MCX5 4ax post issue?
johnh
Hi all,
I've been playing around with our Hurco VM10i which has a 4th axis (A) installed. My issue is that I'm trying to get a part that has a thread type feature on it to run. When I output the code it looks like it has continuous X and A motion but the machine reads each line and brakes/unbrakes the 4th on every single move. I have no M codes active in the program that would force this. I can command X and A at the same time (IE: X1.250 A90. F25.) and the x and A move together, but not when it reads my code. Am I looking at a post issue or machine issue? I'm still getting into the 4th axis programming stuff so I'm not sure which way to turn on this. I've had some help from other guys and they have been able to get me to the point of gettnig the program right and now it's on the code. It would seem that Hurco tech support is rather slow on help so I'm hoping someone in here might have an answer for me, or at least point me down the right road. Thanks in advance!
John
Here's what the code looks like:
N100 G20
N102 G0 G17 G40 G49 G80 G90
N104 T4 M6
N106 G0 G90 G54 X-.2927 Y.1229 A-324.392 S8404 M3
N108 G43 H4 Z3.4424
N110 Z1.4424
N112 G1 Z1.1424 F25.
N114 X-.2921 Y.1198 Z1.0979
N116 X-.2904 Y.1107 Z1.0557
N118 X-.2877 Y.0961 Z1.0177
N120 X-.284 Y.0766 Z.9861
N122 X-.2797 Y.0533 Z.9623
N124 X-.2748 Y.0273 Z.9475
N126 X-.2697 Y0. Z.9424
N128 X-.2688 A-324.076 F25..
N130 X-.2678 A-323.757
N132 X-.2668 A-323.442
N134 X-.2658 A-323.125
N136 X-.2649 A-322.808
N138 X-.2639 A-322.495
N140 X-.2629 A-322.176
N142 X-.262 A-321.859
N144 X-.261 A-321.542
N146 X-.26 A-321.224
N148 X-.259 A-320.911
N150 X-.2581 A-320.59
Usually when doing full fourth stuff you will need to output some kind of rotary unlock command, then when the full fourth move is complete do a rotary lock command, this is usually a machine specific M code.
If you don't have them there the machine will still run however it will stop at each move as it locks and unlocks..
I did a quick search online and found this someone saying for a Hurco the unlock code is M33, lock code is M32
For starters I would put that in your code manually .. ie unlock before you start cutting full fourth and lock again after your done..
Assuming that works you could modify or else have your post modified to output the codes for you.. the mpmaster post has a setting for this something like unlock_codes or something..
