Facing finish pass options
zamot
Hello everyone, I am new to the forum and I have a question
Is there a way to increase the rpm and decrease the feed rate in a facing operation in Mastercam X6?
I am aware that you can change the feed using the tool path editor but I would also like to increase the rpm to get a better finish and I don't see that option other than editing the actual code. can anyone please help me with this?
I don't think, but you can create another op with different feeds and speeds right under your first op.
Is there a way to use two different ops and keep the tool from returning to the clearance height or the retract height and just go straight to the final z depth? I am programming for production and the extra tool motion will add more cycle time to each part.
That would be WAY too useful.  <sarcasm font>
Mastercam has many things that should have been instituted long ago even back in V9 but oddly enough, aren't.
The added it to contour toolpaths, and standard pocket finishing passes, but not pocket facing or standard facing; and then it only works on multi-passes, not depth cuts.
Oh well, who doesn't want twice as many toolpaths in the operations manager anyways, looks like you are doing more work right ?! :laughing:
This is actually fairly easy to accomplish if you know how to make some simple post edits.
The key with using the Toolpath Editor for making changes to generated operation is using the "Canned Text" function. In this example I used the Canned Text function to allow you to modify the spindle speed by outputting the Spindle Speed as a local variable (variable #100). This allows you to output the initial spindle speed as a variable value, then every time the Speed command is issued, we output it as a reference to a variable.
With Canned Text, we probably don't need to have access to such a great range of adjustment, but I wanted to show what is possible using Canned Text.
The other great thing about this modification is that it will work with any version of Mastercam, even V9 (shudder).
The only thing that I would consider adding would be some logic to check the actual RPM value, compare it to the Max RPM, and swap out the Max RPM if that value is exceeded. The current logic just outputs an equation to override the SS value.
O0000(CANTEXT_SS_OVERRIDE)
(DATE=DD-MM-YY - 24-08-14 TIME=HH:MM - 16:22)
(MCX FILE - D:\EMASTERCAM\CANTEXT_SS_OVERRIDE.MCX-6)
(NC FILE - C:\USERS\COLIN_000\DOCUMENTS\MY MCAMX6\MILL\NC\CANTEXT_SS_OVERRIDE.NC)
(MATERIAL - ALUMINUM INCH - 2024)
( T1 | 2"  FACE MILL | H1 )
N100 G20
N110 G0 G17 G40 G49 G80 G90
N120 T1 M6
N130 #100=1146 ( SS SAVED IN TEMP VAR 100 )
N140 G0 G90 G54 X-1.6207 Y-2.9697 A0. S#100 M3
N150 G43 H1 Z.2
N160 Z.1
N170 G1 Z.01 F100.
N180 X-1.9636 Y-2.19 F53.63
N190 X-2.0366 Y-2.024
N200 G3 X-2.1303 Y-1.887 I-.4119 J-.1812
N210 G1 X-2.1611 Y-1.8473
N220 X-2.2147 Y-1.772
N230 X-2.2719 Y-1.6813
N240 X-2.3273 Y-1.58
N250 X-2.3785 Y-1.4703
N260 X-2.4238 Y-1.3537
N270 X-2.462 Y-1.2316
N280 X-2.4921 Y-1.1051
N290 X-2.5129 Y-.9812
N300 X-2.5257 Y-.8655
N310 G2 X-2.5362 Y-.6519 I3.0494 J.2571
N320 X-2.5365 Y-.5954 I5.8687 J.0565
N330 X-2.5271 Y-.2647 I5.869 J0.
