added for 'css_start_rpm' logic (09/05/01)
     if css_actv$,
       if css_start_rpm,
         prpm # Direct RPM startup for programmed CSS
       else,
         pcssg50, pcss # NO RPM start - just output the CSS
     else, # Direct RPM was programmed
       prpm # Output programmed RPM
     if home_type > one, absinc$ = zero
     pcan1, pbld, n$, *sgcode, pfxout, pyout, pfzout, pscool, strcantext, e$
     if lcc_cc_pos, plcc_cc_pos  #Use sav_xa to position with comp. LCC
     pcom_movea    #Update previous, pcan2
     ps_inc_calc   #Reset current
     if css_start_rpm,
       pcssg50, pcss # CSS output AFTER a G97S???? RPM spindle startup
     c_msng$        #Position single-tool sub, sets inc. current if G54...
     toolchng = zero
     plast
     sav_cc_st_seq = n$   #saved sequence number for canned cycles
mtlchg$          #Toolchange, mill
     toolchng = one
     gcode$ = zero
     copy_x = vequ(x$)
     comment$
     if mr3$ < 0,
     else,
     if opcode$ = 3 | opcode$ = 16, toolno = t$ * 100 + tlngno$
     else, toolno = t$ * 100 + tloffno$
       if tseqno = 2, n$ = t$
       absinc$ = zero
       if home_type = one,
       else,
         #Toolchange g50 position/reference
     else,
       pbld, n$, *pwcs, e$
     pcaxis_on_m   #Postblock for mill transition
     pbld, n$, "G28H0", e$
     pcan
     pbld, n$, pclampoff, e$        # Unclamp
     if millcc,
       cabs = 0
       pbld, n$, *sgcode, pfcout, [if y_axis_mch, "Y0."], e$
     else,
       prv_gcode$ = c9k                  #change modality for forced output
       pbld, n$, `sgcode, pfcout, e$     #` used in case indexing mode
     pindex
     pbld, n$, pclampbrake, e$  # Clamp
     pcan1, pbld, n$, *sgcode, pfxout, pfyout, pfzout, strcantext, pspindle, prpm, e$
     pbld, n$, pscool, e$
     #pspindle
     #prpm
     toolchng = zero
     if millcc, pmillccb #Set mill conversion
     plast
ltlchg0$         #Call from NCI null tool change, lathe
     toolchng0 = one
     copy_x = vequ(x$)
     pcom_moveb    #Get machine position, set inc. from last position
     comment$
     pcan
     if tloffno$ <> last_tloffno, #added for these machines. If Force Tool change is used you get code machine will not run and sit.
         if lturret$ = 1, pbld, n$, *sg00, *sg28, "U0", e$ #Lower Turret Does not need to go home to call different tooloffsets.
     if home_type = -1,
       prv_gcode$ = c9k
       pbld, n$, `sgcode, toolno, e$
     else, pbld, n$, toolno, e$
     pbld, n$, psgplane, e$
     pspindle
     pnullspindle
     pbld, n$, pscool,e$
     force_flg = 0
     if not(g54g55) & home_type > one & workofs$ <> prv_workofs$, force_flg = 1
     if spindle_no$ <> last_spindle_no, force_flg = 1
     if tloffno$ <> last_tloffno, force_flg = 1 #We need to recall the X and Z axis Values when we move away from the last position
     if force_flg,
       absinc$ = zero
       pbld, n$, pwcs, e$
       pbld, n$, psgcode, pfxout, pfyout, pfzout, e$
       ps_inc_calc #Set current inc.
     #Output cutter comp before each finish pass of           # 1/17/03
     #finishing groove canned cyle                            # 1/17/03
     if gcode$ = one, plinout                                 # 1/17/03
     else,                                                    # 1/17/03
       [                                                      # 1/17/03
       if lathecc = 3, pbld, n$, sccomp, e$                   # 1/17/03
       if tool_op$ = 201, !cc_pos$                            # 5/28/04
       prapidout                                              # 1/17/03
       ]                                                      # 1/17/03
     pcom_movea
     c_msng$ #Single tool subprogram call
     toolchng0 = zero
     plast
mtlchg0$         #Call from NCI null tool change, mill
     toolchng0 = one
     if last_millcc & op_id$ <> last_op_id & (not(millcc) | cuttype <> last_cuttype), pmillcca #End mill conversion
     copy_x = vequ(x$)
     comment$
     pcan
     if home_type = -1,
     #pcaxis_on_m   #Postblock for mill transition
     pspindle
     pnullspindle
     pbld, n$, pscool,e$
     force_flg = 0
     if force_flg,
       absinc$ = zero
       pbld, n$, pwcs,e$
       pbld, n$, pclampoff, e$  # Clamp Off
       if millcc & not(last_millcc), pbld, n$, *sgcode, "C0.", [if y_axis_mch, "Y0."], e$
       else,
       pindex
     else,
       if op_id$ <> last_op_id & millcc & not(last_millcc),
         cabs = 0
     pbld, n$, pclampbrake0, e$
     pindex
     ppos_cax_lin  #Position C axis, toolplane or CL
     if millcc,
       pcom_moveb
     else, prapidout
     toolchng0 = zero
     plast
plast       #Keep track of previous values
     last_millcc = millcc
     last_op_id =  op_id$
     last_cuttype  = cuttype
     last_spindle_no = spindle_no$
     last_mi4 = mi4$
     last_t = t$
     last_tloffno = tloffno$ #added for sending turret home when changing tooloffset numbers
My format statement for my defined variables and or added variables.
fmt "N" 24 ntooltrack #Sequence Number Process for N Tracking back to Tool Number on Fanuc Lathe
fmt "TOOL - " 4 tnotelist # Note format #Changed to support new tooltable process
fmt "T" 7 tnote # Changed to support TXXXX for Lathe output for Fanuc Machines
Great insight and if I ever get buffers figured out then I will finally think I get MP posts. By then they they will no longer exist, but atleast I will say I finally understood the process. That dump file is great that will be helpful.
Colin that will be okay, but then it will throw everything else into a tailspin and all the logic that is written for that would then have to be rewritten. If Lathe Posts had FANUC tool methods supported differently then all of this would not be needed, :turned:
Thing is if I only used one offset per tool then everything is golden it is the use of different offsets for the same tool is when everything starts going crazy. 5 different +/-.0002 diameters needing to be held with one tool so the T0505, T0514, T0515, T0516 and T0525 goes crazy and the calling of the same tool after the use of a live center from the lower turret to then rough and finish the OD also freaks it out.
