IHS Post G-Codes longer than stock MASTERCAM post, do you know why?
Hi Forum,
   Suddenly we intend to buy more OLD equipment (around 1995), and I just found out that In House Solutions has longer G-CODEs than the regular post from MASTERCAM.
   I went to Machine definition and set at SIGNED RADIUS instead of CENTER TO DELTA for both posts and the result was MASTERCAM post is much shorter.  I've been working with IN HOUSE SOLUTION for such a long time and I would like the G-CODES as short as the MASTERCAM's.  Do guys have any solution?
   Below here is the sample code from Mastercam post, thanks for your help.
T10 M6
G0 G90 G54 X1.2852 Y-.2176 S9000 M3
G43 H10 Z.5
Z.1
G1 Z-.085 F10.
X1.2674 Y-.1997
X1.3924
Y-.2176
G0 Z.1
Y-.1997
G1 Z-.085
Y-.1818
G0 Z.1
X1.3745 Y-.1568
G1 Z-.085
G3 X1.3924 Y-.1176 R.0391
X1.3611 Y-.0818 R.034
X1.3297 Y-.1102 R.0316
X1.2986 Y-.0836 R.0315
X1.2674 Y-.1193 R.0339
X1.2852 Y-.1551 R.0369
G0 Z.1
X1.3297 Y-.1191
G1 Z-.085
Y-.1102
G0 Z.1
X1.2852 Y-.0568
G1 Z-.085
X1.2674 Y-.039
X1.3924
Y-.0568
G0 Z.1
Y-.039
G1 Z-.085
Y-.0211
G0 Z.1
X1.3746 Y.0039
G1 Z-.085
G3 X1.3727 Y.0768 R.0446
X1.312 Y.0396 R.0405
X1.3227 Y.0039 R.0577
G1 X1.2674
Y.0794
G0 Z.5
M5
G91 G28 Z0.
G28 X0. Y0.
It would be a lot easier to figure out why if you posted a piece of code from BOTH posts rather than just one post.. what you gave is only one piece of the puzzle..
Or better yet a sample file and even a .z2g so we can do what you should be asking your dealer about help for.
Not Saying, but Saying.
Good morning DJSTEDMAN,
    Thank you for your respond to help me and here is my TWO sample of codes of which posted the same toolpath and same file.
MasterCAM Post
T8 M6
G0 G90 G54 X-.9281 Y-.9281 S1528 M3
G43 H8 Z.5
G98 G81 Z-.2821 R-.02 F11.
X.9281
Y.9281
X-.9281
G80
M5
G91 G28 Z0.
M01
( 1/4 CHFM DEBUR PROFILE & C'BORE )
T9 M6
G0 G90 G54 X-1.2715 Y.025 S8000 M3
G43 H9 Z.5
Z.1
G1 Z-.06 F30.
G41 D39 X-1.359
G3 X-1.384 Y0. R.025
X-1.1201 Y-.813 R1.384
G2 X-1.1129 Y-.8627 R.054
G3 X-.8627 Y-1.1129 R.196
G2 X-.813 Y-1.1201 R.054
G3 X.813 R1.384
G2 X.8627 Y-1.1129 R.054
G3 X1.1129 Y-.8627 R.196
G2 X1.1201 Y-.813 R.054
G3 Y.813 R1.384
G2 X1.1129 Y.8627 R.054
G3 X.8627 Y1.1129 R.196
G2 X.813 Y1.1201 R.054
G3 X-.813 R1.384
G2 X-.8627 Y1.1129 R.054
G3 X-1.1129 Y.8627 R.196
G2 X-1.1201 Y.813 R.054
G3 X-1.3837 Y-.03 R1.384
X-1.3581 Y-.0544 R.025
G1 G40 X-1.2707 Y-.0526
G0 Z.5
X-.025 Y1.9265
Z.1
G1 Z-.06
G41 D39 Y1.839
G3 X0. Y1.814 R.025
G1 X1.51
G2 X1.5482 Y1.7982 R.054
G1 X1.7982 Y1.5482
G2 X1.814 Y1.51 R.054
G1 Y-1.51
G2 X1.7982 Y-1.5482 R.054
G1 X1.5482 Y-1.7982
G2 X1.51 Y-1.814 R.054
G1 X-1.51
G2 X-1.5482 Y-1.7982 R.054
G1 X-1.7982 Y-1.5482
G2 X-1.814 Y-1.51 R.054
G1 Y1.51
G2 X-1.7982 Y1.5482 R.054
G1 X-1.5482 Y1.7982
G2 X-1.51 Y1.814 R.054
G1 X0.