N340 X-2.4947 Y.1995 I14.1838 J-.7562
N350 X-2.4686 Y.4121 I3.4076 J-.3105
N360 G1 X-2.4486 Y.5241
N370 X-2.4229 Y.6378
N380 X-2.3907 Y.7517
N390 X-2.3519 Y.8647
N400 X-2.3061 Y.9758
N410 X-2.2532 Y1.0838
N420 X-2.1933 Y1.1879
N430 X-2.1267 Y1.2873
N440 X-2.0535 Y1.3812
N450 X-1.9742 Y1.4689
N460 X-1.8892 Y1.5497
N470 X-1.7992 Y1.6231
N480 X-1.7046 Y1.6887
N490 X-1.6061 Y1.7464
N500 X-1.5046 Y1.7967
N510 X-1.4012 Y1.84
N520 X-1.2968 Y1.877
N530 X-1.1919 Y1.9083
N540 X-1.087 Y1.9346
N550 G2 X-.8781 Y1.9743 I.6592 J-2.9021
N560 X-.5689 Y2.0086 I.5717 J-3.742
N570 X-.1837 Y2.022 I.3852 J-5.54
N580 X-.165 Y2.0219 I0. J-5.5534
N590 X.232 Y2.0124 I-.0306 J-9.5587
N600 G3 X.5107 Y2.0026 I.8254 J19.4551
N610 X.5768 Y2.0019 I.0661 J3.1105
N620 X.6777 Y2.0035 I0. J3.1112
N630 X.8301 Y2.0144 I-.0642 J1.9621
N640 X.9683 Y2.0366 I-.1606 J1.4438
N650 X1.0971 Y2.0714 I-.2495 J1.1803
N660 X1.2518 Y2.1289 I-.7483 J2.2499
N670 X1.5168 Y2.2422 I-4.2806 J10.3708
N680 G2 X1.7013 Y2.3187 I2.3772 J-5.4754
N690 X1.8862 Y2.385 I1.136 J-2.8787
N700 X2.0709 Y2.4361 I.7274 J-2.2694
N710 X2.3578 Y2.4884 I.6802 J-2.9167
N720 X2.7508 Y2.5224 I.5725 J-4.3252
N730 X3.0262 Y2.5281 I.2754 J-6.6052
N740 X3.15 Y2.527 I0. J-6.6109
N750 X3.7551 Y2.5013 I-.2696 J-13.4962
N760 X4.3674 Y2.457 I-2.2701 J-35.6001
N770 G3 X4.5787 Y2.4438 I.5026 J6.3417
N780 X4.7318 Y2.4403 I.1531 J3.3733
N790 X4.792 Y2.4409 I0. J3.3768
N800 G1 X4.8986 Y2.4451
N810 X5.0047 Y2.454
N820 X5.1102 Y2.4679
N830 X5.2146 Y2.4874
N840 X5.3177 Y2.5127
N850 X5.4194 Y2.5443
N860 X5.5228 Y2.5833
N870 X5.6268 Y2.6281
N880 X5.7285 Y2.6772
N890 G3 X6.0065 Y2.8297 I-2.8968 J5.6133
N900 G2 X6.1684 Y2.9189 I3.2298 J-5.6657
N910 X6.3138 Y2.9905 I1.1943 J-2.2413
N920 X6.5239 Y3.0695 I.7342 J-1.6343
N930 X6.764 Y3.1321 I.8147 J-2.6326
N940 X7.1151 Y3.1928 I.9459 J-4.4304
N950 X7.5819 Y3.2406 I1.0311 J-7.7567
N960 X8.26 Y3.2757 I1.1705 J-16.0437
N970 X8.5368 Y3.2812 I.2877 J-7.5697
N980 X8.6933 Y3.2747 I-.0127 J-2.2023
N990 X8.828 Y3.2577 I-.1077 J-1.3942
N1000 X8.9422 Y3.2306 I-.1735 J-.9853
N1010 X9.0371 Y3.195 I-.2188 J-.7286
N1020 X9.2953 Y2.9928 I-.2905 J-.6369
N1030 G1 X9.3293 Y2.946
N1040 X9.3626 Y2.8919
N1050 X9.3945 Y2.8312
N1060 X9.4245 Y2.7645
N1070 X9.4522 Y2.6927
N1080 G2 X9.4997 Y2.5359 I-1.6774 J-.5937
N1090 X9.5359 Y2.365 I-2.1556 J-.546
N1100 X9.5612 Y2.1837 I-2.9945 J-.5107
N1110 X9.5951 Y1.816 I-7.2966 J-.8579
N1120 X9.5997 Y1.6677 I-2.3684 J-.1483
N1130 G1 Y1.6565
N1140 G2 X9.5925 Y1.5183 I-1.4709 J.0072
N1150 X9.5739 Y1.4002 I-1.0356 J.103
N1160 X9.5453 Y1.3009 I-.7688 J.1672
N1170 X9.3375 Y1.0043 I-.6577 J.2397
N1180 G1 X9.2918 Y.969
N1190 X9.2388 Y.9344
N1200 X9.179 Y.9011
N1210 X9.1132 Y.8697
N1220 X9.0422 Y.8406
