STOCK TO LEAVE
Hi,
I just found out that "RADIAL" is not showed up for STOCK TO LEAVE. Do you guys know why? Like I have other 3D toolpaths, they would show STOCK TO LEAVE ON WALL or FLOOR if I input into the boxed that MASTERCAM allows us.
On RADIAL, the program works fine and it just not showing STOCK TO LEAVE all though I programmed it to leave on DRIVE .01, CHECK .005 and now thing showed up in the comment
Here is my post block, thanks for your help.
pstock # Comment amount of stock to leave
spaces$=0
if (opcode$=13 | opcode$=14),
if opcode$ = 13 & hst_flg, n$, pspc, scomm_str, "3D= ", *sopnotehst, scomm_end, e$
else, n$, pspc, scomm_str, "3D= ", *stoper, scomm_end, e$
if tool_op$ = 132,
n$, pspc, scomm_str, "3D XY STK= ", *stock_walls, scomm_end, e$
n$, pspc, scomm_str, "3D Z STK= ", *stock_floors, scomm_end, e$
else,
if check & stock<>0, n$, pspc, scomm_str, "3D XY STK= ", *stock, scomm_end, e$
if check & stock<>0, n$, pspc, scomm_str, "3D Z STK= ", *check, scomm_end, e$
hst_flg = 0
if stockleft,
if opcode$ = 1 | opcode$ = 2,
if stock1<>0, pbld, n$, scomm_str, "Z STK= ", *stock1, scomm_end, e$
if stock<>0, pbld, n$, scomm_str, "XY STK= ", *stock, scomm_end, e$
if opcode$ = 19 & stock2<>0, pbld, n$, scomm_str, "Z STK= ", *stock2, scomm_end, e$
if opcode$ = 4 & stock<>0, pbld, n$, scomm_str, "XY STK= ", *stock, scomm_end, e$
spaces$=sav_spc
  • 3 weeks later...
I tried to look and I think it is staying at this area below and I still having problem for it to call out the STOCK TO LEAVE for RADIAL:
fstrsel sdr00 nextdc$ sdrnote 20 -1
#Tool_Op String Select
stop00 : "None"
stop01 : "Contour"
stop02 : "Drill"
stop03 : "Pocket"
stop04 : "Transform"
stop05 : "Multi-surface rough parallel"
stop06 : "Multi-surface rough radial"
stop07 : "Multi-surface rough project"
stop08 : "Multi-surface rough flowline"
stop09 : "Multi-surface rough contour"
stop10 : "Multi-surface rough pocket"
stop11 : "Multi-surface finish parallel"
stop12 : "Multi-surface finish radial"
stop13 : "Multi-surface finish project"
stop14 : "Multi-surface finish flowline"
stop15 : "Multi-surface finish contour"
stop16 : "For C-Hook-created operations"
stop17 : "Manual entry"
stop18 : "None"
stop19 : "Point"
stop20 : "Trimmed"
stop21 : "Ruled"
stop22 : "Revolved"
stop23 : "Letters"
stop24 : "Swept 2D"
stop25 : "Swept 3D"
stop26 : "Coons"
stop27 : "Lofted"
stop28 : "5-Axis Drilling"
stool_op : "" #Target for string
fstrsel stop00 tool_op$ stool_op 29 -1
Hi,
Yepp, mpmaster is a good post and a good starting point. But the little details... Well, not developed correctly or 100%.
Like the "pccdia" on a circle movement... I used to work on many machines, but none of them can accomplish G41/G42 with G2/G3. Just a sidenote.
Anyhow Steven, "radial", what radial? Which toolpath strategy we talking'bout here?
Here what I made before, just for fun. Yes, this is the proper solution (X7). Maybe someone will find it here once and it will be a good point to start... Or...
DO NOT copy/paste directly into your post, I just wanna show an example, which work with every toolpath in every case.
