how to edit mplfan to post canned cycles without decimals
Hello, I have to edit mplfan for x4 to change the depth of cut on canned cycles to whole numbers instead of decimals.
It reads like G71 P1 Q2 U.05 W.002 D.1 F.01
IT SHOULD READ G71 P1 Q2 U.05 W.002 D1000 F.01
also,
I need to make G83 read without a decimal number for Q
ex, G83 Z-1. Q1250 F.005 R.1
any suggestions?
I am definitely not a post expert but this is what I think you will have to change. Make sure you save a backup of the post before starting.
There should be a section of the post that look like this
fmt "Q" 2 peck1$ #First peck increment (positive)
I think you will have to change the 2 to something else. Look for a section in the post that looks like the following
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (:)
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 16 0 4 0 4t #No decimal, absolute, 4 trailing
Find the format type you want. You may have to create a new one if the correct one is not there. The one in the post by MSL above is probably what you need. Notice the number after fs2. This is the number you what to change the number the other section of the post to. In the example I have it is set to 2 so it would output absolute code with a decimal. I think you would want to use 16.
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize ( :)
If above section is from Mpfan post you need to use format # 16 which is the last one.
fs2 16 0 4 0 4t #No decimal, absolute, 4 trailing <--------------
