tooltable output current tool cut max/min depth error
Lee1
The first tool value is -9999/9999.the other tool value is ok.
see below red color is error value
(T4 - 3.00 90 DEG FACEMILL - H4 - D4 - D3.0000"Z99999.Z-99999.)
(T5 - 1.000 ROUGH EM W/.03 - H5 - D5 - D1.0000" - R0.0300"Z3.6018Z4.5)
(T6 - 1.000 E/MILL 2-3FL. .03 - H6 - D6 - D1.0000" - R0.0300"Z-1.8Z4.5)
(T1 - D2.0 90° FACEMILL - H1 - D1 - D2.0000" - R0.0300"Z2.1978Z4.5)
(T9 - .750 FINISH EM W/.03 - H9 - D9 - D0.7500" - R0.0300"Z2.0478Z4.5)
(T8 - .50 FINISH EM W/.03 - H8 - D8 - D0.5000" - R0.0300"Z1.5Z4.5)
(T7 - .50 FINISH EM W/.03 - H7 - D7 - D0.5000" - R0.0300"Z-1.0913Z1.2585)
(T11 - 0.5 CARBIDE ENDMILL W./R.019 - H11 - D11 - D0.5000" - R0.1900"Z.4756Z4.5)
(T10 - 3/8" NC SPOT DRILL 3.0" OOH 7.6" MIN GAGE - H10 - D10 - D0.3750"Z-1.51Z4.5)
(T12 - 0.18 DRILL - H12 - D12 - D0.1800"Z-1.68Z4.5)
(T16 - 0.188 PRE-BORING - H16 - D16 - D0.1880"Z-1.828Z4.5)
(T17 - 0.196 REAMER - H17 - D17 - D0.1960"Z-1.658Z4.5)
(T13 - 7/16 DRILL - H13 - D13 - D0.4375"Z-.2493Z4.5)
(T14 - .615 PRE-BORING - H14 - D14 - D0.6150"Z-.03Z4.5)
(T15 - 0.625 REAMER - H15 - D15 - D0.6250"Z-.03Z4.5)
below is code
ptooltable # Write tool table, scans entire file, null tools are negative
tnote = t$
toffnote = tloffno$
tlngnote = tlngno$
spaces$=0
if t$ >= zero,
preadbuf1
if tcr$>0, scomm_str, *t$, ptspace, " - ", plistcomm, " - ", *tlngno$, phspace, " - ", *tloffno$, pdspace, " - ", *tldia$, punit, pdiamspc, " - ", *tcr$, punit, min_depth, max_depth, scomm_end, e$
if tcr$=0, scomm_str, *t$, ptspace, " - ", plistcomm, " - ", *tlngno$, phspace, " - ", *tloffno$, pdspace, " - ", *tldia$, punit, pdiamspc, min_depth, max_depth, scomm_end, e$
pwritbuf1 # Write Buffer 1
b1_gcode = gcode$
if gcode$ = 1000 & op_id$ <> prv_op_id$ & list_type = 0, b1_gcode = 1002
#if gcode = 1002 & op_id = prv_op_id, b1_gcode = 1000 #V9.12
if gcode$ = 1002 & abs(t$) = prv_t$ & list_type = 1, b1_gcode = 1000
prv_t$ = abs(t$)
!op_id$
last_op_id = op_id$
b1_xmin = x_min$
b1_xmax = x_max$
b1_ymin = y_min$
b1_ymax = y_max$
b1_zmin = z_min$
b1_zmax = z_max$
b1_gcode = wbuf(1, wc1)
preadbuf1 # Read Buffer 1
size1 = rbuf(1,0)
b1_gcode = 1000
min_depth = 99999
max_depth = -99999
while rc1 <= size1 & b1_gcode = 1000, preadbuf1_1
preadbuf1_1 # Read Buffer 1
if rc1 <= size1, b1_gcode = rbuf(1,rc1)
if b1_zmin < min_depth, min_depth = b1_zmin
if b1_zmax > max_depth, max_depth = b1_zmax
It is where the buffer is being called. Need to make sure you make the call before any code is processed. That writes it and since the tooltable is at the start it really only meant to process tools and not all the code the process has to be redo to process the whole operation then store it to then call it. That is the thing about buffers I never get.
thanks you reply.
how can i do my want result?
