Adding subroutines after subroutines
 Not quite sure what your getting at but there may be a simplier solution. Appears you are planning on calling these routines to set your tools.
Can you just put the routines into a seperate program in the memory where as this tool setting program will have the N number repersenting the tool number.
 Can you show an example of a laser routine maybe that will help.
Thanks for the replies to my post.
Here is a very rough example of what I am looking for:
O1234 (main prog #)
N1 (comment)
T1 M6
M98 P1234  Q101  (subroutine call)
M1
N2
T2M6
(tool motion)
M1
N101 (subroutine)
(tool motion)
M99
N10001 (tool laser routine for T1)
T1 M6
S3000M3
(call tool laser macro here)
M1
N10002
T2M6
S3000M3
(call tool macro here)
M1
There is a tool motion subroutine in T1 but not T2. The tool laser macro is needed for both tools and has to be after any tool motion subroutines or after the M30
if there are no tool motion subroutines. In most posts, there is mergeaux after mergesub, so is this a method to output the laser rouitines or is there another method?
I have no experience with "aux" files and I would be interested in learning about and using them.
Thanks again.
If you are using subout you might need to use auxprg. Save a copy of your post and in the following in the appropriate section in the post.
Example from made from generic post hope this helps.
Format new N number
fmt  "N" 21 nn          #Sequence number at tool change
Edit in the following in (start of file after m6,  tool change section of post after m6, and end of file after m30)
psof$ #Start of file for non-zero tool number
      auxprg$ = 1
      subout$ = 2
      nn = t$ + 1000
      *smspc, e$
      pbld, *nn, "(LASER ROUTINE", *t$, ")", e$
      *t$, sm06, e$
      "G65P1234(LASER MACRO)", e$
      pbld, *sm01, e$
      *smspc, e$
      subout$ = 0
ptlchg$ #Tool change
     subout$ = 2
     nn = t$ + 1000
    *t$, sm06, e$
     pbld, *sm01, e$
     *smspc, e$
     subout$ = 0
peof$ #End of file for non-zero tool
        mergeaux$     #Merge non-transform subs
        clearaux$
