I've been working on a custom drill cycle for my post and I've almost got it but I can't get it to input the feed with the value I have given it in my custom drill parameters.
I can get a post of this:
T21 M06 (.385 GO DRILL KENNAMETAL# 4149277)
M11 (UNLOCK)
G90 G80 G49 G40 G17 G00 G54 B0. X0. Y.818 S2650 M03
M10 (LOCK)
G43 H21 Z8.3 M88
(DRILL PISTON BORE)
G94
G01 Z0. F0. <---------- custom line
Z7. F25. <---------- custom line
Z8.3 F0. <---------- custom line
M89
G91 G28 Z0. M05
With this in my post:
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
#if drillcyc = 8, pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,
# prdrlout, dwell, *feed, strcantext, e$
if drillcyc$ = 8,
sub_prg_call = peck1$
pcan1, pbld, n$, *sg00, *sgabsinc, pfxout, pfyout, pfcout, pindexdrl, strcantext, e$
pbld, n$, "M98", *sub_prg_call, e$
if drillcyc$ = 9,
refht_z = refht$
pdrlcommonb
pcan1, pbld, n$, *sg01, *drl_prm1, *drl_prm2, e$
pbld, n$, pfzout, *feed, e$
pbld, n$, *refht_z, *drl_prm3, e$
pcom_movea
else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, pindexdrl, e$
pcom_movea
pdrlcst_2$ #Custom drill cycles 8 - 19, additional points (user option)
pdrlcommonb
#if drillcyc = 8, pcan1, pbld, n$, pdrlxy, pzout, pcout, pindexdrl, prdrlout, dwell,
# feed, strcantext, e$
if drillcyc$ = 8,
if drillcyc$ = 9,
refht_z = refht$
pdrlcommonb
pcom_movea
pcom_movea
Or I can get this:
M11 (UNLOCK)
M10 (LOCK)
G43 H21 Z8.3 M88
(DRILL PISTON BORE)
G94
G01 drl_prm1$ 8. drl_prm2$ 10.
Z7. F25.
Z8.3 drl_prm3$ 60.
M89
G91 G28 Z0. M05
pdrlcommonb
if drillcyc$ = 8,
if drillcyc$ = 9,
refht_z = refht$
pdrlcommonb
pcan1, pbld, n$, *sg01, *drl_prm1$, *drl_prm2$, e$
pbld, n$, *refht_z, *drl_prm3$, e$
pcom_movea
pcom_movea
pdrlcommonb
if drillcyc$ = 8,
if drillcyc$ = 9,
refht_z = refht$
pdrlcommonb
pcom_movea
I have my custom drill parameters set as follows:
# Custom drilling cycle 9, carbide drill drilling cycle
fmt "Z" 2 drl_prm1 #starting Z depth
fmt "F" 2 drl_prm2 #starting feed rate
fmt "F" 2 drl_prm3 #retract feed rate
fmt "Z" 2 refht_z #for Z retract height output
Seems like I can get it to either post the F or Z code I have assigned or post the numbers I have for my custom parameters in Mastercam.
What am I doing wrong??
That did it.
Thank you very much for your help.
The only other thing I added was:
if drillcyc$ = 9,
refht_z = refht$
drl_prm1 = drl_prm1$
drl_prm2 = drl_prm2$
drl_prm3 = drl_prm3$
pdrlcommonb
pcan1, pdrlxy, e$ <---------------------------------------added this line so it will move to next hole location
pcom_movea
Thanks again.
Just an observation, when I create a variable, I try not to use a name that could be confused with another variable. The naming rules are basic, and there is a lot of latitude to be creative. So, instead of drl_prm1, you could have defined InitialZDepth as a variable name. That makes it much easier to track what it is used for when you don't remember what you did with drl_prm1... :cheers:
So when I create a variable for custom drilling cycle can I use more than the ten different variables that the custom drill parameters has?
That is not what he saying. He is saying you can define the variable you use in a different way. You can get real trick with the 10 and have millions of possibilities.
if drl_prm1 > 10,
if drl_prm1 > 1000, then inside of the block you break it down to what you want for a group of numbers. Not sure why 10 is not enough, but yes the sky is the limits with any variable on how to use it just up the post builder to decide how complex they want to make it.
What I intended to illustrate was that I tend to be very descriptive with the names that I assign to variables. In your first post, you defined variables like this:
Had this been my post I would define variables with names like this:
fmt "Z" 2 InitialZDepth           #starting Z depth
fmt "F" 2 InitialFeedrate        #starting feed rate
fmt "F" 2 RetractFeedrate    #retract feed rate
fmt "Z" 2 RetractZHeight	  #for Z retract height output
This type of naming makes it easier to recognize what the variable is being used for. Especially when you are making more edits a year from now. I actually have some very long variable names in my post... like sErrorMessageWarningToolDcompDoesNotMatchHcomp (this is easy to recognize what it is for)
What Crazy^Millman refers to in his post is useful if you need to pass more information to the NCI than you have system variables. (The variables that end with $).
HTH :cheers:
+1! ;)
We should make a championship here! "See who's have the longest!!!"
:laughing::smoke::lol:
I guess the part that was confusing me was I thought if it wasn't named drl_prm1 etc, then the post would not know where to look in Mastercam to get the custom drill parameters input while programming. Where I was going with the only having ten variables was if drl_prm1 was for a "Z" value then any other custom parameters I would use the parameter 1 in mastercam would always have to be a "Z" value, but I guess that is not the case if you can create your own variables?
Any variable (including system variables) can be formatted, have address assigned (Z, Y, Q, etc.), whenever you like.  As often as you like.
In your case, you need to understand....  drl_prm1 is not the same variable as drl_prm1$.  You created drl_prm1.  It is a user defined variable.  So, you can name it anything that you want.  And format it however you want.
