Subprograms
bigprody
We are starting to use transform with subprograms for our multiple hit electrodes quite frequently. As things are now the subprogram numbers start at 11 and increment by 1. Is there a way to set that starting value inside of MC? We like to run our trodes at night and if we are to run more than one I need to do a bit of editing to the code.
If your subs already put out starting at 11, someone has already altered your post in some way
The default is adding 1000
SO I think before anyone can offer what you need to do, figuring out what's already been changed is going to be helpful
OK, don't if this will help you but
This will allow you in the first operation to to set your desired sub# and increment value
Created 3 variables
sof          : 1     #start of file flag
prog_inc_no  : -9999 #Subprogram increment value
sav_sub_no   : -9999 #Save the subprogram value
In the psof section I added
if sof, sav_sub_no = mr1$
if sof, prog_inc_no = mr2$
and at the end of the psof section
sof = 0
Then in the section
psub_call_trans #Translate level calls from toolchange, user
if progno$ = main_prg_no$, result = mprint(sprgnerror)
main_prg_no$ = sav_sub_no  <------------------added this line
sav_sub_no = main_prg_no$ + prog_inc_no   <---added this line
pbld, n$, "M98", *main_prg_no$, e$
prv_feed = c9k #Force feed in sub
and I added this int he Control def section
[misc reals]
1."Initial SUB #"
2. Sub Increment"
That lets me set the first sub# to 2500 and increment by 10
So I got
2500
2510
2520
2530
2540
You can alter the values to your taste
hth
I figured it was a post thing, and I was going to have to use a Misc. Value, just thought I would check here first. Thanks John, your examples have got me on the right track.
Have you ever seen a smooth body of water and think I would row the $h!t out of that.
