Cutter comp on last cut only
Hi everyone,
   I remember that I read one of the topics of which talked about another person wants the CUTTER COMP use only the last cut and somehow I can't find that topic again.
   Today, I'm having the same issue.  In this cut, I have:
Mastercam X7 , Contour feature:
        Cut Parameters: Compensation type: Wear
                                   Contour type: 2D
                                   Compensation direction: Left
         Depth Cuts:
                    Max rough step: .05
                    Finish Cuts: 1
                    Finish Step: .015
            Depth Cut Order:
                    By Contour
        Multi Passes:
             Rough:
                       Number: 1
                       Spacing: .005
             Finish:
                       Number: 1
                       Spacing: .005
        Machining finish passes at:
            Final depth
N6(.100 CRNR 2FLT W/.50TIP .250SHANK DIA)
G0 G17 G40 G49 G53 G80 G90 Z0
T6 M6(ROUGH AND FINISH .100R, CUT#6)
G90 G54
X-12.0177 Y3.7894 S6000 M3
G43(D36) H6 Z1. T3 M8(DOC= Z-.1)
Z.125
G1 Z-.0425 F15.
G41 D36 X-12.0025 Y3.7807 ===============> No need for G41 D6
G3 X-12. Y3.78 I.0025 J.0043
G1 X-11.95
X11.95
X12.
G3 X12.0025 Y3.7807 I0. J.005
G1 G40 X12.0177 Y3.7894
G0 Z.125
X-12.0177
G1 Z-.085
G1 X-11.95
X11.95
X12.
G0 Z.125
X-12.0177
G1 Z-.1
G1 X-11.95
X11.95
X12.
G0 Z.125
X-12.0177 Y3.7844
G1 Z-.1
G41 D36 X-12.0025 Y3.7757 ===============> I do need this for finish cut only G41 D6
G3 X-12. Y3.775 I.0025 J.0043
G1 X-11.95
X11.95
X12.
G3 X12.0025 Y3.7757 I0. J.005
G1 G40 X12.0177 Y3.7844
G0 Z1. M9
M5
G53 Y0
M1
Hi everyone,
                                   Contour type: 2D
         Depth Cuts:
                    Max rough step: .05
                    Finish Cuts: 1
                    Finish Step: .015
            Depth Cut Order:
                    By Contour
        Multi Passes:
             Rough:
                       Number: 1
                       Spacing: .005
             Finish:
                       Number: 1
                       Spacing: .005
            Final depth
G90 G54
Z.125
G1 Z-.0425 F15.
G1 X-11.95
X11.95
X12.
G0 Z.125
X-12.0177
G1 Z-.085
G1 X-11.95
X11.95
X12.
G0 Z.125
X-12.0177
G1 Z-.1
G1 X-11.95
X11.95
X12.
G0 Z.125
X-12.0177 Y3.7844
G1 Z-.1
G1 X-11.95
X11.95
X12.
G0 Z1. M9
M5
G53 Y0
M1
Why not program it correctly? Use the 2D toolpath without it and then use the same toolpath with it only for finishing? You would need to trick the post and create a trigger in the post to not use it and then use it. To dual that down and tune it verses just programming it correctly sorry for me is chasing your tail.
The topic I have seen was someone wanting to turn it on and off in a rapid move.
Hi Ron,
   I thought about the solution as you pointed and I'm looking for something shortcut if there is any.  Thank you for your time to respond my question, Ron.
Pc that is just it there is not real short cut. Why walk around to the back of your shop if you just go out the side door to get your car. Simple is as simple does and I really appreciate your thinking out of the box, but some times things can be made more complicated than they need to be. I again am sorry I see this as one of those cases, but again I say it is.
Why does it matter if the passes before it have comp? What problem does it create that you are trying to overcome here? Root cause analysis is finding out what the root cause of the problem is. Tool is chattering. What is causing it to chatter? Where is it chattering? What are the effects of that chatter? Are you getting excessive tool wear? Surface finish being effected? Once you identify the root cause you then work backwards to eliminate everything creating the problem.
Why does comp on every pass before the last one create a problem for you? I along with others have never run into such an issue and have subscribed to breaking up operations if we want this ability. Why would that process not be effective, efficient and empowering to your application?
I also break things down to 3 areas. People, Process and Technology. Where is the break down in your application?
I just talked to my dealer and I paid with my personal card, they said it is doable.  I will post here for the solution.
Thanks for all of you have been input your time to respond my question.
I really wish you would not post up the solution. You are paying for a service and unless they give you permission to share it then I would rather you didn't.
I never said it was was not possible. :question:
Hi Ron,
ctrl+c, then ctrl+v
Between the keyboard and monitor meh thinks   ;)
You mean between the chair and the keyboard :harhar:
I'm trying to be informative and if you guys said so, then I keep it myself.   Thanks to all your suggestions.
Go back and look at my track record of sharing information and being helpful. I have shared my work for years. This is not your work so sorry if you don't see the difference between the two, but I see a huge difference. You are paying for a service and with that service there should be a certain amount of respect given in my opinion. You are free to do whatever you think is right, but I see if different and sorry I am willing to say what I think.
Thanks for all that you have shared Ron.
But If he recieved information without any agreement of disclosure then he is free to do as he wishes IMHO.
