Custom vertical lathe tools
Machine: Mazak Integrex w/Matrix control
Post/X7 issue: The vertical position (B90.) for custom lathe tools is not being read.
There is no issue with the non-custom lathe tools.
Post code from lathe tool change (ltlchg$)/tool call section only:
ptoolcall
if synch_flg & vert, pbld, n$,"G0 B90. W-15.",e$
else,
if vert, pbld, n$,"G0 B90.",e$
if not(vert) & spindle_no$ = 0,pbld, n$,"G0 B0.",e$
if not(vert) & spindle_no$ = 1,pbld, n$,"G0 B180.",e$
Post code for tool call:
ptoolcall
if posttype$ <> 2,
if cuttype = 2, tdircode = 0.01
if abs(cuttype) = 3 | cuttype = 4, tdircode = 0.01
if cuttype = -2,tdircode= 0.01
if cuttype > 5, tdircode = 0.01 # use .0 for all 5-axis except when 5-axis with 4-axis output
if cuttype = 5 & not(mr3$), tdircode = 0.01
if cuttype = 5 & mr3$ & mill5$ = 1,
if fmtrnd(babs) = 90, tdircode = 0.01
else, tdircode = 0.02
if lturret$ = 0, tdircode = .7575
if posttype$ = 2 & vert, #vertical tools
if orient$ = 1, tdircode = 0.02 #unrotated mill spindle
if orient$ = 5, tdircode = 0.02
if orient$ = 2, tdircode = 0.05 #rotated mill spindle
if orient$ = 6, tdircode = 0.05
if posttype$ = 2 & not(vert) & spindle_no$ = 0, #horizontal tools on main
if orient$ = 4, tdircode = 0.01 #unrotated mill spindle
if orient$ = 8, tdircode = 0.01
if orient$ = 1, tdircode = 0.04 #rotated mill spindle
if orient$ = 5, tdircode = 0.04
if posttype$ = 2 & not(vert) & spindle_no$ = 1, #horizontal tools on sub
if orient$ = 5, tdircode = 0.03 #unrotated mill spindle
if orient$ = 8, tdircode = 0.03
if orient$ = 6, tdircode = 0.06 #rotated mill spindle
if orient$ = 7, tdircode = 0.06
if mi6$ > 0, tdircode = mi6$/10 # Override #entered as integer
if mi6$ > 9, tdircode = mi6$/100 # Override
if mr2$ & sav_tdircode = 0,
sav_tdircode = tdircode
tdircode = 0
toolno = int(t$)
#suffix = ((t$/100) - toolno) / 100
if tcode_sw = 0,
toolno = toolno + tdircode #4-Digit T-Code
result = newfs(21,toolno)
#if lturret$ = 0, result = newfs(24,toolno)
if toolchng, pbld, n$, *toolno,next_tool$,"M6",tloffno$, e$
else, pbld, n$, toolno, e$
The tool path code in the posted program for the custom tool is correct for a lathe tool at B90. However, the B on the main spindle outputs B0. and the sub spindle outputs B180. If I manually change the B to B90. in the program there is no issue. Non-custom lathe tools will output correctly.
Sample tool path code:
N1
(Custom Vert lathe tool)
G28 U0. Y0.
G28 W0.
M901
M202
T17.04 T17 M6 D17
G0 B0. – Should read B90.
G53.5
G18
G50 S2000 R1 (MAIN)
G96 S100 M03 R1 (MAIN)
**removed tool path code**
Okay are you using MU1? There was a known bug with certain tools in X7 that caused all kind of havoc for lathe that was addressed in MU1. I suggest you make a .z2g and shoot it off to your dealer and let them take alook to help you sort it out. I never set my tools up the way you are describing so unless I have something to follow not going to be much help.
