Lathe Canned Rough Output is Wrong
Hi,
I put together a program with a rough canned cycle for cutting the OD of a part on our HAAS TL-1, but when I go to post the program - it outputs opposite of what I want. I enter that I would like to leave .010" per side on the part for finishing in the "Stock to leave in X (U)" box, but instead I get the coding below. This is useable as is with some manual modification, but I would like to correct the problem so in the future it will output correctly. I've also attached a screen shot of mastercam prior to generating this code.
N110 G0 T0101
N120 G97 S969 M03
N130 G0 G54 X1.325 Z.1
N140 G50 S1800
N150 G96 S336
N560 G71 U.04 R.01
N570 G71 P580 Q690 U-.02 W.002 F.0048
N580 G0 G41 X.8325 S336
N590 G1 Z-.0079
N600 X.8641 Z-.0237
N610 G3 X.875 Z-.0369 I-.0131 K-.0132
N620 G1 X.8759 Z-1.1225
N630 G2 X.8838 Z-1.125 I.004 K.0019
N640 G1 X1.0515
N650 G3 X1.0779 Z-1.1305 K-.0186
N660 G1 X1.1142 Z-1.1487
N670 G3 X1.125 Z-1.1619 I-.0132 K-.0131
N680 G1 Z-1.405
N690 G40 X1.325
N700 G0 Z.1
N830 G28 U0. W0. M05
N840 T0100
N850 M30
Thanks for the help!
Bret
not an expert on haas lathes but looking at your screen shot you have the comp
set to wear. when ever i use the canned cycles i turn the comp to off.
that way the numbers match the print.
then i do a seperate finish pass with the comp on set to control.
it maybe doing that because your tool might have comp to the center of the radius
not the z/x edges.
HTH Ken
[Maybe I am mistaken for a Haas lathe, but shouldn't the rough direction be on the other side of the part?]
after taking closer look at your settings i also noticed that you have the comp direction to the left.
not sure but i think that should be to the right. that might giving you the "u-.02".
Ken
Thanks for the input everyone!
  • I just tried turning the comp off - no change in output
  • I tried adjusting comp from left to right and vice versa with comp on and off - no change in output
This lathe is basically a glorified engine lathe with servo motors installed - it uses a standard Aloris tool post. When I enter my value (in this instance .01") into the box (stock I want to leave in X) in mastercam, it generates the actual lines of code down at the lower left of the screen (or at least what should be the correct lines). But when I go to process, they generate incorrect. I notice above that box it states: "The actual NC Output depends on the post processor". Is there a value in the post that controls whether it generates as a positive or negative value? If I enter the a negative value in mastercam for what I want to leave - it generates as a positive value. For right now - I will just cheat and change the program to suit - but I would like to get this figured out.
Once again,
Bret
not sure what your tool path looks like, but if you look at your posted code " N130 X1.325"
and your screen shot shows "X-1.325" per "tozmasters" post maybe try switching sides
in the roughing pattern.
also "N590 G1 Z-.0079" is this correct if not it might be how the rad. is defined on your tool,
compted to the center not the edges.
most od paths in mc are usually programed on the X+ sidein mc.
not as you would always see them in relation to how the machine is orintated.
Ken
I just recently had the same problem, in a way--whenever I would do a canned rough with a boring bar, the U value would be negative. On our Okumas, the value has to always be a positive.
I made this change in my post:
in the lathe canned cycle end postblock prcc_call_end$,
find the line xstckcc = xstckcc * xmult4 * lccdirx
and change it to xstckcc = abs(xstckcc * xmult4 * lccdirx)
(labels may be different depending on your post)
Also, I'm not sure if you are asking about the stock to leave, but .010" per side is .020" in radial, so that number is correct. I'm sure you know that, I just wanted to make sure it was said. If that's not right depending on your machine, the problem is the multiplier (xmult4 in the above code.)
  • 3 weeks later...