X.03
G3 X.055 Y1.839 R.025
G1 G40 Y1.9265
G0 Z.5
( 1/4 CHFM DEBUR CENTER HOLE )
X.3835 Y-.025
Z.002
G1 Z-.158
G41 D39 X.471
G3 X.496 Y0. R.025
I-.496 J0.
X.4951 Y.03 R.496
X.4686 Y.0534 R.025
G1 G40 X.3813 Y.0481
G0 Z.5
M5
G91 G28 Z0.
G28 X0. Y0.
IHS Post
N8( 1/2 COUNTERSINK 82 DEG)
G0 G17 G40 G49 G53 G80 G90 Z0.
T8 M6(1/2 C'SINK 4X THRU HOLES, CUT#18)
G90 G54
G43 H8 Z.5 T9(DOC= Z-.2821)
X.9281
Y.9281
X-.9281
G80
G90 G53 Z0. M5
/G53 Y0.
M1
N9( 1/4 90 DEG CHAMFER )
T9 M6(1/4 CHFM DEBUR PROFILE & C'BORE, CUT#19)
G90 G54
G43(D39) H9 Z.5 T1(DOC= Z-.06)
Z.1
G1 Z-.06 F30.
G41 D39 X-1.359
G3 X.813 R1.384
G3 Y.813 R1.384
G3 X-.813 R1.384
G1 X-1.3823 Y-.0377
X-1.3786 Y-.0446
X-1.3729 Y-.0501
X-1.3659 Y-.0535
X-1.3581 Y-.0544
G0 Z.5
X-.025 Y1.9265
Z.1
G1 Z-.06
G41 D39 Y1.839
G3 X0. Y1.814 R.025
G1 X1.51
X1.5205 Y1.813
X1.5307 Y1.8099
X1.54 Y1.8049
X1.5482 Y1.7982
X1.7982 Y1.5482
X1.8049 Y1.54
X1.8099 Y1.5307
X1.813 Y1.5205
X1.814 Y1.51
Y-1.51
X1.813 Y-1.5205
X1.8099 Y-1.5307
X1.8049 Y-1.54
X1.7982 Y-1.5482
X1.5482 Y-1.7982
X1.54 Y-1.8049
X1.5307 Y-1.8099
X1.5205 Y-1.813
X1.51 Y-1.814
X-1.51
X-1.5205 Y-1.813
X-1.5307 Y-1.8099
X-1.54 Y-1.8049
X-1.5482 Y-1.7982
X-1.7982 Y-1.5482
X-1.8049 Y-1.54
X-1.8099 Y-1.5307
X-1.813 Y-1.5205
X-1.814 Y-1.51
Y1.51
X-1.813 Y1.5205
X-1.8099 Y1.5307
X-1.8049 Y1.54
X-1.7982 Y1.5482
X-1.5482 Y1.7982
X-1.54 Y1.8049
X-1.5307 Y1.8099
X-1.5205 Y1.813
X-1.51 Y1.814
X0.
X.03
G1 G40 Y1.9265
G0 Z.5
(T9=  1/4 90 DEG CHAMFER )
(1/4 CHFM DEBUR CENTER HOLE, CUT#20)
(DOC= Z-.158)
(D39)
X.3835 Y-.025
Z.002
G1 Z-.158
G41 D39 X.471
G3 X.496 Y0. R.025
X.496 Y0. I-.496 J0.
G1 X.4958 Y.015
X.4951 Y.03
X.4934 Y.0377
X.4894 Y.0444
X.4836 Y.0496
X.4764 Y.0527
X.4686 Y.0534
G40 X.3813 Y.0481
G0 Z.5
G90 G53 Z0. M5
G53 Y0.
M1
T1 M6
Most likely you want to look at the break arc settings, I believe the default is set to break arc at quadrants for mpmaster machine definition.
That would give you 3 extra lines of code for every full circle.
Hello Allan,
   In arc breaks, I set:
ALLOW 360 DEGREE ARCS (Checked Mark)
   DON'T BREAK ARCS
In the ARC CENTER TYPE, I set:
     XY PLANE: SIGNED RADIUS
     XZ PLANE: SIGNED RADIUS
     YZ PLANE: SIGNED RADOIS
In the HELIX SUPPORT, I chose:
     ONLY IN XY PLANE
And the code shown on the previous respond.
Thank you for your respond, Allan.
