post Processor Tiger 5
hello, I'm french and I do not speak good English.
I use a post processor is not adpater to my CNC (tiger4)
I am trying to change the post processor for CNC "SHARNOA" (tiger5).
I still use MASTERCAM V9, I managed to make some changes, but I'm stuck on actuelement the tool "G41 / G42) correction.
Actually psot processor generates a gcode like this:
G41 Y-37. F300
G42 X-8. F200
but for my CNC I would need a code like this:
G41
G-1 Y-37. F300
G42
G 1-X-8. F200
Here is a link where I left on the post processor I use.
Thank you for your help
PS: if a person possesses the post processor for 5 tiger I'd be happy.
It's a relatively easy modification, but I can't see the post you linked. It leads to a page that's all in French and It seems as if it want's me to download something, and that isn't happening. So I'll just use a standard post as an example.
Inside your post you'll find a table of strings that define your G codes. It will look like this:
# Motion G code selection
sg00    : "G0"       #Rapid
sg01    : "G1"       #Linear feed
sg02    : "G2"       #Circular interpolation CW
sg03    : "G3"       #Circular interpolation CCW
sg04    : "G4"       #Dwell
sgcode  : ""         #Target string
All you have to do is modify the code in between the quotes. So you will want to change yours to look like this:
sg01    : "G-1"       #Linear feed
Change it for every g code you need modified.
To break up the cutter comp line, you need to find a block called plinout
It should look like this:
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n$, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, feed, strcantext, scoolant, e$
Modify it to look like this:
     pccdia, e$
And if you need the g code to output on every line, change the ` to an *  in the prapidout, plinout, and pcirout post blocks.
ALWAYS SAVE A COPY OF YOUR POST BEFORE YOU MAKE ANY CHANGES
Since is a Sharnoa speciality, I would do this:
Define this postblock
pApproach	# Sharnoa non-tangent approach
		if cc_pos$ > zero & cstart$ = two, "G-1"
Modify this postblocks:
plinm   # Linear line movement - at feedrate
	pcan
        pcan1, n, sccomp, sgcode, pApproach, x, y, z, pfr, strcantext, e
        pcan2
pcirm   # Circular interpolation
	pcan
        pcan1, n,  sgplane, sccomp, sgcode, pApproach, x, y, z, parctyp, pfr, strcantext, e
	pcan2
# Post Name           : MPTIGER4
# Product             : MILL
# Machine Name        : SHARNOA TIGER 4
# Control Name        : TIGER 4
# Description         : SHARNOA TIGER 4 MILL POST
# 4-axis/Axis subs.   : NO
# 5-axis              : NO
# Subprograms      : NO
# Executable          : MP v9.10
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
#| REVISION LOG: |
# Programmers Note:
# CNC  01/12/01 - Updated for Mill Version 8.1
# CNC  01/09/02 - Initial post update for V9.0
# CNC  02/04/03 - Initial post update for V9.1
#| FEATURES:     |
# Users Note:
# Following Misc_Reals & Misc_Integers are used:
# mi1 - Work coordinate system
#        0 = Reference return is generated and G92 with the
#            X, Y and Z home positions at file head.
#        1 thru 3 = Reference return is generated and G92 with the
#                   X, Y and Z home positions at each tool.
#        4 thru 9 = The WCS of G54 thru G59 respectively at each tool.
#Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Stop = output the "M00" stop code
#    2 = Ostop =  output the "M01" optional stop code
# Options / Usage:
# It is recommended to start and end cutter compensation on a linear move.
# Rotary axis assumes a "Z" plunge at feed into part, position of the
# substituted axis at absolute zero position and the retraction from path
# by the post call to the G28 machine Z home position.
# END_HEADER$
# DEBUG/PROGRAM SWITCHES, debugging and program switches
fastmode  : yes  # Optimize processing time (set to no for debugging)
bug1   : 1       # 0=No display, 1=Generic list box, 2=Editor
bug2   : 0       # Append postline labels, non-zero is column position?
