PARAMETER
I'm trying to look into the
CLEARANCE - INCREMENTAL
RETRACT - INCREMENTAL
FEED PLANE - INCREMENTAL
TOP OF STOCK - INCREMENTAL
DEPTH - INCREMENTAL
Would you guys please can tell me what the
prmcode$ code for each of those? I would like to use the pparameter$ to call out the function. Please help.
I'm trying to make the post warns if someone is using INCREMENTAL instead of ABSOLUTE because it is very dangerous for the setup man since the are not getting used to with INCREMENTAL programming. Please help.
Thank you
Hi Pc,
Those incremental values have NOTHING to do with incremental PROGRAMMING !!!
Before post editing it's better to learn how mastercam works, this is very basic stuff !!!
Make an simple basic program.
Play with those settings and see on your screen what happens.
Then check your posted code for different settings.
PC,
Henk is correct about what he is saying. All values are output in the NCI file as Absolute positions. The "Incremental" setting in the Linking parameters specifies that the depth values are incremental from the Z depth of the geometry on the screen in Mastercam.
A "Top of Stock" set to 0.0 "incremental" just means that the top of stock starts at wherever the point lies in Z. A "Depth" of -2.0 "Incremental", does not switch the canned cycle to incremental output, it just means the depth of the hole is calculated based on the drill point that was selected.
Since you asked:
Clearance: true = incremental, false = absolute | 10021
Retract: true = incremental, false = absolute | 10023
Feed Plane: true = incremental, false = absolute | 10025
Top of Stock: true = incremental, false = absolute | 10028
Depth: true = incremental, false = absolute | 15103
Hi Colin,
Where do I put those definitions as you wrote:
Thank you Colin
Should I put it at this section, Colin?
pparameter$ # Run parameter table
if opcode$=13 | opcode$=14, result = fprm (opcode$)
if prmcode$ = 10000, stoper = ucase(sparameter$)
if stoper=snull, stoper = snullop
if prmcode$ = 10010, stock = rpar(sparameter$,1) # Stock to leave in Z
if prmcode$ = 10068, stock1 = rpar(sparameter$,1) # Stock to leave in XY
if prmcode$ = 12068, stock2 = rpar(sparameter$,1) # Stock to leave in Z facing
if prmcode$ = 10020, clearinc = rpar(sparameter$,1) #param 10020 is clearance now and 10021 indicates abs or inc
if prmcode$ = 15100, clearflg = rpar(sparameter$,1)
if prmcode$ = 15145, metvals = rpar(sparameter$,1)
if prmcode$ = 15339, clearstrt = rpar(sparameter$,1)
if prmcode$ = 15346, comp_type = rpar(sparameter$,1)
if prmcode$ = 15182, miscvalon = rpar(sparameter$,1)
if prmcode$ = 20010, sconstplname = ucase(sparameter$)
if prmcode$ = 20011, sconstplcomm = ucase(sparameter$)
if prmcode$ = 20012, stoolplname = ucase(sparameter$)
if prmcode$ = 20013, stoolplcomm = ucase(sparameter$)
if prmcode$ = 20014, swcsplname = ucase(sparameter$)
if prmcode$ = 20015, swcsplcomm = ucase(sparameter$)
if prmcode$ = 20016, smatlname1 = ucase(sparameter$)
if prmcode$ = 20017, smatlname2 = ucase(sparameter$)
if prmcode$ = 20018, stpgrpname = ucase(sparameter$)
if prmcode$ = 12025, rotary_axis2 = rpar(sparameter$,1) #Capture the axis of rotation in Multiaxis Drill and Curve 5 Axis
if prmcode$ = 15371, axissubdir = rpar(sparameter$,1)
if prmcode$ = 10029, operation_depth = rpar(sparameter$, 1) #Capture the full depth of OP
if prmcode$ = 10027, OpTopOfStock = rpar(sparameter$, 1) # Operation Top of Stock
if prmcode$ = 10020, OpClrPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15374, OpRtrPlane = rpar(sparameter$, 1) # Operation Retract plane
if prmcode$ = 10024, OpFeedPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15100, OpClrPlane_ON = rpar(sparameter$, 1) # Operation Clearance plane set or not
if prmcode$ = 15101, OpRtrPlane_ON = rpar(sparameter$, 1) # Operation Retract plane set or not
if prmcode$ = 12628,
hst_flg = 1
hststyle = rpar(sparameter$,1)
if prmcode$ = 15084, NumEntities = rpar(sparameter$, 1)
if prmcode$ = 15211, DepthCuts = rpar(sparameter$, 1)
if prmcode$ = 15240, sOpSeqNo = sparameter$ #This is the operation manager operation number
if prmcode$ = 20001,
s20001 = sparameter$
s20002 = sparameter$
Hi Colin,
I have this message, would you please tell me where do I define your definitions? Thank you
04 Jun 2014 06:14:43 AM - <2> - PST LINE (638) - The left side of the formula is the wrong type (var/string)
04 Jun 2014 06:14:43 AM - <2> - PST LINE (1775) - The post block output type processing has failed!, , Illegal character(s) encountered, Label has not been defined[33]
04 Jun 2014 06:14:43 AM - <2> - PST LINE (1775) - The post block output type processing has failed!, , Label has not been defined[44]
04 Jun 2014 06:14:43 AM - <2> - PST LINE (1775) - The post block output type processing has failed!, , Label was expected but was not found[49], Illegal character(s) encountered
04 Jun 2014 06:14:43 AM - <2> - PST LINE (1775) - The post block output type processing has failed!, , Label has not been defined[64]
04 Jun 2014 06:14:43 AM - <2> - PST LINE (1775) - The post block output type processing has failed!, , Label was expected but was not found[70], Illegal character(s) encountered
04 Jun 2014 06:14:43 AM - <2> - PST LINE (635) - The math calculation/formula has an error
  • 3 months later...
Hallo and a good day.
I hope my english is not so bad, because i have not everyday  practice.
I try to create a new Variable to use in MasterCAM X7.
up at the beginning of post is :   test_par  :  " "
in middle i have write :  if prmcode$ = 15239, test_par = sparameter$
now i have the same message  error:   The left side of the formula is the wrong type (var/string)
please can you help  me ?
Thanks and greetings from Germany......
You're close. You have to initialize it as a string variable, not a numeric variable. To format simple strings, it must start with an "s"
So just change test_par to s_test_par
