Change tap cycle from ipm to ipr
Hello I have a Medlas m3 control (Mitsubishi). On my post i need to output feed in Inches per revolution
ptap$ #Canned Tap Cycle
pdrlcommonb
"M05", e$
pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
prdrlout, *feed, *speed, strcantext, e$
pcom_movea
I added the ( "m05", e$ ) line to stop the spindle which works
but I need to change the feed form F44.57 to F.0625 (3/8-16 tap)
G00G90G54X0.Y-8.886B90.S713M03
G43H203Z2.M08T123
M05
G98G84Z.787R1.5375F44.57S713
Pete
X7 mu2
It's odd that you wouldn't have use_pitch
you should have a variable named pitch, so on the line before your cycle output, put in this line:
pitch = 1/n_tap_thds$
and replace *feed with *pitch in the output line.
And never use * in a formula the way you typed it - the asterisk is used to force output into the final code; but in a formula it's used for multiplication.
The post he is using could be an older post from a previous version, Pete you could borrow some logic from another post to accomplish the pitch output.
This tapping cycle is from the MPFan post that gets installed with Mcam. To use the asterisk as part of an equation there needs to be a space between what you're multiplying, if you use the asterisk with no space it creates a force condition.
fmt "F" 2 pitch #Tap pitch (units per thread) <<< don't forget to format the variable "pitch", fs2 should output a 4 place absolute decimal
pdrlcommonb
result = newfs(17, feed) # Set for tapping Feedrate format <<< this will reset the decimal output to two places, if you do not want 2 place output use the pound sign "#" to comment out the line. The other way to do it would be to use fs17 when you format "pitch" check the format statements, for 2 place output it should look like this "fs2 17 0.2 0.3" This will result in two place for inch and three place for metric.
if met_tool$,
if toolismetric, pitch = n_tap_thds$ #Metric NC Code - Metric Tap
else, pitch = (1/n_tap_thds$) * 25.4 #Metric NC Code - English Tap
else,
if toolismetric, pitch = n_tap_thds$ * (1/25.4) #English NC Code - Metric Tap
else, pitch = 1/n_tap_thds$ #English NC Code - English Tap
pitch = pitch * speed #Force Units Per Minute for regular Tap cycle
pbld, n$, sg94, e$
prdrlout, *pitch, !feed, strcantext, e$
pcom_movea
pdrlcommonb
if met_tool$,
else,
pbld, n$, sg94, e$
pcom_movea
The part in red is exactly what OP is trying to avoid.
hello
I replaced my, ptap$ #Canned Tap Cycle
with
pdrlcommonb
if met_tool$,
else,
pbld, n$, sg94, e$
pcom_movea
from MPFAN.pst
this is what i got- G99G84Z-.5R.1
this is what i want G99G84Z-.5R.1S713F.0625
here are the errors
15 May 2014 10:27:13 AM - <0> - Report created.
15 May 2014 10:27:13 AM - <2> - Initialize posting log file
15 May 2014 10:27:13 AM - <2> - Using MP run version 16.00 and post components version 16.00
15 May 2014 10:27:13 AM - <2> - Initiate opening the post processor file(s).
15 May 2014 10:27:13 AM - <2> - C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX7\MILL\POSTS\MITSUBISHI MELDAS 4 - AXIS HMC.PST