The answer may hidden somewhere here... :)
Definitions:
OpLastOp_id : 0 # OP tracking ID
OpDrillPoints : 0 # Number of Drill Points
OpStock_XY : 0 # OP stock on XY or drive surfaces
OpStock_Z : 0 # OP stock on Z
OpStock_F : 0 # Facing OP stock on face
OpStock_C : 0 # Surface OP stock on check surface
OpStock_Wall : 0 # OP stock on 3D HSM Wall
OpStock_Floor : 0 # OP stock on 3D HSM Floor
OpStock_HSM_C : 0 # OP stock on 3D HSM Check
OpCompSide : 0 # OP Cutting Side
Op2D_HSM_Style : 0 # 2D HSM OP Type
Op3D_HSM_Style : 0 # 3D HSM OP Type
OpContType : 0 # 2D Contour OP Type
OpPockType : 0 # 2D Pocket OP Type
OpPockCutDir : no$ # 2D Pocket OP Cutting direction
OpFaceType : 0 # 2D Facing OP Type
OpPockStepO : 0 # Pocket OP StepOver in mm
OpPockStepO_P : 0 # Pocket OP StepOver in percentage
OpDepthCuts : no$ # 2D Operations - Depth cuts ON/OFF
OpDepthCuts_D : 0 # 2D Operations - Depth cuts rough value
OpMultiPass : no$ # 2D Operations - Multipass cuts ON/OFF
OpMultiPass_SO : 0 # 2D Operations - Multipass cuts step
OpMultiPass_N : 0 # 2D Operations - Multipass number of passes
OpHSMCutDir : no$ # HSM OP Cutting direction
OpHSMStepO : 0 # 2D HSM Stepover
OpHSMStepO_2 : 0 # 2D HSM Stepover - 2
OpThrdType : 0 # Thread mill type, RH/LH
OpThrdSide : 0 # Thread mill side, ID/OD
Op3DStep_O : 0 # Multisurface OP Stepover
Op3DStep_D : 0 # Multisurface OP Stepdown
Op3DFlowTyp : no$ # Multisurface Rough/Finish OP Flowline Type (Across)
Op3DFlow_AD : 0 # Multisurface Rough/Finish OP Flowline Across distance
Op3DFlow_SH : 0 # Multisurface Rough/Finish OP Flowline Scallop height
Op3DContFlat : 0 # Multisurface Rough/Finish OP Contour use Flat
Op3DContFlat_SO : 0 # Multisurface Rough/Finish OP Contour Stepover on Flats
Op3DRest_SO : 0 # Multisurface Rough Rest OP Stepover
Op3DPencil : 0 # Multisurface Finsih Pencil OP StepType
Op3DPen_P : 0 # Multisurface Finsih Pencil OP Passes total number
Op3DPen_SO : 0 # Multisurface Finsih Pencil OP Stepover
Op3DBlend_SO : 0 # Multisurface Finsih B OP Blend Stepover
Op3DHSMStepO : 0 # 3D HSM Stepover
Op3DHSMStepO_2 : 0 # 3D HSM Stepover - 2
Op3DHSMStep_D : 0 # 3D HSM Stepdown
OpDrlTipComp : 0 # Drill OP Tip compensation length
OpDrlTipComp_ON : no$ # Drill OP Tip compensation enabled
OpBrkTrghLen : 0 # Operation Breaktrough length
OpBrkTrghLen_ON : no$ # Operation Breaktrough enabled
fmt "Z" 25 OpDepth	 # Operation full depth, Z level
fmt 4 OpDrillPoints # Number of Drill Points
fmt 25 OpStock_XY "mm" # OP stock on XY or drive surfaces
fmt 25 OpStock_Z "mm" # OP stock on Z
fmt 25 OpStock_F "mm" # Facing OP stock on face
fmt 25 OpStock_C "mm" # Surface OP stock on check surface
fmt 25 OpStock_Wall "mm" # OP stock on 3D HSM Wall
fmt 25 OpStock_Floor "mm" # OP stock on 3D HSM Floor
fmt 25 OpStock_HSM_C "mm" # OP stock on 3D HSM Check
fmt 25 OpPockStepO "mm" # Pocket OP StepOver in mm
fmt 25 OpPockStepO_P "%" # Pocket OP StepOver in percentage
fmt 25 OpDepthCuts_D "mm" # 2D Operations - Depth cuts rough value
