Manual Entry location Help
I would like to have a manual entry show up after the tool change, I tried of hand editing my programs here's an example of what I want.
Thanks for any help.
N5(5/16-18 TAP DIA. OFF. - 9)
M00 <------- THIS LINE
(LUBE TAP) <----- AND THIS LINE
G0 G17 G40 G49 G80 G90
T9 M6
M00 <------- WOULD LIKE HERE
(LUBE TAP) <----- WOULD LIKE HERE
G0 G90 G54 X.8465 Y0. S270 M3
G43 H9 Z1. T13
M8
G98 G84 Z-.7 R.2 F15.
X2.8194
X4.7923
G80
M9
M5
G91 G28 Z0.
That is something I would use canned text to accomplish
I would use the pcan2 and set that up in there
I tagged this into my pcan2 section, then you can adjust the plocation of pcan2
pcant_out	 #Canned text - build the string for output
 #Assign string select type outputs
 if cant_pos < three, #cant_pos indicates canned text output
 if cantext$ = three, bld = one
 if cantext$ = four, bld = zero
 #Build the cantext string
 if cantext$ = one, strcantext = strcantext + sm00
 if cantext$ = two, strcantext = strcantext + sm01
 if cantext$ > four,
	 #strtextno = no2str(cantext$)
	 #strcantext = strcantext + strm + strtextno
	 if cantext$ = 5,
		 pbld, n$, "()", e$
		 pbld, n$, "G91", "G28", "Y0.", e$
		 pbld, n$, "G00", "G90", pwcs, "X0.", e$
		 pbld, n$, "(SET X TO DESIRED LOCATION)", e$
		 pbld, "M00", e$
		 pbld, n$, "(RELEASE AND RETIGHTEN)", e$
		 pbld, n$, "()", e$
	 if cantext$ = 6,
		 pbld, n$, "()", e$
		 pbld, "M00", e$
		 pbld, n$, "(ADD/REMOVE SCREWS/CLAMPS)", e$
		 pbld, n$, "()", e$
 else, #cant_pos indicates coolant output
Then at the bottom of the post I edit this in;;;
[canned text]
1. "Stop"
2. "Ostop"
3. "Bld on"
4. "bLd off"
5. "VISE RELEASE"
6. "SCREWS/CLAMPS"
7. "M7"
8. "M8"
9. "M9"
10. "M10"