15 May 2014 10:27:13 AM - <2> - The post processor file has been successfully opened.
15 May 2014 10:27:13 AM - <2> - Post version information (input):
15 May 2014 10:27:13 AM - <2> - UPDATEPOST Version 16. was used to modify this file.
15 May 2014 10:27:13 AM - <2> - The file was modified by this product on 05 Sep 2013 13:37:32
15 May 2014 10:27:13 AM - <2> - The post was written to run with Mastercam Version 16.
15 May 2014 10:27:13 AM - <2> - The post product type is Mill.
15 May 2014 10:27:13 AM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
15 May 2014 10:27:13 AM - <2> - Search for defined post variables, strings, postblocks was successful.
15 May 2014 10:27:13 AM - <2> - PST LINE (1124) - The formula/boolean failed (general message), , Label has not been defined[12]
15 May 2014 10:27:13 AM - <2> - PST LINE (1124) - The post block output type processing has failed!, , Label has not been defined[26]
15 May 2014 10:27:13 AM - <2> - PST LINE (1124) - The post block output type processing has failed!, , Label was expected but was not found[32], Illegal character(s) encountered
15 May 2014 10:27:13 AM - <2> - PST LINE (1125) - The post block output type processing has failed!, , Label has not been defined[15]
15 May 2014 10:27:13 AM - <2> - PST LINE (1125) - The post block output type processing has failed!, , Label was expected but was not found[21], Illegal character(s) encountered
15 May 2014 10:27:13 AM - <2> - PST LINE (1129) - The formula/boolean failed (general message), , Label has not been defined[12]
15 May 2014 10:27:13 AM - <2> - PST LINE (1129) - The post block output type processing has failed!, , Label has not been defined[26]
15 May 2014 10:27:13 AM - <2> - PST LINE (1129) - The post block output type processing has failed!, , Label was expected but was not found[32], Illegal character(s) encountered
15 May 2014 10:27:13 AM - <2> - PST LINE (1130) - The post block output type processing has failed!, , Label has not been defined[15]
15 May 2014 10:27:13 AM - <2> - PST LINE (1130) - The post block output type processing has failed!, , Label was expected but was not found[21], Illegal character(s) encountered
15 May 2014 10:27:13 AM - <2> - PST LINE (1132) - The post block output type processing has failed!, , Label has not been defined[7]
15 May 2014 10:27:13 AM - <2> - PST LINE (1132) - The post block output type processing has failed!, , Label was expected but was not found[13], Illegal character(s) encountered
15 May 2014 10:27:13 AM - <2> - PST LINE (1135) - The post block output type processing has failed!, , Label has not been defined[19]
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'arcoutput$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'arcoutputxz$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'arcoutputyz$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'larcoutput$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'larctypexz$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'larcoutputyz$' was re-initialized from 1. to 0.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'arccheck$' was re-initialized from 1. to 111.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'larccheck$' was re-initialized from 1. to 111.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'rotfeed4$' was re-initialized from 2. to 1.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'rotfeed5$' was re-initialized from 3. to 1.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'lrotfeed4$' was re-initialized from 2. to 1.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'lrotfeed5$' was re-initialized from 0. to 1.
15 May 2014 10:27:13 AM - <2> - CONTROL DEFINITION - Post variable 'peckacel$' was re-initialized from 0. to 1.
15 May 2014 10:27:13 AM - <2> - RUN TIME - PST(1129), NCI(100) - The math calculation/formula has an error
15 May 2014 10:27:13 AM - <2> - Successful completion of posting process!
This message is referring to the user defined variables that were added to your post using the ptap postblock from MPFan. When you open the post in the Mcam or Cimco editor you will see a number variable calls with $ attached to their assends, those are predefined variables. When you create a new variable "user defined" it has to be formatted or initialized. I am guessing that you are working with an older post and it never had "pitch" or "toolismetric" as user defined variables. You can borrow the format for "pitch" from MPFan.
Like I said, don't forget to format the variable "pitch", fs2 should output a 4 place absolute decimal, without the "F" character there is no label for the value of pitch, without the format statement 2 the post does not know how to output the numeric value.
The newfs (17,feed) will reset the decimal output to two places, if you do not want 2 place output use the pound sign "#" to comment out the line. The other way to do it would be to use fs17 when you format "pitch"
Check the format statements, for 2 place output it should look like this "fs2 17 0.2 0.3" This will result in two place for inch and three place for metric.
Your post more than likely does not have the call for "toolismetric" this is another user defined variable, you can borrow the initialization from MPFan.
toolismetric : 0 #flag that tool is metric
To use the metric tool information you will need to setup a parameter call in postblock called pparameters$
# Check To See if tool is metric
if prmcode$ = 20007, toolismetric = rparsngl(sparameter$, 11)