fmt 25 OpMultiPass_SO "mm" # 2D Operations - Multipass cuts step
fmt 4 OpMultiPass_N # 2D Operations - Multipass number of passes
fmt 25 OpHSMStepO "mm" # 2D HSM Stepover
fmt 25 OpHSMStepO_2 "mm" # 2D HSM Stepover - 2
fmt 25 Op3DStep_O "mm" # Multisurface OP Stepover
fmt 25 Op3DStep_D "mm" # Multisurface OP Stepdown
fmt 25 Op3DRadStep "mm" # Multisurface Rough/Finish OP Radial Step
fmt 25 Op3DFlow_AD "mm" # Multisurface Rough/Finish OP Flowline Across distance
fmt 25 Op3DFlow_SH "mm" # Multisurface Rough/Finish OP Flowline Scallop height
fmt 25 Op3DContFlat_SO "mm" # Multisurface Rough/Finish OP Contour Stepover on Flats
fmt 25 Op3DRest_SO "mm" # Multisurface Rough Rest OP Stepover
fmt 4 Op3DPen_P # Multisurface Finsih Pencil OP Passes total number
fmt 25 Op3DPen_SO "mm" # Multisurface Finsih Pencil OP Stepover
fmt 25 Op3DBlend_SO "mm" # Multisurface Finsih B OP Blend Stepover
fmt 25 Op3DHSMStepO "mm" # 3D HSM Stepover
fmt 25 Op3DHSMStepO_2 "mm" # 3D HSM Stepover - 2
fmt 25 Op3DHSMStep_D "mm" # 3D HSM Stepdown
fmt "Z" 25 OpThrdDpth # Thread Mill OP Depth
fmt "D" 25 OpThrdDia "mm" # Thread Mill OP Diameter
fmt 25 OpThrdPitch "mm" # Thread Mill OP Pitch
# Cutter Compensation Side
sComp_L : "LEFT"
sComp_R : "RIGHT"
sOpCompSide : ""
fstrsel sComp_L OpCompSide sOpCompSide 2 -1
#Select operation note - 2D HSM
sHsm2D00 : "2D HSM CORE"
sHsm2D01 : "2D HSM PEEL"
sHsm2D02 : "2D HSM BLEND"
sHsm2D03 : "2D HSM AREA"
sHsm2D04 : "2D HSM REST"
sHsm2D05 : "2D DYNAMIC AREA"
sHsm2D06 : "2D DYNAMIC REST"
sHsm2D07 : "2D DYNAMIC CORE"
sHsm2D08 : "2D DYNAMIC CONTOUR"
sHsm2D09 : "----"
sHsm2D10 : "----"
sHsm2D11 : "----"
sHsm2D12 : "----"
sHsm2D13 : "----"
sHsm2D14 : "----"
sOpType_2D_HSM : ""
fstrsel sHsm2D00 Op2D_HSM_Style sOpType_2D_HSM 15 -1
#Select operation note - 3D HSM
sHsm3D00 : "3D HSM CORE ROUGH"
sHsm3D01 : "3D HSM AREA CLEARANCE"
sHsm3D02 : "3D HSM WATERLINE"
sHsm3D03 : "3D HSM SCALLOP"
sHsm3D04 : "3D HSM HORIZONTAL AREA"
sHsm3D05 : "3D HSM RASTER"
sHsm3D06 : "3D HSM PENCIL"
sHsm3D07 : "3D HSM HYBRID"
sHsm3D08 : "-----"
sHsm3D09 : "3D HSM SPIRAL"
sHsm3D10 : "3D HSM RADIAL"
sHsm3D11 : "3D HSM REST ROUGH"
sHsm3D12 : "3D OPTIAREA"
sHsm3D13 : "3D OPTICORE"
sHsm3D14 : "3D OPTIREST"
sHsm3D15 : "3D HSM PROJECT"
sOpType_3D_HSM : ""
fstrsel sHsm3D00 Op3D_HSM_Style sOpType_3D_HSM 16 -1
#Select operation note - Drill
sdr00 : "COUNTER BORE"
sdr01 : "PECK DRILL"
sdr02 : "CHIP BREAK"
sdr03 : "TAP"
sdr04 : "BORE #1"
sdr05 : "BORE #2"
sdr06 : "FINE BORE"
sdr07 : "MISC #2"
sdr08 : "CUSTOM CYCLE 9"
sdr09 : "CUSTOM CYCLE 10"
sdr10 : "CUSTOM CYCLE 11"
sdr11 : "CUSTOM CYCLE 12"
sdr12 : "CUSTOM CYCLE 13"
sdr13 : "CUSTOM CYCLE 14"
sdr14 : "CUSTOM CYCLE 15"
sdr15 : "CUSTOM CYCLE 16"
sdr16 : "CUSTOM CYCLE 17"
sdr17 : "CUSTOM CYCLE 18"
sdr18 : "CUSTOM CYCLE 19"
sdr19 : "CUSTOM CYCLE 20"
sDrlOp : ""
fstrsel sdr00 nextdc$ sDrlOp 20 -1
stop00 : "None"
stop01 : "Contour"
stop02 : "Drill"
stop03 : "Pocket"
stop05 : "Surface Rough Parallel"
stop06 : "Surface Rough Radial"
