Opti-Core & Opti-rest
rhino44
So here's my question; I am programming a relatively simple part on a 5-axis Mikron Mill. I have machined 4 of 5 available sides of the stock to finished features. Now I want to flip the part over and finish the last of the features. I have created a Stock Model from all of the previous Operations, and also created an stl as a back-up to my stock model. I want to generate an Opti-core or possibly an Opti-rest toolpath for Side 2 set up that generates its toolpath from the Stock Model that I created. But Mastercam is not cooperating. It just won't recognize my Stock Model and generates only from the original stock definition. I have already set the Stock definition in Backplot/verify options to the new Stock Model but that seems to have no effect. Does anyone have any suggestions? I have attached an image here to show my Stock Model
Hi Ben, thanks for the quick response. Unfortunately, that is not working for me. I have done as you have suggested and yet, I am still getting a lot of unnecessary tool path where the tool is simply cutting air. I can only assume that my toolpath is generating from the original stock definition. that is the only explanation that makes sense.
In Opti rest you have your most updated stock model being selected as your tool path to calculate stock? Also could you try using all of your previous ops to calculate the stock for your new tool path. The only issue I have had using stock models and Opti rest was using a hollow tube. I could not get it to recognize it. Maybe because your stock is somewhat undercut????
I have tried using all previous operations, also tried selecting one operation and clicking on the stock model. I have also tried defining the stock from an stl file. Nothing works. About the undercut, keep in mind that the view I posted of my stock model is seen from the perspective of Top Plane. When I get to secondary operations, the model and the actual part will be inverted. I have created a Relative Plane for secondary operations and I am attempting to get good toolpath from that position. The undercut is no longer an issue. Thanks for the input.
A screen shot would help, but I think I know what you're referring to. When you turn the part over, it will cut air where it thinks there is material, but there really isn't. The only way I've gotten it to work is to split the toolpath in 2. Generate the first path at a depth that will remove the outer boundry of the stock. Then create a new stock model from that, and do a new opti rest using that stock model.
Volumill does the same thing.  BTW, I recently did a side by side comparison of Opti rough and Volumill. Opti won by a factor of about 2:1. Volumill released a new version last month that sped things up by about 50%, but opti still wins by a huge margin.
I am guessing you are doing this is a secondary operation.....
Here's what I do......
Make your stl from your OP1 verify
xform stl into position if necessary
In the next machine group, set the stl as your stock
Then, create a Stock Model based on the stl only, no toolpaths. That will create a stock model that you can then reference for a restmill
I go from the stl to the Stock Model because I have had issues getting the stl to load into verify but the stock model would
It may be an extra step but I have found it works well
I do exactly the same way and have upwards of 200 to 300 operations in files with no issue following this process.
Thanks, J. I will give that a try. Update; That didn't work either. I am giving up on this method. I am going to use the process that Guyinthedesert has suggested. 2 ops instead of 1. Thanks to everyone who stepped up to offer help.
have you tried deleting the op and building a fresh one
was going to try that but not yet....
Was trying to systematically figure out what it was so as not to go though all this again...
mill vertical did not work.
The reason the fist verify results dont look the same as this one is because I tried it with zero stock left on walls....this one has .02.
