Canned Cycle Rough - G68
Hello guys.
I am studying a way to configure the turning cycle G68 XZCDLMKFHSE Q.
I managed to set almost the whole cycle, but the value of X and Z not yet. X and Z are the start profile.
I know the generic pos mastercam calculates this, but I can not capture these values​​. Can someone give me a light on this.
G0 X110. Z2.566
F.2
G68 X52.634 Z.097 C2. D.2 L.4 M.2 S10 E20 Q220 (Correctly)
G68 X0. Z0. C2. D.2 L.4 M.2 S10 E20 Q220 (Wrongly)
N10 X52.634
G1 Z.097
X55.297 Z-1.234
G3 X55.765 Z-1.8 R.8
G1 Z-7.372
Z-24.517
Z-32.604
Z-58.773
X63.639 Z-69.42
X97.127 Z-76.026
G3 X97.862 Z-76.32 R.8
G1 X99.723 Z-77.687
G3 X100. Z-78.137 R.8
G1 Z-104.726
N20 X110.
G0 Z2.566
G0 X300. Z100.
The values ​​that are coming X0 and Z0 should be X52.634 Z.097.
I know that somehow these values ​​can be captured in this excerpt from post processor. But do not know how. formulate and test several already failed.
prcc_setup$ #Lathe canned cycle setup
#Capture values from rough
sav_iprcc = c1_ipr_actv
sav_feedcc = c1_fr_pos
if orient$ = one|orient$ = two|orient$ = five|orient$ = 6, lccdirx = one
else, lccdirx = m_one
if orient$ = one|orient$ = four|orient$ = five|orient$ = 8, lccdirz = one
else, lccdirz = m_one
if lathecc > zero, cc_stop_fcc = one
else, cc_stop_fcc = zero
#G74/G75
if lathecc = three,
lcc_xcst = vequ (copy_x)
if dopeckcc = zero,
depthcc = zero
clearcc = zero
if directcc > one,
gcodecc = four
grvspcc = stepcc
grvdpcc = depthcc
else,
gcodecc = five
grvspcc = depthcc
grvdpcc = stepcc
else,
if n1_cc_pos,
sav_xa = vequ(copy_x)
#Shift for cutter comp. start position
copy_x = copy_x + (lcc_move * lccdirx)
copy_z = copy_z + (lcc_move * lccdirz)
pcom_moveb
compok = zero
lcc_cc_pos = one
else, lcc_cc_pos = zero
sub_seq_typ$ = 0
prcc_call_st$ #Rough canned cycle start
if tool_op$ <> 208,
sav_subout = subout$
sav_omitsq = omitseq$
omitseq$ = one
extprg$ = one
subout$ = three
prcc_call_end$ #Rough canned cycle end
# Restore cc_1013 to the value it held prior to the rough
# groove canned cycle. cc_1013 was changed in ptoolend.
if tool_op$ = 208 | tool_op$ = 62, cc_1013$ = sav_cc_1013
if tool_op$ <> 208,
omitseq$ = sav_omitsq
#Close the ext file
result = fclose (sbufname3$)
#Open the ext file as a buffer
#Use the size to determine the start and end sequence
subout$ = sav_subout
size3 = rbuf(three, zero)
if omitseq$ = one,
ng70s = n$
ng70e = n$ + seqinc$
else,
if old_new_sw = zero, ng70s = n$ + seqinc$
else, ng70s = n$ + (seqinc$ * two)
ng70e = ng70s + (seqinc$ * (size3 - one))
pwrite_g70
#Setup the stock and clearance directions
g73x = vsub (lcc_xcst,lcc_xcend)
if old_new_sw = zero, g73x = g73x
else, g73x = g73x * dia_mult
g73z = g73z
xstckcc = xstckcc * dia_mult * lccdirx
zstckcc = zstckcc * lccdirz
clearcc = clearcc * lccdirz
#Write the cycle definition
sav_feed = feed
sav_ipr = ipr_actv$
feed = sav_feedcc
ipr_actv$ = sav_iprcc
if lathecc = three,
#Setup the previous position for inc. in G74/G75 cycle
sav_xa = vequ(xabs) #Save the cycle end
copy_x = vequ(lcc_xcst) #The cycle start raw
pshft_map_xa
pxyzcout ##The cycle start in machine terms
ps_inc_calc #Recalculate incremental
pe_inc_calc #Update previous at start
xabs = vequ(sav_xa) #Restore the cycle end
if gcodecc < three, pg71old
if gcodecc = three, pg73old
if gcodecc > three, pg74old
else,
if gcodecc < three, pg71new
if gcodecc = three, pg73new
if gcodecc > three, pg74new
if lathecc = three,
#Set the cycle end position at the original start
pshft_map_xa
ps_inc_calc #Position at start
feed = sav_feed
ipr_actv$ = sav_ipr
if tool_op$ <> 208,
#Bug2 is off to prevent execution crashes with long strings
bug2$ = zero
#Write the cycle profile, sequence are written now
rc3 = one
while rc3 <= size3,