stop07 : "Surface Rough Project"
stop08 : "Surface Rough Flowline"
stop09 : "Surface Rough Contour"
stop10 : "Surface Rough Pocket"
stop11 : "Surface Finish Parallel"
stop12 : "Surface Finish Radial"
stop13 : "Surface Finish Project"
stop14 : "Surface Finish Flowline"
stop15 : "Surface Finish Contour"
stop18 : "None"
stop19 : "Point"
stop20 : "Trimmed"
stop21 : "Ruled"
stop22 : "Revolved"
stop23 : "Letters"
stop24 : "Swept 2D"
stop25 : "Swept 3D"
stop26 : "Coons"
stop27 : "Lofted"
stop29 : "NONE"
stop30 : "NONE"
stop31 : "NONE"
stop32 : "NONE"
stop33 : "NONE"
stop34 : "NONE"
stop35 : "NONE"
stop36 : "NONE"
stop37 : "NONE"
stop38 : "NONE"
stop39 : "Surface Finish Pencil"
stop40 : "Surface Finish Leftover"
stop41 : "Surface Finish Parallel Steep"
stop42 : "Surface Finish Shallow"
stop43 : "Surface Finish Scallop"
stop44 : "Surface Rough Plunge"
stop45 : "NONE"
stop46 : "NONE"
stop47 : "NONE"
stop48 : "NONE"
stop49 : "NONE"
sSurf_Op : ""
fstrsel stop00 tool_op$ sSurf_Op 50 -1
# Contour Type
sCont00 : "2D"
sCont01 : "3D"
sCont02 : "2D Chamfer"
sCont03 : "3D Chamfer"
sCont04 : "Ramp"
sCont05 : "Remachining"
sCont06 : "Oscillate"
sContOpType : ""
fstrsel sCont00 OpContType sContOpType 7 -1
# Pocket Type
sPock00 : "Standard"
sPock01 : "Facing"
sPock02 : "Island Facing"
sPock03 : "Remachining"
sPock04 : "Open"
sPockOpType : ""
fstrsel sPock00 OpPockType sPockOpType 5 -1
# Facing Type
sFace00 : "ZigZag"
sFace01 : ""
sFace02 : ""
sFace03 : "One Pass"
sFace04 : "One Way"
sFace05 : "Dynamic"
sFaceOpType : ""
fstrsel sFace00 OpFaceType sFaceOpType 6 -1
Postblocks:
pOperationInfo
sav_spc = spaces$
spaces$ = 0
#pCheckOpValues
"( *** Operation Basic Info *** )", e$
#"()", e$
#*opcode$, e$
#*tool_op$, e$
#"()", e$
# Contour Operations
if (opcode$ = 1 | opcode$ = 2) & tool_op$ = 1, pContourOp
# 2D HSM Operations
if opcode$ = 2 & tool_op$ = 134, pHSMOp_2D
# Drill Operations
if opcode$ = 3, pDrillOp
# Pocket Operations
if opcode$ = 4, pPocketOp
# Circmill Operations
if opcode$ = 2 & (tool_op$ = 18 | (tool_op$ > 99 & tool_op$ < 107)), pCircMillOp
# Facing Operations
if opcode$ = 19, pFacingOp
# Multisurface Operations
if (opcode$ = 13 | opcode$ = 14) & tool_op$ < 132, pMultiSurfOp
# HSM Multisurface Operations
if opcode$ = 13 & tool_op$ = 132, pHSMOp_3D
"( **************************** )", e$
spaces$ = sav_spc
pContourOp # Contour Operations
"( Operation Type: Contour - ", *sContOpType, " )", e$
"( DOC = ", *OpDepth, " )", e$
if OpDepthCuts & OpDepthCuts_D <> 0, "( Maximum Depth Cuts: ", *OpDepthCuts_D, " )", e$
if OpMultiPass, "( Multipass Cuts: ", *OpMultiPass_N, " Cuts by ", *OpMultiPass_SO, " )", e$
if OpStock_XY <> 0, "( Stock to leave on XY: ", *OpStock_XY, " )", e$
if OpStock_Z <> 0, "( Stock to leave on Z: ", *OpStock_Z, " )", e$
"( Cutter Compensation: ", *scomp_type, " )", e$
"( Compensation Side: ", *sOpCompSide, " )", e$
pHSMOp_2D # 2D HSM Operations
"( Operation Type: ", *sOpType_2D_HSM, " )", e$
