Sick of breaking taps due to oversight. M29 output in machine def?
Bucky Cornstarch
So, I program for a number of different machines and have for the most part been using floating tap holders for the last 15+ years. These seem to work okay for the limited amount of tapping we do, so I generally haven't had an issue with the code MC spits out.
Typical code:
(TAP M5)
G0G90G40G80G54
T18M06
M01
S318M3
G0X2.3473Y.5319
G43H18Z.1
M8
G99G84Z-.45R.1F10.
X1.2475Y1.1669
G80
M9
G91G28Z0M05
Fast forward to now: I am finding that using rigid holders with a rigid tap cycle allows us to go much faster and control the thread depth more accurately. (Duh :rolleyes:.)  My machines seem to enjoy having an M29 in the code to turn on rigid tapping, which MC doesn't spit out when I post code. Is there a setting in the machine or control def that would post the M29 for me?
I would like the code to look like this (same code as above but with M29):
(TAP M5)
G0G90G40G80G54
T18M06
M01
G0X2.3473Y.5319
G43H18Z.1
M8
M29S318
G99G84Z-.45R.1F10.
X1.2475Y1.1669
G80
M9
G91G28Z0M05
Up until now I've just been manually editing the code before I send it to the machine, but sometimes I forget. Especially on a Friday afternoon so close to   :cheers: time ;)
Any help would be appreciated
BT
My tapping section in my MPMaster based posts looks like this;
ptap$            #Canned Tap Cycle
      pdrlcommonb
      #RH/LH based on spindle direction
      if rigid_tap, pbld, n$, *sm29, *speed, e$           #Rigid Tapping
      if use_pitch = 0,
        pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,
          prdrlout, [if peck1$, *peck1$], *feed, strcantext, e$
      else,
        if metvals, pitch = n_tap_thds$  # Tap pitch (mm  per thread)
        else, pitch = 1/n_tap_thds$       # Tap pitch (inches per thread)
          prdrlout, [if peck1$, *peck1$], *pitch, !feed, strcantext, e$
      pcom_movea
This may help.
Thanks guys! I didn't want to use the evil "post" word and risk a warning slap from Webby.
To be fair, the post I am using was probably written at least 13-14 years ago (back in the V9 days) and has been updated whenever I've installed new versions of MC.  I'll play around with it and see if I can get it to spit out what I need.
Have a good weekend.
I would strongly tell you to dump it and go to a modern post. Using a Hodge Podge of a post is just asking for trouble. Might be surprised what a friendly call to your dealer might yield. TK-32 will be happy I finally talked about a dealer.
:scooter: :scooter: I am out of the country for 3 weeks in Europe so have a good 3 weeks without the resident PIA. :scooter: :scooter:
If its a Fanuc control, there is a parameter to make G84 always rigid tap, without using M29. Then if you need to float tap something for increased tap life/speed or whatever you can change it back.  I don't know why Fanuc has it turned off as a factory standard.