#Write the lathe canned cycle profile
string3 = rbuf (three, rc3)
if rc3 = two,
#Add the finish spindle speed to the first move
speed = n1_ss
pbld, *n$, *string3, e$ #*speed,
else,
if omitseq$ = one & rc3 = size3 + one, pbld, *n$, *string3, e$
else, pbld, n$, *string3, e$
#Close the buffer
result = fclose (three)
#Remove the ext file
result = remove (sbufname3$)
bug2$ = sav_bug2
pfcc_call$ #G70 recall output postblock
if cc_stop_fcc = zero,
pread_g70
if foundcc = zero, result = mprint(sfccerror)
no_nc_out$ = zero
cc_stop_fcc = zero
pread_g70 #Read G70 recall buffer
foundcc = zero
size2 = rbuf (two, zero)
wc2 = one
while wc2 <= size2 & foundcc = zero,
fcc_subid = rbuf (two, wc2)
if fcc_subid = sub_op_id$,
gcodecc = zero
ng70s = fcc_ng70s
ng70e = fcc_ng70e
pbld, n$, *scclgcode, *ng70s, *ng70e, e$
foundcc = one
pwrite_g70 #Write G70 recall buffer
fcc_ng70s = ng70s
fcc_ng70e = ng70e
fcc_subid = wbuf (two, rc2)
I appreciate your cooperation in my learning.
Like I answered you privately not something easily undertaken. Things go on with the mp.dll and mp.pst that does some things behind the scenes. Might try the debugger to find what is the exact variable capturing and then outputting the value. Might could capture that and then buffer it our or something like that. but tons of extra work for a process I am really not sure you need. Not sure why the standard canned cycle could not be modified to do what you are after and be done.
Hi Bayron,
Can you upload a Zip to Go file that contains a sample Mastercam file, and the post that you are working on?
What version of Mastercam are you writing this post for? I believe X6 had a re-write of the Lathe canned cycles. There are some switch strings at the top of the post that can be used to configure the output for the canned cycle. I think that only changes the output of Cutter Comp, and sets if the comp value is turned on inside the cycle or not.
When the values are being calculated, I believe these variables hold the start and end positions, but you'll have to check and see where they get their values from:
lcc_xcst	 : 0	 #Lathe canned cycle contour start position
lcc_ycst	 : 0	 #Lathe canned cycle contour start position
lcc_zcst	 : 0	 #Lathe canned cycle contour start position
lcc_xcend    : 0	 #Lathe canned cycle contour end position
lcc_ycend    : 0	 #Lathe canned cycle contour end position
lcc_zcend    : 0	 #Lathe canned cycle contour end position
The values are probably set using a 'vequ' function. "Vector Equate" (vequ) is a function that copies the values of three sequential variables, and loads them into three other consecutive variables.
That is what this line does:
To give you any more tips for debugging this, I'd need to see your sample files...
Hi Bayron,
Hi Colin
Thank you, your answer gave me many ideas, I'll do some tests.
Dear Colin how do I send you the Zip to Go?
Thank you again.
Dear Crazy^Millman, thank you very much
First, make sure you have your test file loaded.
Go to Help > Zip2Go Utility.
In the dialog box, make sure the "toolpaths" check box is turned on. (leave the other boxes that are already on, checked).
Press the "create Zip2go file" button.
That places a copy of the Zip to go file in your "my documents" folder, with the same name as your MCX-7 file.
In this message board, you can do a Reply, then click on "More Reply Options". There is a feature on the message board to attach a file to a forum post. I'd suggest attaching the Zip2Go file there, that way others can take a look and help you get this figured out. I think of Emastercam like a small community. People will jump in when someone asks a question. I help when I can, but I can't promise I'll be able to answer your question.