if Op2D_HSM_Style = 0 | Op2D_HSM_Style = 3, "( Maximum Stepover: ", *OpHSMStepO_2, " )", e$
else, "( Maximum Stepover: ", *OpHSMStepO, " )", e$
#"( Cutter Compensation: ", *scomp_type, " )", e$
#"( Compensation Side: ", *sOpCompSide, " )", e$
#if OpHSMCutDir = no$, "( Cutting Direction: Climb )", e$
#if OpHSMCutDir = yes$, "( Cutting Direction: Conventional )", e$
pDrillOp # Drill Operations
"( Operation Type: ", *sDrlOp, " )", e$
"( Drilling Depth: ", *OpDepth, " )", e$
"( Number of Holes: ", *OpDrillPoints, " )", e$
if drl_sel_tos$ < 0,
[if mprint("Drilling R plane below Top of Stock!!!", 2) = 2, exitpost$]
pPocketOp # Pocket Operations
"( Operation Type: Pocket - ", *sPockOpType, " )", e$
"( Rough Stepover: ", *OpPockStepO, ", ", *OpPockStepO_P, " )", e$
if OpPockCutDir = yes$, "( Cutting Direction: Climb )", e$
if OpPockCutDir = no$, "( Cutting Direction: Conventional )", e$
pCircMillOp # Circmill Operations
if tool_op$ = 18, "( Operation Type: Circle Mill )", e$
if tool_op$ = 100, "( Operation Type: Threadmill )", e$
if tool_op$ = 105, "( Operation Type: Slot Milling )", e$
if tool_op$ = 106, "( Operation Type: Helix Bore )", e$
if tool_op$ <> 100, "( DOC = ", *OpDepth, " )", e$
else,
"( Thread Type: ", [if OpThrdType = 0, "Right", else, "Left"], [if OpThrdSide = 0, " - ID", else, " - OD"], " Thread )", e$
"( Thread Depth = ", *OpThrdDpth, " )", e$
"( Thread Diameter = ", *OpThrdDia, " )", e$
"( Thread Pitch = ", *OpThrdPitch, " )", e$
if OpStock_Z <> 0 & opcode$ <> 19, "( Stock to leave on Z: ", *OpStock_Z, " )", e$
if tool_op$ <> 100, "( Compensation Side: ", *sOpCompSide, " )", e$
pFacingOp # Facing Operations
"( Operation Type: Facing - ", *sFaceOpType, " )", e$
if OpStock_F <> 0, "( Stock to leave on Face: ", *OpStock_F, " )", e$
pMultiSurfOp # Multisurface Operations
if tool_op$ < 50, "( Operation Type: ", *sSurf_Op, " )", e$
if Op3DStep_O <> 0,
"( Maximum Stepover: ", *Op3DStep_O, " )", e$
Op3DStep_O = 0
# Radial Rough/Finish
if tool_op$ = 6 | tool_op$ = 12,
Op3DRadStep = Op3DRadStep / deg2rad$
"( Radial Angle Step: ", *Op3DRadStep, " )", e$
# Flowline Rough/Finish
if tool_op$ = 8 | tool_op$ = 14,
if Op3DFlowTyp, "( Stepover Distance: ", *Op3DFlow_AD, " )", e$
else, "( Scallop Height: ", *Op3DFlow_SH, " )", e$
# Contour Rough/Finish
if tool_op$ = 9 | tool_op$ = 15,
if Op3DContFlat > 1, "( Stepover on Flat areas: ", *Op3DContFlat_SO, " )", e$
"( Maximum Stepdown: ", *Op3DStep_D, " )", e$
# Pocket Rough
if tool_op$ = 10, "( Stepover Distance: ", *OpPockStepO, ", ", *OpPockStepO_P, " )", e$
# Pencil Finish
if tool_op$ = 39,
if Op3DPencil = 0, "( Only one pencil pass! )", e$
if Op3DPencil = 1, "( Number of total passes: ", *Op3DPen_P, " )", e$
if Op3DPencil = 2, "( Stepover Distance: ", *Op3DPen_SO, " )", e$
# Restmill Rough
if tool_op$ = 107,
"( Operation Type: Surface Rough Restmill )", e$
"( Stepover Distance: ", *Op3DRest_SO, " )", e$
# Blend Finish
if tool_op$ = 109,
"( Operation Type: Surface Finish Blend )", e$