N1230 G2 X8.8869 Y.79 I-.6166 J1.6303
N1240 X8.7175 Y.7508 I-.5698 J2.0747
N1250 X8.4441 Y.7126 I-.5329 J2.8208
N1260 X8.0602 Y.6873 I-.9186 J11.0103
N1270 X7.677 Y.6723 I-.7828 J15.0977
N1280 X7.6133 Y.6716 I-.0637 J2.8921
N1290 X7.5107 Y.6734 I0. J2.8928
N1300 X7.3666 Y.6849 I.0596 J1.6667
N1310 X7.2436 Y.7069 I.1401 J1.1365
N1320 X7.1403 Y.7383 I.1958 J.8294
N1330 X7.0548 Y.7773 I.2471 J.655
N1340 X6.946 Y.846 I.6329 J1.1227
N1350 X6.8044 Y.9496 I2.3665 J3.3843
N1360 G1 X6.7253 Y1.0091
N1370 X6.6464 Y1.0605
N1380 X6.5612 Y1.1079
N1390 X6.461 Y1.1543
N1400 X6.3385 Y1.1875
N1410 X6.1981 Y1.2125
N1420 G2 X6.0334 Y1.2362 I.3085 J2.7276
N1430 G3 X5.6725 Y1.2757 I-.6661 J-4.416
N1440 X5.3037 Y1.2997 I-2.6825 J-38.5159
N1450 G2 X4.6257 Y1.354 I1.5746 J23.8973
N1460 G1 X4.5458 Y1.3613
N1470 X4.4666 Y1.3685
N1480 X4.3877 Y1.3691
N1490 X4.3098 Y1.3745
N1500 X4.166 Y1.339
N1510 X4.0404 Y1.2753
N1520 X3.932 Y1.2011
N1530 X3.8384 Y1.1253
N1540 X3.7574 Y1.0524
N1550 G3 X3.5263 Y.8135 I2.4209 J-2.573
N1560 X3.4521 Y.7231 I1.2211 J-1.0771
N1570 X3.3734 Y.6017 I.7637 J-.5815
N1580 X3.2946 Y.4358 I1.4417 J-.7865
N1590 X3.1945 Y.1548 I2.9595 J-1.2126
N1600 G1 X3.1687 Y.0707
N1610 G2 X3.0772 Y-.213 I-6.8676 J2.0579
N1620 X2.9996 Y-.4107 I-2.8369 J1.0003
N1630 G1 X2.9544 Y-.5082
N1640 X2.9048 Y-.6035
N1650 X2.8505 Y-.6957
N1660 X2.7916 Y-.7841
N1670 X2.7281 Y-.868
N1680 X2.6603 Y-.9467
N1690 X2.5885 Y-1.0198
N1700 X2.513 Y-1.0869
N1710 X2.4343 Y-1.1474
N1720 X2.352 Y-1.2017
N1730 X2.2651 Y-1.2509
N1740 X2.1747 Y-1.2949
N1750 X2.0814 Y-1.3339
N1760 X1.986 Y-1.3682
N1770 X1.8889 Y-1.3981
N1780 G2 X1.6918 Y-1.4458 I-.7251 J2.5658
N1790 X1.3923 Y-1.4923 I-.6651 J3.2973
N1800 X.9916 Y-1.5193 I-.5272 J4.824
N1810 X.791 Y-1.5219 I-.2006 J7.8104
N1820 X.4917 Y-1.5162 I0. J7.813
N1830 X.1922 Y-1.5022 I.4086 J11.9819
N1840 X-.0048 Y-1.4855 I.2417 J4.017
N1850 X-.1933 Y-1.4575 I.273 J2.4845
N1860 G1 X-.283 Y-1.4383
N1870 X-.369 Y-1.4154
N1880 X-.441 Y-1.3918
N1890 X-.5028 Y-1.366
N1900 X-.5588 Y-1.3369
N1910 X-.6094 Y-1.305
N1920 X-.6557 Y-1.27
N1930 X-.6991 Y-1.2312
N1940 X-.7407 Y-1.1871
N1950 X-.7805 Y-1.1372
N1960 X-.8182 Y-1.0815
N1970 X-.8536 Y-1.0201
N1980 X-.8864 Y-.9533
N1990 X-.9162 Y-.8816
N2000 X-.9429 Y-.8056
N2010 X-.9659 Y-.7264
N2020 X-.9851 Y-.6452
N2030 X-1.0002 Y-.5634
N2040 X-1.0107 Y-.4828
N2050 X-1.0168 Y-.4039
N2060 X-1.0181 Y-.3291
N2070 X-1.015 Y-.2599
N2080 X-1.0079 Y-.1982
N2090 G2 X-.8596 Y.1335 I.6914 J-.11
N2100 G1 X-.8237 Y.1743
N2110 X-.7814 Y.2152
N2120 X-.7324 Y.2551
N2130 X-.6771 Y.2934
N2140 X-.6161 Y.3294
N2150 X-.5496 Y.3631
N2160 X-.4779 Y.3941
N2170 X-.4014 Y.4223
N2180 G2 X-.2352 Y.4706 I.6509 J-1.9298
N2190 X.0418 Y.5251 I.7337 J-3.
N2200 X.3419 Y.5659 I1.4753 J-9.7289
N2210 G1 X.4452 Y.5793
N2220 G3 X.976 Y.656 I-1.6837 J13.5363
N2230 X1.2977 Y.7152 I-1.8442 J10.9119
N2240 G1 X1.3996 Y.7387
N2250 X1.4876 Y.7656
N2260 X1.5767 Y.7996
N2270 X1.6684 Y.8421
N2280 G2 X1.8636 Y.9656 I15.0141 J-23.5104
N2290 G1 X1.9715 Y1.0673
N2300 G2 X2.4515 Y1.2578 I.48 J-.5095
N2310 X3.1515 Y.5578 I0. J-.7
N2320 X3.098 Y.2893 I-.7 J0.
N2330 G3 X3.0445 Y.0208 I.6465 J-.2685
N2340 X3.0458 Y-.0225 I.7 J0.
N2350 G1 X3.0263 Y-.1392
N2360 X2.9977 Y-.246
N2370 X2.9643 Y-.339
N2380 X2.9267 Y-.4228
N2390 X2.885 Y-.5002
N2400 X2.8385 Y-.5734
N2410 X2.7857 Y-.6442
N2420 X2.7274 Y-.711
N2430 X2.6666 Y-.7714
N2440 X2.6043 Y-.8258
N2450 X2.5411 Y-.8747
N2460 X2.4774 Y-.9187
N2470 X2.3505 Y-.9928
N2480 X2.2235 Y-1.0543
N2490 X2.0974 Y-1.105
N2500 X1.9729 Y-1.1468
N2510 X1.8495 Y-1.1815
N2520 X1.7273 Y-1.2103
N2530 G2 X1.4849 Y-1.2558 I-1.026 J4.8024
N2540 X.9838 Y-1.328 I-2.7325 J17.1828
N2550 X.5665 Y-1.3796 I-3.0905 J23.3113
N2560 G1 X.4933 Y-1.3765
N2570 X.3364 Y-1.37 Z.03
N2580 X.0437 Y-1.3578
N2590 G2 X-.3876 Y-.9081 I.0188 J.4497
N2600 X-.1612 Y-.5177 I.4501 J0.
N2610 G1 X5.8947 Y2.9513
N2620 G2 X6.1183 Y3.0108 I.2236 J-.3905
N2630 G1 X6.1238
N2640 G3 X6.2769 Y3.009 I.1555 J6.9635
N2650 G1 X6.3291 Y3.0126 Z.0233
N2660 X6.3806 Y3.0222 Z.0167
N2670 X6.4306 Y3.0377 Z.01
N2680 G2 X6.5688 Y3.0684 I.9202 J-3.8169
N2690 X6.8377 Y3.1061 I.5025 J-2.6097
N2700 X7.1957 Y3.1255 I.4528 J-5.0285
N2710 X7.3713 Y3.1271 I.1756 J-9.7111
N2720 X7.7327 Y3.1204 I0. J-9.7127
N2730 X7.9128 Y3.1131 I-.468 J-13.7616
N2740 G1 X8.0218 Y3.1056
N2750 X8.1608 Y3.0779
N2760 X8.2943 Y3.0286
N2770 X8.4194 Y2.9606
N2780 X8.5334 Y2.8774
N2790 X8.6349 Y2.7827
N2800 X8.684 Y2.7269
N2810 X8.7122 Y2.6885
N2820 X8.7432 Y2.6389
N2830 X8.7757 Y2.574
N2840 X8.8063 Y2.49
N2850 X8.8284 Y2.3855
N2860 X8.8338 Y2.2634
N2870 X8.8154 Y2.131
N2880 X8.7708 Y1.9977
N2890 X8.7039 Y1.8709
N2900 X8.6201 Y1.7534
N2910 X8.5231 Y1.6468
N2920 X8.4267 Y1.5665
N2930 X8.3178 Y1.4992
N2940 X8.1934 Y1.4393
N2950 G2 X7.893 Y1.3279 I-2.8145 J7.1267
N2960 X7.6165 Y1.2501 I-.825 J2.4028
N2970 X7.4165 Y1.2129 I-.6367 J2.8645
N2980 G1 X7.3107 Y1.1981
N2990 X7.2203 Y1.1984
N3000 X7.0632 Y1.1988 Z.03
N3010 X6.7703 Y1.1995
N3020 G0 Z.11
N3030 X-1.6207 Y-2.9697
N3040 Z.01
N3050 G1 Z0. F100.
N3060 #100=[#100*1.5]
N3070 S#100
N3080 X-1.9636 Y-2.19 F15.
N3090 X-2.0366 Y-2.024
N3100 G3 X-2.1303 Y-1.887 I-.4119 J-.1812
N3110 G1 X-2.1611 Y-1.8473
N3120 X-2.2147 Y-1.772
N3130 X-2.2719 Y-1.6813
N3140 X-2.3273 Y-1.58
N3150 X-2.3785 Y-1.4703
N3160 X-2.4238 Y-1.3537
N3170 X-2.462 Y-1.2316
N3180 X-2.4921 Y-1.1051
N3190 X-2.5129 Y-.9812
N3200 X-2.5257 Y-.8655
N3210 G2 X-2.5362 Y-.6519 I3.0494 J.2571
N3220 X-2.5365 Y-.5954 I5.8687 J.0565
N3230 X-2.5271 Y-.2647 I5.869 J0.
N3240 X-2.4947 Y.1995 I14.1838 J-.7562
N3250 X-2.4686 Y.4121 I3.4076 J-.3105
N3260 G1 X-2.4486 Y.5241
N3270 X-2.4229 Y.6378
N3280 X-2.3907 Y.7517
N3290 X-2.3519 Y.8647
N3300 X-2.3061 Y.9758
N3310 X-2.2532 Y1.0838
N3320 X-2.1933 Y1.1879
N3330 X-2.1267 Y1.2873
N3340 X-2.0535 Y1.3812
N3350 X-1.9742 Y1.4689
N3360 X-1.8892 Y1.5497
N3370 X-1.7992 Y1.6231
N3380 X-1.7046 Y1.6887
N3390 X-1.6061 Y1.7464
N3400 X-1.5046 Y1.7967
N3410 X-1.4012 Y1.84
N3420 X-1.2968 Y1.877
N3430 X-1.1919 Y1.9083
N3440 X-1.087 Y1.9346
N3450 G2 X-.8781 Y1.9743 I.6592 J-2.9021
N3460 X-.5689 Y2.0086 I.5717 J-3.742
N3470 X-.1837 Y2.022 I.3852 J-5.54
N3480 X-.165 Y2.0219 I0. J-5.5534
N3490 X.232 Y2.0124 I-.0306 J-9.5587
N3500 G3 X.5107 Y2.0026 I.8254 J19.4551
N3510 X.5768 Y2.0019 I.0661 J3.1105
N3520 X.6777 Y2.0035 I0. J3.1112
N3530 X.8301 Y2.0144 I-.0642 J1.9621
N3540 X.9683 Y2.0366 I-.1606 J1.4438
N3550 X1.0971 Y2.0714 I-.2495 J1.1803
N3560 X1.2518 Y2.1289 I-.7483 J2.2499
N3570 X1.5168 Y2.2422 I-4.2806 J10.3708
N3580 G2 X1.7013 Y2.3187 I2.3772 J-5.4754
N3590 X1.8862 Y2.385 I1.136 J-2.8787
N3600 X2.0709 Y2.4361 I.7274 J-2.2694
N3610 X2.3578 Y2.4884 I.6802 J-2.9167
N3620 X2.7508 Y2.5224 I.5725 J-4.3252
N3630 X3.0262 Y2.5281 I.2754 J-6.6052
N3640 X3.15 Y2.527 I0. J-6.6109
N3650 X3.7551 Y2.5013 I-.2696 J-13.4962
N3660 X4.3674 Y2.457 I-2.2701 J-35.6001
N3670 G3 X4.5787 Y2.4438 I.5026 J6.3417
N3680 X4.7318 Y2.4403 I.1531 J3.3733
N3690 X4.792 Y2.4409 I0. J3.3768
N3700 G1 X4.8986 Y2.4451
N3710 X5.0047 Y2.454
N3720 X5.1102 Y2.4679
N3730 X5.2146 Y2.4874
N3740 X5.3177 Y2.5127
N3750 X5.4194 Y2.5443
N3760 X5.5228 Y2.5833
N3770 X5.6268 Y2.6281
N3780 X5.7285 Y2.6772
N3790 G3 X6.0065 Y2.8297 I-2.8968 J5.6133
N3800 G2 X6.1684 Y2.9189 I3.2298 J-5.6657
N3810 X6.3138 Y2.9905 I1.1943 J-2.2413
N3820 X6.5239 Y3.0695 I.7342 J-1.6343
N3830 X6.764 Y3.1321 I.8147 J-2.6326
N3840 X7.1151 Y3.1928 I.9459 J-4.4304
N3850 X7.5819 Y3.2406 I1.0311 J-7.7567
N3860 X8.26 Y3.2757 I1.1705 J-16.0437
N3870 X8.5368 Y3.2812 I.2877 J-7.5697
N3880 X8.6933 Y3.2747 I-.0127 J-2.2023
N3890 X8.828 Y3.2577 I-.1077 J-1.3942
N3900 X8.9422 Y3.2306 I-.1735 J-.9853
N3910 X9.0371 Y3.195 I-.2188 J-.7286
N3920 X9.2953 Y2.9928 I-.2905 J-.6369
N3930 G1 X9.3293 Y2.946
N3940 X9.3626 Y2.8919
N3950 X9.3945 Y2.8312
N3960 X9.4245 Y2.7645
N3970 X9.4522 Y2.6927
N3980 G2 X9.4997 Y2.5359 I-1.6774 J-.5937
N3990 X9.5359 Y2.365 I-2.1556 J-.546
N4000 X9.5612 Y2.1837 I-2.9945 J-.5107
N4010 X9.5951 Y1.816 I-7.2966 J-.8579
N4020 X9.5997 Y1.6677 I-2.3684 J-.1483
N4030 G1 Y1.6565
N4040 G2 X9.5925 Y1.5183 I-1.4709 J.0072
N4050 X9.5739 Y1.4002 I-1.0356 J.103
N4060 X9.5453 Y1.3009 I-.7688 J.1672
N4070 X9.3375 Y1.0043 I-.6577 J.2397
N4080 G1 X9.2918 Y.969
N4090 X9.2388 Y.9344
N4100 X9.179 Y.9011
N4110 X9.1132 Y.8697
N4120 X9.0422 Y.8406
N4130 G2 X8.8869 Y.79 I-.6166 J1.6303
N4140 X8.7175 Y.7508 I-.5698 J2.0747
N4150 X8.4441 Y.7126 I-.5329 J2.8208
N4160 X8.0602 Y.6873 I-.9186 J11.0103
N4170 X7.677 Y.6723 I-.7828 J15.0977
N4180 X7.6133 Y.6716 I-.0637 J2.8921
N4190 X7.5107 Y.6734 I0. J2.8928
N4200 X7.3666 Y.6849 I.0596 J1.6667
N4210 X7.2436 Y.7069 I.1401 J1.1365
N4220 X7.1403 Y.7383 I.1958 J.8294
N4230 X7.0548 Y.7773 I.2471 J.655
N4240 X6.946 Y.846 I.6329 J1.1227
N4250 X6.8044 Y.9496 I2.3665 J3.3843
N4260 G1 X6.7253 Y1.0091
N4270 X6.6464 Y1.0605
N4280 X6.5612 Y1.1079
N4290 X6.461 Y1.1543
N4300 X6.3385 Y1.1875
N4310 X6.1981 Y1.2125
N4320 G2 X6.0334 Y1.2362 I.3085 J2.7276
N4330 G3 X5.6725 Y1.2757 I-.6661 J-4.416
N4340 X5.3037 Y1.2997 I-2.6825 J-38.5159
N4350 G2 X4.6257 Y1.354 I1.5746 J23.8973
N4360 G1 X4.5458 Y1.3613
N4370 X4.4666 Y1.3685
N4380 X4.3877 Y1.3691
N4390 X4.3098 Y1.3745
N4400 X4.166 Y1.339
N4410 X4.0404 Y1.2753
N4420 X3.932 Y1.2011
N4430 X3.8384 Y1.1253
N4440 X3.7574 Y1.0524
N4450 G3 X3.5263 Y.8135 I2.4209 J-2.573
N4460 X3.4521 Y.7231 I1.2211 J-1.0771
N4470 X3.3734 Y.6017 I.7637 J-.5815
N4480 X3.2946 Y.4358 I1.4417 J-.7865
N4490 X3.1945 Y.1548 I2.9595 J-1.2126
N4500 G1 X3.1687 Y.0707
N4510 G2 X3.0772 Y-.213 I-6.8676 J2.0579
N4520 X2.9996 Y-.4107 I-2.8369 J1.0003
N4530 G1 X2.9544 Y-.5082
N4540 X2.9048 Y-.6035
N4550 X2.8505 Y-.6957
N4560 X2.7916 Y-.7841
N4570 X2.7281 Y-.868
N4580 X2.6603 Y-.9467
N4590 X2.5885 Y-1.0198
N4600 X2.513 Y-1.0869
N4610 X2.4343 Y-1.1474
N4620 X2.352 Y-1.2017
N4630 X2.2651 Y-1.2509
N4640 X2.1747 Y-1.2949
N4650 X2.0814 Y-1.3339
N4660 X1.986 Y-1.3682
N4670 X1.8889 Y-1.3981
N4680 G2 X1.6918 Y-1.4458 I-.7251 J2.5658
N4690 X1.3923 Y-1.4923 I-.6651 J3.2973
N4700 X.9916 Y-1.5193 I-.5272 J4.824
N4710 X.791 Y-1.5219 I-.2006 J7.8104
N4720 X.4917 Y-1.5162 I0. J7.813
N4730 X.1922 Y-1.5022 I.4086 J11.9819
N4740 X-.0048 Y-1.4855 I.2417 J4.017
N4750 X-.1933 Y-1.4575 I.273 J2.4845
N4760 G1 X-.283 Y-1.4383
N4770 X-.369 Y-1.4154
N4780 X-.441 Y-1.3918
N4790 X-.5028 Y-1.366
N4800 X-.5588 Y-1.3369
N4810 X-.6094 Y-1.305
N4820 X-.6557 Y-1.27
N4830 X-.6991 Y-1.2312
N4840 X-.7407 Y-1.1871
N4850 X-.7805 Y-1.1372
N4860 X-.8182 Y-1.0815
N4870 X-.8536 Y-1.0201
N4880 X-.8864 Y-.9533
N4890 X-.9162 Y-.8816
N4900 X-.9429 Y-.8056
N4910 X-.9659 Y-.7264
N4920 X-.9851 Y-.6452
N4930 X-1.0002 Y-.5634
N4940 X-1.0107 Y-.4828
N4950 X-1.0168 Y-.4039
N4960 X-1.0181 Y-.3291
N4970 X-1.015 Y-.2599
N4980 X-1.0079 Y-.1982
N4990 G2 X-.8596 Y.1335 I.6914 J-.11
N5000 G1 X-.8237 Y.1743
N5010 X-.7814 Y.2152
N5020 X-.7324 Y.2551
N5030 X-.6771 Y.2934
N5040 X-.6161 Y.3294
N5050 X-.5496 Y.3631
N5060 X-.4779 Y.3941
N5070 X-.4014 Y.4223
N5080 G2 X-.2352 Y.4706 I.6509 J-1.9298
N5090 X.0418 Y.5251 I.7337 J-3.
N5100 X.3419 Y.5659 I1.4753 J-9.7289
N5110 G1 X.4452 Y.5793
N5120 G3 X.976 Y.656 I-1.6837 J13.5363
N5130 X1.2977 Y.7152 I-1.8442 J10.9119
N5140 G1 X1.3996 Y.7387
N5150 X1.4876 Y.7656
N5160 X1.5767 Y.7996
N5170 X1.6684 Y.8421
N5180 G2 X1.8636 Y.9656 I15.0141 J-23.5104
N5190 G1 X1.9715 Y1.0673
N5200 G2 X2.4515 Y1.2578 I.48 J-.5095
N5210 X3.1515 Y.5578 I0. J-.7
N5220 X3.098 Y.2893 I-.7 J0.
N5230 G3 X3.0445 Y.0208 I.6465 J-.2685
N5240 X3.0458 Y-.0225 I.7 J0.
N5250 G1 X3.0263 Y-.1392
N5260 X2.9977 Y-.246
N5270 X2.9643 Y-.339
N5280 X2.9267 Y-.4228
N5290 X2.885 Y-.5002
N5300 X2.8385 Y-.5734
N5310 X2.7857 Y-.6442
N5320 X2.7274 Y-.711
N5330 X2.6666 Y-.7714
N5340 X2.6043 Y-.8258
N5350 X2.5411 Y-.8747
N5360 X2.4774 Y-.9187
N5370 X2.3505 Y-.9928
N5380 X2.2235 Y-1.0543
N5390 X2.0974 Y-1.105
N5400 X1.9729 Y-1.1468
N5410 X1.8495 Y-1.1815
N5420 X1.7273 Y-1.2103
N5430 G2 X1.4849 Y-1.2558 I-1.026 J4.8024
N5440 X.9838 Y-1.328 I-2.7325 J17.1828
N5450 X.5665 Y-1.3796 I-3.0905 J23.3113
N5460 G1 X.4933 Y-1.3765
N5470 X.3364 Y-1.37 Z.02
N5480 X.0437 Y-1.3578
N5490 G2 X-.3876 Y-.9081 I.0188 J.4497
N5500 X-.1612 Y-.5177 I.4501 J0.
N5510 G1 X5.8947 Y2.9513
N5520 G2 X6.1183 Y3.0108 I.2236 J-.3905
N5530 G1 X6.1238
N5540 G3 X6.2769 Y3.009 I.1555 J6.9635
N5550 G1 X6.3291 Y3.0126 Z.0133
N5560 X6.3806 Y3.0222 Z.0067
N5570 X6.4306 Y3.0377 Z0.
N5580 G2 X6.5688 Y3.0684 I.9202 J-3.8169
N5590 X6.8377 Y3.1061 I.5025 J-2.6097
N5600 X7.1957 Y3.1255 I.4528 J-5.0285
N5610 X7.3713 Y3.1271 I.1756 J-9.7111
N5620 X7.7327 Y3.1204 I0. J-9.7127
N5630 X7.9128 Y3.1131 I-.468 J-13.7616
N5640 G1 X8.0218 Y3.1056
N5650 X8.1608 Y3.0779
N5660 X8.2943 Y3.0286
N5670 X8.4194 Y2.9606
N5680 X8.5334 Y2.8774
N5690 X8.6349 Y2.7827
N5700 X8.684 Y2.7269
N5710 X8.7122 Y2.6885
N5720 X8.7432 Y2.6389
N5730 X8.7757 Y2.574
N5740 X8.8063 Y2.49
N5750 X8.8284 Y2.3855
N5760 X8.8338 Y2.2634
N5770 X8.8154 Y2.131
N5780 X8.7708 Y1.9977
N5790 X8.7039 Y1.8709
N5800 X8.6201 Y1.7534
N5810 X8.5231 Y1.6468
N5820 X8.4267 Y1.5665
N5830 X8.3178 Y1.4992
N5840 X8.1934 Y1.4393
N5850 G2 X7.893 Y1.3279 I-2.8145 J7.1267
N5860 X7.6165 Y1.2501 I-.825 J2.4028
N5870 X7.4165 Y1.2129 I-.6367 J2.8645
N5880 G1 X7.3107 Y1.1981
N5890 X7.2203 Y1.1984
N5900 X7.0632 Y1.1988 Z.02
N5910 X6.7703 Y1.1995
N5920 G0 Z.1
N5930 M5
N5940 G91 G28 Z0.
N5950 G28 X0. Y0. A0.
N5960 M30
CANTEXT_SS_OVERRIDE.Z2G
To use the override ability, you would use the "Toolpath Editor", and use the "Canned Text, With" option. The override is currently setup to allow as low as 5% of the original SS value, to 200% of the original value, in 1% increments.
So to raise the SS, use any value over 100. Any value less than 100 would slow down the Spindle.
Hope that helps,
Colin
Hey Colin, Weren't you at junior school in the V9 days!! :D
Very neat solution from you as always.
But a tick box in the software would be a whole lot simpler :hrhr:
:cheers:
I agree that having it in the interface would certainly be easier.
And while I'm "relatively" young compared to some on here, I started using Mastercam 6.13 in 1997.
Wasn't V8 out at that time? Or maybe even V9?
Hmm, if memory serves, the shop I was working in had 6.13 installed, and V7 was just released. I know I went through the process of upgrading from V7, to V8, then eventually to V9. I believe V9 was actually "released" in either late 2001 or early 2002. I think that V9 was around for at least 2 years, while everyone waited for X to come out. I certainly attended quite a few training classes on the older software versions that were put on by my reseller in the late 1990's...
