Spotting & drilling down inside
StoneyNH
Im working on a part that has alotta tapped holes down at Z-.640.How can I get the spot & drill to rapid down to Z-.640 before executing its move?Right now after every move it rapids up to Z .050 & feeds down to Z - .640 which wastes alotta time.I cant use G98 cuz theres islands in the way.Is there a way to get the tools to rapid down to Z-.640,do its move,rapid up to Z .050,then rapid down to Z-.64 again?
I tried T.O.S. @ -.640,retract .05 incremental,clearance .05 absolute with start & end unchecked
I get G99 G81 Z-.675 R-.59 F13.
I cant have that because I have numerous islands in the way.
I guess I should mention Im using  2D graphics.
Your retract and clearance numbers can not be the same. Change your clearance number to something above what you have entered in your retract, doesn't have to be much just different. This will give you what your looking for.
retract is .05 Incremental,clearance is .050 absolute,so the numerical values the same but theres different types,i tried changing the clearance to .060,got the same results
G99 G81 Z-.675 R-.59.
Am I attempting something that just cant be done?
Clearance set to Absolute      1.00
Retract set to Incremental        .05
Top Of Stock set to Absolute  -.64
Depth set to absolute              -????????
If your drill cycle is set correct the tool will start at Z1.00, rapid to Z-.59 to start drilling to programmed depth, after drilling tool will retract to Z1.00 then move to the next hole clearing the islands on the part rapid down to Z-.59 and start all over.
The key is the clearance plane value. I know a lot of programmers that do not use that feature.
If you've tried what the others have suggested and it's not working, the problem lies within your post or machine definition. I do G98 and G99 drill day in and day out and it's always worked the way I need it to. Since we're all telling you pretty much the same thing and you're still not getting results, you've got to dig deeper.
Cathedral,I utilize G98 or G99 when milling pockets or contours & it works good.
But this is drilling so its different.
Can you give me a G code line of what Im trying to do looks like?
Im attempting to rapid down to T.O.S. execute my feed in,rapid up above my islands,move to next position,rapid down to T.O.S. & feed in
MIlling pockets and drilling is two completely different animals inside the brain of mastercam and in the post. Just because it works in milling, that has no affect on the drilling cycles. It's very possible your drill cycles weren't configured right, and no matter what you do all you'll get is a G99.
Cathedral,so what youre telling me is all I have to do is change my G99 to a G98? I could do that manually.But then the tool is still going to retract to Z-.59 isn't it?
No, your tool will retract to the clearance plane, which is wherever the Z is at the start of the cycle. (ie G43 z???)
That is the whole point of G98
Go to your control def, under machine cycles choose return to initial height
If it has worked for you in the past with the same machine definition and post, then it most likely that there's something wrong with your process. But if this is something that your just know trying with this machine definition and post than what Cathedral said here in his last post is very possible.
If you do not know how to work on your post or machine definition I would recommend contacting your reseller to help solve this.
Like Cathedral said, milling and drill are two different animals as far as the post goes.
Hmm... I can't say anything that hasn't been said but I will put my perspective on it.
G98= return to initial Z, for example if you program G43 H1 Z5. G98 G81 Z-.65 R-.5 your drill will rapid from the 5. to what your R value is and then rapid back up to the 5. (which would be over the top of your islands) then move to the next position.
G99= return to R plane, so if your code is G43 H1 Z5. G99 G81 Z-.65 R-.5 it will rapid to and from the R value of -.5 (which would crash into your islands) then rapid to the next positon.
I have seen this before where another Z value before the drill cycle gets posted so that becomes the initial which can cause problems like this -
G43 H1 Z5.
Z.1 <-- this has now become the initial Z value which will screw you up if you are thinking it will rapid back to the 5.
G98 G81 Z-.65 R-.5