"( Stepover Distance: ", *Op3DBlend_SO, " )", e$
if opcode$ = 14 & tool_op$ <> 9, "( Maximum Stepdown: ", *Op3DStep_D, " )", e$
if OpStock_XY <> 0, "( Stock to leave on Drive: ", *OpStock_XY, " )", e$
if OpStock_C <> 0, "( Stock to leave on Check: ", *OpStock_C, " )", e$
pHSMOp_3D # HSM Multisurface Operations
"( Operation Type: ", *sOpType_3D_HSM, " )", e$
if Op3D_HSM_Style < 2 | Op3D_HSM_Style = 4, "( Maximum Stepover: ", *Op3DHSMStepO, " )", e$
if Op3D_HSM_Style = 3 | Op3D_HSM_Style = 5 | (Op3D_HSM_Style > 8 & Op3D_HSM_Style < 15), "( Maximum Stepover: ", *Op3DHSMStepO_2, " )", e$
# HSM Pencil
if Op3D_HSM_Style = 6,
"( Maximum 3D Stepover: ", *Op3DHSMStepO_2, " )", e$
# HSM Hybrid
if Op3D_HSM_Style = 7,
"( Maximum Z Stepdown: ", *Op3DHSMStep_D, " )", e$
if OpStock_Wall <> 0, "( Stock to leave on Wall: ", *OpStock_Wall, " )", e$
if OpStock_Floor <> 0, "( Stock to leave on Floor: ", *OpStock_Floor, " )", e$
if OpStock_HSM_C <> 0, "( Stock to leave on Check: ", *OpStock_HSM_C, " )", e$
And...:
pparameter$	 #Read operation parameters
if prmcode$ = 10029, OpDepth = rpar(sparameter$, 1) # Operation full depth
 if prmcode$ = 15083, OpDrillPoints = rpar(sparameter$, 1) # Number of Drill Points
 if prmcode$ = 10010, OpStock_XY = rpar(sparameter$, 1)	 # OP stock on XY or drive surfaces
 if prmcode$ = 10068, OpStock_Z = rpar(sparameter$, 1) # OP stock on Z
 if prmcode$ = 10227, OpStock_C = rpar(sparameter$, 1) # Surface OP stock on check surface
 if prmcode$ = 12068, OpStock_F = rpar(sparameter$, 1) # Facing OP stock on face
 if prmcode$ = 12665, OpStock_Wall = rpar(sparameter$, 1) # OP stock on 3D HSM Wall
 if prmcode$ = 12666, OpStock_Floor = rpar(sparameter$, 1) # OP stock on 3D HSM Floor
 if prmcode$ = 12594, OpStock_HSM_C = rpar(sparameter$, 1) # OP stock on 3D HSM Check
 if prmcode$ = 15346, comp_type = rpar(sparameter$, 1) #Cutter compensation type - 0=computer, 1=control, 2=wear, 3=reverse wear, 4=off
 if prmcode$ = 15347, OpCompSide = rpar(sparameter$, 1) # OP Cutting Side
 if prmcode$ = 12713, Op2D_HSM_Style = rpar(sparameter$, 1) # 2D HSM OP Type
 if prmcode$ = 12628, Op3D_HSM_Style = rpar(sparameter$, 1) # 3D HSM OP Type
 if prmcode$ = 12014, OpContType = rpar(sparameter$, 1) # 2D Contour OP Type
 if prmcode$ = 10450, OpPockType = rpar(sparameter$, 1) # 2D Pocket OP Type
 if prmcode$ = 15564, OpPockCutDir = rpar(sparameter$, 1) # 2D Pocket OP Cutting direction
 if prmcode$ = 12051, OpFaceType = rpar(sparameter$, 1) # 2D Facing OP Type
 if prmcode$ = 10302, OpPockStepO = rpar(sparameter$, 1) # Pocket OP StepOver in mm
 if prmcode$ = 10414, OpPockStepO_P = rpar(sparameter$, 1) # Pocket OP StepOver in percentage
 if prmcode$ = 15211, OpDepthCuts = rpar(sparameter$, 1) # 2D Operations - Depth cuts ON/OFF
 if prmcode$ = 10065, OpDepthCuts_D = rpar(sparameter$, 1) # 2D Operations - Depth cuts rough value
 if prmcode$ = 15214, OpMultiPass = rpar(sparameter$, 1) # 2D Operations - Multipass cuts ON/OFF
