lathe face drill needs to be ipr feed
I have a fanuc 18i control and using- GENERIC FANUC 4X MT_LATHE.pst
when i use C axis face drill the post outputs the feed in IPM and I need IPR
also my "Dia offset 0" box is greyed in C-axis face drill out so when it post i get T0900 in stead of T0909
X7 mu2
puma TT2500SY
fanuc 18i
G0 T0900
G17
M35
M8
G0 G54 Z.25
X3.74
C180.
G97 S3834 M33
G83 Z-.343 R.1 F15.34
C60.
C300.
G80
M9
G28 U0. H0. M35
G28 W0. H0.
T0900
Probably the easiest way is to set up a Misc real to trigger feed per rev.
If it's a drill cycle, might go thru the drill cycle
Declare / format your variables:
use_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping
fmt "N" 4 n_tap_thds$ #Number of threads per inch (tpi)
fmt "F" 2 pitch #Tap pitch (inches per thread)
Might capture it in "pdrlcommonb" post block
if mi6$, use_pitch = 1
if use_pitch = 1,
pbld, n$, "G95",e$
else,
pbld, n$,sgfeed, e$
(Drill cycle post block)
mtap$ #Canned tap cycle, mill
pdrlcommonb
if use_pitch,
pitch = 1/n_tap_thds$
pcan1, pbld, n$, *sgdrlref, pgdrlout, pfxout, pfcout, pfzout,
prdrlout,*pitch, strcantext, e$
else,
prdrlout,pffr, strcantext, e$
pcom_movea
I couldn't figure out the above solution.
I put " sg98 " into the canned drill cycle below and i seemed to work.
mdrill$ #Canned drill cycle, mill
pdrlcommonb
pcan1, pbld, n$, *sgdrlref, pgdrlout, sg98, pxout, pyout, pzout,
pcout, prdrlout, dwell$, pffr, strcantext, e$
pcom_movea
My reseller said - without looking at the entire I can't say if there are anger conflicts but it looks good.
what are anger conflicts?
When I use canned drill cycle it outputs T0900 when i need T0909
the reseller said I needed to edit a math equation in the post
would it be something like- toolno = t$ * 100 + zero
on the #tool change mill it was
toolno = t$ * 100 + tolffno$ but on my c-axis face drill the Dia offset is 0 and greyed out.
i changed it to
toolno = t$ * 100 + t$
then it posted T0909
is there any way to get dia offset un-greyed?
Nope since a Drill should never have a diameter offset. You can make a mi or mr control this if you need it, but milling toolpaths like this when used in lathe never had the logic built into them that you might need adjustments. It was done along the lines of you would never need them since what would you be adjusting. You can define or do a different type of toolpath and they are not greyed out, but would need to know exactly what you are trying to accomplish.
Before i changed toolno = t$ * 100 + tloffno$ to toolno = t$ * 100 + t$
it would post T0900 instead of T09?? the last 2 digits are for the tool length.
It would index to tool 9 but would have zero tool length offset
toolno = t$ * 100 + t$ works if i want the same tool & length number, but some times i might need T0919
is it possible to use toolno = t$ * 100 + ( Len. offset) ?
Yes, but the problem is the lathe operations do not possess such a thing so not sure how you would make something that is not there work like you are thinking. That was why I suggested the mi or mr process to help control this. Mill toolpaths have the length offset, but not the lathe toolpaths unless I am missing something.