bug3   : 0       # Append whatline no. to each NC line?
bug4   : 0       # Append NCI line no. to each NC line?
whatno : yes     # Do not perform whatline branches? (leave as yes)
skp_lead_flgs : 1# Do NOT use v9 style contour flags
get_1004   : 1   # Find gcode 1004 with getnextop?
rpd_typ_v7 : 1   # Use Version 7 style contour flags?
strtool_v7 : 2   # Use Version 7 toolname?
stagetool : 0    # 0 = Do not pre-stage tools, 1 = Stage tools
use_gear  : no   # Set to yes to output gear range codes
# FORMAT STATEMENTS - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
fs  1  0.4      #Decimal, absolute, 4 place
fs  2  0.4d     #Decimal, delta
fs  3  1 0      #Integer, not leading
fs  4  2 0l     #Integer, two leading
fs  5  3 0l     #Integer, three leading
fs  6  4 0l     #Integer, four leading
fs  7  0.1      #Decimal, absolute, 1 place
fs  8  0.2      #Decimal, absolute, 2 place
fs  9  0.3      #Decimal, absolute, 3 place
fs  10 0 4t     #No decimal, absolute, four trailing
fs  11 0.4t     #Decimal, absolute, four trailing
# FORMAT ASSIGNMENTS
# Axis output formats - Linear
fmt  X 1 x        # X axis position
fmt  Y 1 y        # Y axis position
fmt  Z 1 z        # Z axis position
fmt  X 1 xr       # X rapid position from tool change
fmt  Y 1 yr       # Y rapid position from tool change
fmt  Z 1 zr       # Z rapid position from tool change
fmt  X 1 xh       # X home position
fmt  Y 1 yh       # Y home position
fmt  Z 1 zh       # Z home position
# Axis output formats - Circular
fmt  I 2 i         # Arc center description in X
fmt  J 2 j         # Arc center description in Y
fmt  K 2 k         # Arc center description in Z
fmt  R 1 arcrad    # Arc Radius
fmt  R- 1 arcradm  # Arc Radius over 180 degree sweep
# Axis output formats - Rotary substitution
fmt  A 9 xangle    # Linear to rotary calculation of X
fmt  B 9 yangle    # Linear to rotary calculation of Y
# Program & Sequence number format
fmt  O 6 progno    # Program number
fmt  N 3 n         # Sequence nos.
# Tool format
fmt  T 3 t         # Tool No
fmt  T 3 first_tool# First Tool Used (bldnxtool: yes)
fmt  T 3 next_tool # Next Tool Used  (bldnxtool: yes)
fmt  D 3 tloffno   # Diameter Offset No
fmt  H 3 tlngno    # Length Offset No
fmt  "OUTIL:" 4 tnote        # Note format
fmt  "" 4 toffnote    # Note format
fmt  "" 4 tlngnote   # Note format
fmt  "DIAMETRE:" 11 tldia           # Note format
# Spindle Speeds & Feedrate output formats
fmt  S 6 speed      # Spindle Speed
fmt  F 8 fr         # Feedrate
fmt  F 7 frdeg      # Feedrate for rotary
fmt  M 3 gear       # Gear range
# Drill variable formats
fmt  G 3 drillref   # Initial / Reference Toggle (G98/G99)
fmt  P 10 dwell     # Dwell
fmt  Z 1 initht     # Initial Height
fmt  P 1 refht      # Reference Height
fmt  Q 1 depth      # Depth
fmt  E 1 peck1      # First peck increment (positive)   #JQ was Q 10
fmt    1 peck2      # Second or last peck (positive)
fmt    1 peckclr    # Safety distance
fmt    1 retr       # Retract height
fmt  F 8 frplunge   # Plunge feedrate in drill cycles
# Miscellaneous output formats
fmt  M 5 ssrange    # Spindle Speed Range
fmt  C 4 coolant    # Coolant
fmt  M 4 cantext    #canned text
# INITIALIZE - initialize system variables and define user variables
arcoutput : 1      # 0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
breakarcs : 0      #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arctype   : 2      # Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0    # Allow full circle output? 0=no, 1=yes
helix_arc   : 0    # Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck  : 1      # Check for small arcs, convert to linear
ltol      : .002   # Length tolerance for arccheck
bldnxtool : yes    # Build next tool table
omitseq   : no     # Omit sequence numbers?
progname  : 1      # Use uppercase for program name (sprogname)
scalex    : 1.0    # Scaling of .NCI at input - x,y,z,i,j,k
scaley    : 1.0    # Scaling of .NCI at input - x,y,z,i,j,k
scalez    : 1.0    # Scaling of .NCI at input - x,y,z,i,j,k
seqmax    : 9999   # Max. sequence number
skipmotest: no     # Skip motion test in linear
spaces    : 1      # No. of spaces to add between fields
tooltable : 1      # Read for tool table and pwrtt
absswp    : 0      # Absolute sweep
maxfrdeg  : 999    # Limit for feed in deg/min
absinc    : 0      # Absolute/Incremental toggle for modality
tcnt      : 0      # Count the number of tool changes
adelta    : 0      # Calculation for deg/min
ldelta    : 0      # Calculation for deg/min
zdelta    : 0      # Calculation for deg/min
alzdelta  : 0      # Calculation for deg/min
frdelta   : 0      # Calculation for deg/min
frdegcalc : 0      # Calculation for deg/min
circum    : 0      # Calculation for deg/min
rotstrt   : 1      # Flag for first rotary position
#Cantext string definitions (spaces must be padded here)
sm00        "M00"
sm01        "M01"
strm "M"
strtextno
strcantext
sblank
# FORMULAS - global formulas
ssrange   = mi3              # Gear Range Select
speed     = abs ( ss )       # Absolute spindle speed
arcradm   = arcrad           # Negative arcrad
spdlsel   = fsg3(ss)         # Spindle on selector based on pos. or neg. ss
# CANNED CYCLES - select long or short code
usecandrill : yes  # Use canned cycle for drill
usecanpeck  : yes  # Use canned cycle for Peck
usecanchip  : yes  # Use canned cycle for Chip Break
usecantap   : yes  # Use canned cycle for Tap
usecanbore1 : yes  # Use canned cycle for Bore1
usecanbore2 : yes  # Use canned cycle for Bore2
usecanmisc1 : yes  # Use canned cycle for Misc1
usecanmisc2 : yes  # Use canned cycle for Misc2
# Lookup table definitions - for math functions FLOOK and FRANGE
flktbl    1     3  # Lookup table definitions - table no. - no. entries
         40  1000  # Low gear range
         41  2500  # Med gear range
         42  5000  # Hi gear range
# Strings - String labels must start with 's' - they are not pre-assigned
#Select operation note
sop00   NULL...........          # String definition
sop01   CONTOURNAGE....          #    "       "
sop02   CONTOURNAGE....          #    "       "
sop03   FORET PERCAGE..          #    "       "
sop04   POCHE..........          #    "       "
sop05   RULED..........          #    "       "
sop06   2D-SWEPT.......          #    "       "
sop07   3D-SWEPT.......          #    "       "
sop08   REVOLVED.......          #    "       "
sop09   LOFT...........          #    "       "
sop10   COONS..........          #    "       "
sop11   FILLET.........          #    "       "
sop12   FLOWLINE.......          #    "       "
sop13   M.FINISH.......          #    "       "
sop14   M.ROUGH........          #    "       "
sop15   POINT..........          #    "       "
sop16   DRILL5AX.......          #    "       "
sop17   CURVE5AX.......          #    "       "
sop18   OP18...........          #    "       "
sop19   OP19...........          #    "       "
sop20   OP20...........          #    "       "
sopnote                  # Target string
fstrsel  sop00 opcode sopnote
# Select motion G code
sg00    G0    # Linear movement at rapid feedrate
sg01    G1    # Linear movement at feedrate
sg02    G2    # Circular interpolation CW
sg03    G3    # Circular interpolation CCW
sgcode        # Target string
fstrsel  sg00 gcode sgcode
# Select incremental or absolute G code
sg90    G90   # Absolute G code
sg91    G91   # Incremental G code
sgabsinc      # Target string
fstrsel  sg90 absinc sgabsinc
# Select spindle start
sm04    M4    # Spindle reverse
sm05    M5    # Spindle off
sm03    M3    # Spindle forward
spdlon        # Target string
fstrsel  sm04 spdlsel spdlon
# Cutter compensation code
scc0    ""    # Cutter compensation state not changed
sg40    G40   # Cancel cutter compensation
sg41    "G41" # Cutter compensation left ###################
sg42    "G42" # Cutter compensation right ##################
sg140   G40   # Last linear move cancel cutter comp (see note)
              # Note: to cancel comp after last move, remove G40 string
              # with sg140 and remove "#" at the postline call "pcancelcc"
sccomp        # Target string
fstrsel  scc0 ccomp sccomp
# Select work plane G code
sg17    G17   # XY plane code
sg19    G19   # XZ plane code
sg18    G18   # YZ plane code
sgplane       # Target string
fstrsel  sg17 plane sgplane
# Work coordinate system
sg50    G92   # Work coordinate system G code
sg51    G92   #  "       "        "    "  "
sg52    G92   #  "       "        "    "  "
sg53    G92   #  "       "        "    "  "
sg54    G54   #  "       "        "    "  "
sg55    G55   #  "       "        "    "  "
sg56    G56   #  "       "        "    "  "
sg57    G57   #  "       "        "    "  "
sg58    G58   #  "       "        "    "  "
sg59    G59   #  "       "        "    "  "
sgwcs         # Target string
fstrsel  sg50 mi1 sgwcs
# Canned drill cycle string select
sg81     G81  #  drill      - sans temporisation
sg81d    G82  #  drill      - avec temporisation
sg83     G81  #  peck drill - sans temporisation       #JQ made G81 - was G83
sg83d    G83  #  peck drill - avec temporisation
sg73     G73  #  chip break - sans temporisation
sg73d    G73  #  chip break - avec temporisation
sg84     G84  #  tap        - sans temporisation
sg84d    G74  #  tap        - avec temporisation  (selects left hand)
sg85     G85  #  bore #1    - sans temporisation
sg85d    G89  #  bore #1    - avec temporisation
sg86     G86  #  bore #2    - sans temporisation
sg86d    G86  #  bore #2    - avec temporisation
sgm1     G81  #  misc #1    - sans temporisation
sgm1d    G82  #  misc #1    - avec temporisation
sgm2     G81  #  misc #2    - sans temporisation
sgm2d    G82  #  misc #2    - avec temporisation
sgdrill       #  Target string
drlgsel = drillcyc * 2 + fsg2 ( dwell )  # 16 possible combinations:
                                     #   drillcyc = 0..7
                                     #   dwell    = 0 or non-zero (2 states)
fstrsel  sg81 drlgsel sgdrill
# Generate 'sgear' string
sgear0      M**   # auto gear range
sgear1      M41   # Low gear range
sgear2      M42   # Med gear range
sgear3      M43   # High gear range - selected in parameters by mi3
sgear
fstrsel sgear0 gear sgear
# POSTLINES, USER-DEFINED -  Postline labels start with 'p'.
# End a line with ',' to continue on the next line.
# End a line with ', e' to generate carriage return and linefeed.
# Program general output control, user defined
pinit      # Initialize Vars
             prv_fr = 999.999
             prv_frdeg = 999.999
             prv_frplunge = 999.999
             linarc = 0
             rotstrt = 1
pcomment   # Manual Entry - COMMENTS (on a block by itself) 1005,1006
             "/", scomm
pabs       # Absolute G code output
             absinc = 0
             sgabsinc
pinc       # Incremental G code output
             absinc = 1
             sgabsinc
pcooloff   # Coolant off "M" code output
             if prv_coolant > 0, "M9"
             if prv_coolant > 0, prv_coolant = 0
pcoolon    # Coolant off "M" code output
             if coolant = 1, "M7"     # Flood
             if coolant = 2, "M7"     # Mist
             if coolant = 3, "M7"     # Tool
             if prv_coolant > 0, !coolant
pcoolnl    # Coolant off "M" code output
             if coolant = 0, "M9"     # Off
pfr        # Feedrate W/O Negative Feedrates
             if fr > 0, fr
# Canned Text
pcan            #Canned text - before output call
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 0, pcant_1
        if cant_pos2 = 0, pcant_2
        if cant_pos3 = 0, pcant_3
        if cant_pos4 = 0, pcant_4
        if cant_pos5 = 0, pcant_5
        if cant_pos6 = 0, pcant_6
        if cant_pos7 = 0, pcant_7
        if cant_pos8 = 0, pcant_8
        if cant_pos9 = 0, pcant_9
        if cant_pos10 = 0, pcant_10
        n, strcantext, e
        strcantext = sblank
pcan1           #Canned text - with move
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 1, pcant_1
        if cant_pos2 = 1, pcant_2
        if cant_pos3 = 1, pcant_3
        if cant_pos4 = 1, pcant_4
        if cant_pos5 = 1, pcant_5
        if cant_pos6 = 1, pcant_6
        if cant_pos7 = 1, pcant_7
        if cant_pos8 = 1, pcant_8
        if cant_pos9 = 1, pcant_9
        if cant_pos10 = 1, pcant_10
      if cstop, strcantext = strcantext + sm00
      if cgstop, strcantext = strcantext + sm01
      #Output of strcantext occurs at the end of the output line
pcan2           #Canned text - after output call
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 2, pcant_1
        if cant_pos2 = 2, pcant_2
        if cant_pos3 = 2, pcant_3
        if cant_pos4 = 2, pcant_4
        if cant_pos5 = 2, pcant_5
        if cant_pos6 = 2, pcant_6
        if cant_pos7 = 2, pcant_7
        if cant_pos8 = 2, pcant_8
        if cant_pos9 = 2, pcant_9
        if cant_pos10 = 2, pcant_10
        n, strcantext, e
        strcantext = sblank
pcant_1         #Canned text - output call
      cantext = cant_val1
      pcant_out
pcant_2         #Canned text - output call
      cantext = cant_val2
      pcant_out
pcant_3         #Canned text - output call
      cantext = cant_val3
      pcant_out
pcant_4         #Canned text - output call
      cantext = cant_val4
      pcant_out
pcant_5         #Canned text - output call
      cantext = cant_val5
      pcant_out
pcant_6         #Canned text - output call
      cantext = cant_val6
      pcant_out
pcant_7         #Canned text - output call
      cantext = cant_val7
      pcant_out
pcant_8         #Canned text - output call
      cantext = cant_val8
      pcant_out
pcant_9         #Canned text - output call
      cantext = cant_val9
      pcant_out
pcant_10        #Canned text - output call
      cantext = cant_val10
      pcant_out
pcant_out       #Canned text - build the string for output
      #Build the cantext string
      if cantext = 1, strcantext = strcantext + sm00
      if cantext = 2, strcantext = strcantext + sm01
      if cantext > 2,
        strtextno = no2str(cantext)
        strcantext = strcantext + strm + strtextno
# Work coordinate output, user defined
pg92_sof   # G92 coordinate setting at start
             "/", n, pinc, "G28", "Z0.", e
             "/", n, "G28", "X0.", "Y0.", e
             "/", n, *sgwcs, *xh, *yh, *zh, e
pg92_out   # G92 coordinate setting at tool change
             if gcode <> 1003, "/", n, *sgwcs, *xh, *yh, *zh, e
pg92_tst   # G92 coordinate test for output
             if mi1 > 0, pg92_out
pwcs       # G54+ coordinate setting
             if mi1 >= 4, *sgwcs
# Gear selection control, user defined
pgear      # Find spindle range
             gear = frange ( 1, speed )
             *gear
prange     # Find spindle range
             if use_gear = 1, pgear
# Cutter comp. output control, user defined
pccdia2    # Cutter Compensation2
             if ccomp <> 4, tloffno
pccdia     # Cutter Compensation
             if ccomp <> 0, pccdia2
# Axis substitution motion, user defined
pdrlxyrot  # Substitute Axis X/Y with Rotary axis w/ drilling
           xangle = xs
           yangle = ys
           if rotaxis = 0, x, y
           if rotaxis = 1, y, xangle
           if rotaxis = 2, x, yangle
pfrd       # Feedrate W/O Negative Feedrates (deg/min)
           if frdeg > maxfrdeg, frdeg = maxfrdeg
           if frdelta > .5, *frdeg           #Value to exceed to output frdeg
protaxis1a # Substitute Axis X/Y with Rotary axis
           if rotstrt = 0, pcan1, n, sgcode, y, z, *xangle, pfrd, strcantext, e
           if rotstrt = 1, n, xangle, e
           if rotstrt = 1, pcan1, n, sgcode, y, z, pfrd, strcantext, e
protaxis1  # Substitute Axis X/Y with Rotary axis
  pcan
           if gcode = 0, pcan1, n, sgcode, y, z, *xangle, strcantext, e
           if gcode = 1, protaxis1a
  pcan2
protaxis2a # Substitute Axis X/Y with Rotary axis
           if rotstrt = 0, pcan1, n, sgcode, x, z, *yangle, pfrd, strcantext, e
           if rotstrt = 1, n, yangle, e
           if rotstrt = 1, pcan1, n, sgcode, x, z, pfrd, strcantext, e
protaxis2  # Substitute Axis X/Y with Rotary axis
  pcan
           if gcode = 0, pcan1, n, sgcode, x, z, *yangle, strcantext, e
           if gcode = 1, protaxis2a
  pcan2
protaxis   # Substitute Axis X/Y with Rotary axis
           xangle = xs
           yangle = ys
           if rotstrt = 1, !fr
           if fr < 0, fr = prv_fr
           !fr
           if rotaxis = 1, ldelta = abs ( y - prv_y )
           if rotaxis = 2, ldelta = abs ( x - prv_x )
           zdelta = abs ( z - prv_z )
 if rotaxis = 1, adelta = ( ( abs ( xangle - prv_xangle ) ) / 360 ) * circum
 if rotaxis = 2, adelta = ( ( abs ( yangle - prv_yangle ) ) / 360 ) * circum
           alzdelta = sqrt ( adelta^2 + ldelta ^2 + zdelta^2 )
           frdegcalc =  fr * ( 360 / circum )
 if alzdelta <> 0, frdeg = ( adelta / alzdelta ) * frdegcalc
           if adelta = 0, frdeg = fr
           frdelta = abs ( frdeg - prv_frdeg )
           if rotaxis = 1, protaxis1
           if rotaxis = 2, protaxis2
           if gcode = 1, rotstrt = 0
           !x, !y, !z
protary    # Rotary Move
             if rotaxis = 1, xr = 0  #Force X to zero
             if rotaxis = 2, yr = 0  #Force Y to zero
             if rotaxis > 0, linarc = 1
             circum = rotdia * pi
# Axis linear/circular motion, user defined
parctyp2   # Arc output for R w/ sign over 180 degree sweep
             absswp = abs ( sweep )
             @absswp
             if absswp <= 180, *arcrad
             if absswp > 180, *arcradm
parctyp1   # Arc output for R w/ no sign
             *arcrad
parctyp0   # Arc output for IJK
             if plane = 0, *i, *j,  k
             if plane = 1,  i, *j, *k
             if plane = 2, *i,  j, *k
parctyp    # Select the arc output
             if arcoutput = 0 | full_arc_flg | arc_pitch, parctyp0
             else,
              if arcoutput = 1, parctyp1
              if arcoutput = 2, parctyp2
prapidm    # Linear line movement - at rapid feedrate
pcan
             pcan1, n, sgplane, sccomp, sgcode, x, y, z, strcantext, e
pcan2
               pcan
                        pcan2
               pcan
              pcan2
#plinm      # Linear line movement - at feedrate
# pcan
#             pcan1,n, sccomp, sgcode, x, y, z, pfr, strcantext, e
# pcan2
#pcirm      # Circular interpolation
# pcan
#             pcan1, n, sgplane, sccomp, sgcode, x, y, z, parctyp , pfr, strcantext, e
# pcan2
# Drilling, user defined
pdrillref  # Determine G98 or G99
             if initht <> refht, drillref = 98
             if initht = refht, drillref = 99
pdwell     # Determine whether to output dwell
             if dwell <> 0, *dwell
ptlchg0dr3 # Null tool change for drilling
             gcode = 0
             if zr < prv_zr, n, sgcode, *xr, *yr, e
             n, sgcode, *zr, e
ptlchg0dr2 # Null tool change for drilling
             if zr <> prv_zr, ptlchg0dr3
ptlchg0drl # Null tool change for drilling
             if prv_opcode = 3, ptlchg0dr2
# POSTLINES, PRE-DEFINED - Postline names are pre-assigned.
# Lines do not need to end with ', e' for carriage return and linefeed.
pheader    # File header
             " ", e
             n, "/ NOM DU PROGRAMME -", sprogname
             n, "/ DATE: ", date, " HEURE:", time
psof0      # Start of file for tool zero
             psof
psof       # Start of file for non-zero tool number
             pinit
             !opcode, !coolant
             if tcnt = 1, stagetool = 1  #####################
             ##*progno     ###################################
             comment
             if mi1 <= 3, #pg92_sof #########################
             n, "G99"       #################################
             n, "/----------------------------------------------------"
             n, "G99"########################################
             if stagetool = 0, n, "G40", *t, "M6"
             if stagetool = 1, n, "G40", *next_tool, "M6"
             protary
             n, "G4", *speed, *spdlon
pcan
             pcan1, n, "G0", pabs, *xr, *yr, strcantext, e
             n, *zr, pcoolon
pcan2
ptlchg0    # Null tool change
             if opcode = 3, ptlchg0drl
             if prv_speed <> speed, n, speed
             if coolant <> prv_coolant, n, pcoolnl
             !opcode, !coolant
    pcan
ptlchg     # Tool change
             pinit
             !opcode
             #n, "/POSITION CHANGEMENT OUTIL"
             #n, "G0", *xh, *yh, *zh
             n, "G40 T0"        #JQ
             n, "/ARRET ARROSAGE"
             n, "M9"
             n, "/ARRET BROCHE"
             n, "M5"
             n, "/ARRET MACHINE
             n, "M00"
             n, "/"
             if mi1 <= 3, pg92_tst
             comment
             protary
pcan
pcan2
             n, *zr, pcoolon
             !coolant
peof0      # End of file for tool zero
             peof
peof       # End of file for non-zero tool
              n, "G40 T0"
              n, "M9"
              n, "/ARRET BROCHE"
              n, "M5"
              n, "/FIN DE PROGRAMME"
              n, "M2"
# Axis motion
prot0      # Toolplane postline - Custom post required
prot       # Toolplane postline - Custom post required
prapid     # Linear line movement - at rapid feedrate
             if rotaxis <> 0, protaxis
             if rotaxis = 0, prapidm
pzrapid    # Linear movement in Z axis only - at rapid feedrate
             n, sgcode, z
plin       # Linear line movement - at feedrate
             if rotaxis = 0, plinm
pz         # Linear movement in Z axis only - at feedrate
             n, sgcode, z, pfr
pcir       # Circular interpolation
             if rotaxis = 0, pcirm
# Drilling
pdrill     # Canned Drill Cycle
             pdrillref
       n, *sgdrill, pdrlxyrot, *refht, *depth, *initht, pdwell, *frplunge
ppeck      # Canned Peck Drill Cycle
             pdrillref
       n, *sgdrill, pdrlxyrot, *refht, *depth, *peck1, *frplunge
pchpbrk    # Canned Chip Break Cycle
             pdrillref
       n, *drillref, *sgdrill, pdrlxyrot, *depth, *refht, *peck1, *frplunge
ptap       # Canned Tap Cycle
             pdrillref
       n, *sgdrill, pdrlxyrot, *refht, *depth, *initht, *frplunge
pbore1     # Canned Bore #1 Cycle
             pdrillref
       n, *drillref, *sgdrill, pdrlxyrot, *depth, *refht, pdwell, *frplunge
pbore2     # Canned Bore #2 Cycle
             pdrillref
       n, *drillref, *sgdrill, pdrlxyrot, *depth, *refht, *frplunge
pmisc1     # Canned Misc #1 Cycle (User Option)
             pdrill
pmisc2     # Canned Misc #2 Cycle (User Option)
             pdrill
pdrill_2   # Canned Drill Cycle
           n, pdrlxyrot, refht, depth, *peck1
ppeck_2    # Canned Peck Drill Cycle
             pdrill_2
pchpbrk_2  # Canned Chip Break Cycle
             pdrill_2
ptap_2     # Canned Tap Cycle
             pdrill_2
pbore1_2   # Canned Bore #1 Cycle
             pdrill_2
pbore2_2   # Canned Bore #2 Cycle
             pdrill_2
pmisc1_2   # Canned Misc #1 Cycle
             pdrill_2
pmisc2_2   # Canned Misc #2 Cycle
             pdrill_2
pcanceldc  # Cancel canned drill cycle
             !gcode
             n, "G0", *zr     #JQ G0 was G80
             prv_z = initht
pcancelcc  # Cancel cutter comp.
             #n, "G40"
pwrtt      # Write tool table, scans entire file, null tools are negative
             tnote = t
             toffnote = tloffno
             tlngnote = tlngno
 if t >= 0, n, "/", *tnote, " ", *tldia, " ",
            *sopnote, ")"
             if t >= 0, tcnt = tcnt + 1
# Numbered questions for Mastercam Mill
38. Rapid feedrate? 300.0
1538. Rapid feedrate (metric)? 10000.0
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 300
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name?
100. Number of places BEFORE the decimal point for sequence numbers? 3
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 5000
107. Average time for tool change (seconds)? 2.0
159. Show first and last position as fully compensated in simulation? n
161. Enable Home Position button? y
162. Enable Reference Point button? n
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? n
166. Enable Construction Plane button? n
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? n
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Default Work Coordinate System (0 thru 3=G92, 4 thru 9=G54-G59)? 4
302. Miscellaneous integer variable 2 (mi4)? 0
303. Miscellaneous integer variable 3 (mi4)? 0
304. Miscellaneous integer variable 4 (mi4)? 0
305. Miscellaneous integer variable 5 (mi5)? 0
306. Miscellaneous integer variable 6 (mi6)? 0
307. Miscellaneous integer variable 7 (mi7)? 0
308. Miscellaneous integer variable 8 (mi8)? 0
309. Miscellaneous integer variable 9 (mi9)? 0
310. Miscellaneous integer variable 10 (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? n
1503. Write transform operations (0=transform ops, 1=source ops, 2=both)? 1
1520. Display a warning when cutter compensation in control simulation finds an error? n
1521. Number of controller look-ahead blocks for CDC in control? 2
1530. Ignore work offset numbers when processing subprograms? y
1531. Ignore contour flags when processing subprograms? y
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
3001. Machine acceleration? 2
3002. timing size? .1
if cc_poss$ > 0 & cstart$ = 2, "G-1"