 if prmcode$ = 15561, OpMultiPass_SO = rpar(sparameter$, 1) # 2D Operations - Multipass cuts step
 if prmcode$ = 15560, OpMultiPass_N = rpar(sparameter$, 1) # 2D Operations - Multipass number of passes
 if prmcode$ = 12956, OpHSMCutDir = rpar(sparameter$, 1) # HSM OP Cutting direction
 if prmcode$ = 12719, OpHSMStepO = rpar(sparameter$, 1) # 2D HSM Stepover
 if prmcode$ = 12974, OpHSMStepO_2 = rpar(sparameter$, 1) # 2D HSM Stepover - 2
 if prmcode$ = 12192, OpThrdDpth = rpar(sparameter$, 1) # Thread Mill OP Depth
 if prmcode$ = 12203, OpThrdDia = rpar(sparameter$, 1) # Thread Mill OP Diameter
 if prmcode$ = 12194, OpThrdPitch = rpar(sparameter$, 1) # Thread Mill OP Pitch
 if prmcode$ = 12204, OpThrdType = rpar(sparameter$, 1) # Thread mill type, RH/LH
 if prmcode$ = 12202, OpThrdSide = rpar(sparameter$, 1) # Thread mill side, ID/OD
 if prmcode$ = 10205, Op3DStep_O = rpar(sparameter$, 1) # Multisurface OP Stepover
 if prmcode$ = 12411, Op3DStep_D = rpar(sparameter$, 1) # Multisurface OP Stepdown
 if prmcode$ = 12103, Op3DRadStep = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Radial Step
 if prmcode$ = 12117, Op3DFlowTyp = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Flowline Type (Across)
 if prmcode$ = 12118, Op3DFlow_AD = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Flowline Across distance
 if prmcode$ = 12119, Op3DFlow_SH = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Flowline Scallop height
 if prmcode$ = 15505, Op3DContFlat = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Contour use Flat
 if prmcode$ = 15506, Op3DContFlat_SO = rpar(sparameter$, 1) # Multisurface Rough/Finish OP Contour Stepover on Flats
 if prmcode$ = 12124, Op3DRest_SO = rpar(sparameter$, 1) # Multisurface Rough Rest OP Stepover
 if prmcode$ = 12449, Op3DPencil = rpar(sparameter$, 1) # Multisurface Finsih Pencil OP StepType
 if prmcode$ = 12424, Op3DPen_P = rpar(sparameter$, 1) # Multisurface Finsih Pencil OP Passes total number
 if prmcode$ = 12054, Op3DPen_SO = rpar(sparameter$, 1) # Multisurface Finsih Pencil OP Stepover
 if prmcode$ = 12302, Op3DBlend_SO = rpar(sparameter$, 1) # Multisurface Finsih Blend OP Stepover
 if prmcode$ = 12597, Op3DHSMStepO = rpar(sparameter$, 1) # 3D HSM Stepover
 if prmcode$ = 12579, Op3DHSMStepO_2 = rpar(sparameter$, 1) # 3D HSM Stepover
 if prmcode$ = 12578, Op3DHSMStep_D = rpar(sparameter$, 1) # 3D HSM Stepdown
Finally need to drop the "pOperationInfo" postblock call into the "ptlchg$" and "ptlchg0$" postblocks and let it run. (roughly...) :)
Peter good job copied and pasted into my archives of stuff. Thanks for sharing that.
Thank you Ron! These kind words are pushing me forward... ;)
And you're welcome!
Just a note, I went through on this, and I see, few things are still missing from this library, but when I decided to implement this on this way, then I focused on the new Dynamic path mostly.
But I think what I shared here, it can be a good starting point and easy to extend or improve or add other stuffs toolpaths.
:cheers:
