eob$ (end of block)
Do you have   e$   at the end of each block in the post?  If so you can get the dollar sign output you're looking for by inserting an ASCII character.  Using the replace function, change all   , e$  with    , 36, e$     The number 36 will output a dollar sign to your posted code.
What I would do, to save a bunch of typing, is create an EOB post block. Then, for every line you want an EOB, instead of typing 36, eob$, you can just type pe
Then somewhere in the post, create a post block that says this:
pe
      36, eob$
and do a find, replace to replace eob$ with pe  (except for in that postblock)
The call to 'pprep$' is made before the Control Definition is read. You could move this code to the beginning of 'psof$' and it would work there for you. The proper way to do this however is to use the Control Definition, as this is expressly the type of thing it was designed to handle.
When you enable the 'Alternate EOB character' option, this sets the pre-defined variable 'use_alt_eob$' to 'yes$'. (1)
The Alternate EOB character output can be a single ASCII value if only the first alternate is set, or you can output two optional EOB characters by using the first and second alternates. (MP will automatically output both if both are not zero)
There is also a checkbox that controls the option for removing the carriage return and line feed characters (when checked).
Hope that helps,
Colin
