Can you guys please help with these simple MODs, I can pin down the solution yet !
O1392(1392) ------------------------------------> I want the group name here.
(CHUCKING DEPTH)
(CHUC PRESSURE)
(CYCLE TIME)
G20
N100(OD ROUGH RIGHT - 80 DEG. )
( FC RGH )
G0 T0101
M8
G97 S1000 M03
G0 G54 X1.7 Z.03 ------------------------------> Want M8 here by default
G50 S1000
G96 S500 M03
G72 W.1 R.01
G72 P1 Q3 U0. W.005 F.01
N1 G0 Z0. S500
G1 X0.
N3 Z.03
G0 X1.7 -------------------------------------------> Want M9 Here by default
M9
G28 U0. W0.
M01
You are right on the dot about the period; it does consider it an extension after that. That also explains why I cannot have the / since windows considers it a path separator. I was able to post the heading I want, however I must save the NC file as that complete heading then change it to what I want the file to be named. Is there a way to use the group name as it is posted. Also any word on getting the M9 placed with the retract move ?
-Bill
I had the same problem with coolant M code location. I wanted it on the G43 Z* H line, regardless of wether it was set to before, with or after.
I can dig out the info for you if you want. It means that Canned Text won't work properly, but I don't use that anyway.
Sure why not. I can use all the help I can get. Did you get the coolant to turn off with the retract move as well ?
How do I know that I'm using V9 or X style?
Go into your Machine Definition and see what you have set up there. Go to the Edit General Machine Parameters. If Support coolant value in post-processor(provides backwards compatibility for old post) is check then you V9 coolant enabled if it is unchecked then you have the newer more option and improved process in place.
