Multi-Passes, Depth Cuts notice
Hello every one,
    In most shop "COMMUNICATION" between the setup man and PROGRAMMER is often occur.   Therefore, I made the post spits out the MULTI-PASSES and DEPTH OF CUTS so he knows exactly of what I do.  See below of my sample code.
   If you guys are interested in this, I will post all of the codes of how I do it.  I think it is time to give back to this forum a bit of my knowledge incase you guys think it is a good idea.
PS: Remember this G-CODE is only sample not to REAL PART, so the number of DEPTH CUTS and MULTI-PASSES are not making sense.
O1111(tmp.NC Post REV.14)
(SOURCE= 715-173528-002-REVC-REWORK-ENGRAVING.MCX-8)
(PART NAME= PL, INDEX HUB, BOTTOM, ALD, RINGLESS)
(UNPROVEN SOURCE CODE)
(POSTED ON APR.03.2015 AT 6*53AM)
(Vertical 4Axis Universial Post)
(MATERIAL TYPE= AL6061-T6)
(MATERIAL STK= X1.40 Y1.30 Z1.00)
(Work Offset Info:)
(OP2)
(XY0= CENTER OF STOCK)
(Z0= TOP OF STOCK)
(TOOLS LIST)
(T1  - .1250, 1/8 CEM 3FLT .250LOC -  H1)
(T2  - .125, 1/8 CEM .005TIP ENGRAVER .150LOC -  H2)
N1(.1250, 1/8 CEM 3FLT .250LOC)
G0 G17 G40 G49 G53 G80 G90 Z0.
T1 M6(CLEAN OLD ENGRAVING, CUT#2)
G90 G54
X.7325 Y2.2025 S7200 M3
G43 H1 Z1. T2 M8(DOC= Z-.05)
(.0005 Rough Depth Cut) ============è ROUGH DEPTH CUT
(1x At.0002 Each Finish Depth) =======è FINISH DEPTH CUT
Z.1
G1 Z-.0005 F5.
X-.5725 F25.
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
Y1.9825
X.8875
Y2.2
X.8867 Y2.2081
X.8842 Y2.2158
X.8803 Y2.2229
G40 X.8774 Y2.227
G0 Z1. M9
G90 G53 Z0. M5
/G53 Y0.
M1
N2(.125, 1/8 CEM .005TIP ENGRAVER .150LOC)
T2 M6(ENGRAVING PART NO. 715-173528-002 REV.C, CUT#3)
G90 G54
X-.735 Y2.3621 S7800 M3
G43 H2 Z1. T1 M8(DOC= Z-.01)
(x2 Rough Multi-Passes At .005) ============è ROUGH MULTI-PASSES
(x1 With.0001 Each Finish Depth) ===========è FINISH MULTI-PASSES
Z.047
G1 Z-.01 F5.
X-.669 F10.
X-.6657 Y2.3608
X-.6639 Y2.3577
X-.6647 Y2.3542
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
(CUTTING…)
G1 Z-.01 F5.
X-.6156 F10.
G0 Z.1
X-.6313 Y2.247
Z.047
G1 Z-.01 F5.
X-.6156 F10.
G0 Z1. M9
G90 G53 Z0. M5
G53 Y0.
M1
T1 M6
You know how crunchy of the operators are, they are willing to SCREAM the entire shop when they see feed rate is F200. where I step over only 10% of the tool.
Letting the post spits out what STEP OVER i am going for, the operator will understand what I want in the program and be ensure when he knows how much he can hold the part strong or weak.
I have to create more codes and as long as the COMMUNICATION between the setup man and the programmer, why not do it?
 I just love to avoid argument and doubtful.
