File descriptor
Hello everyone,
   I'm trying to output the date of the MasterCam created by using FILE DESCRIPTOR info such as:
Created: 4/15/15 08:37AM
Modified: 4/15/15 08:37AM ===== it will show different time and date if we hit save for the next time
Then....
   I want to try to output DESCRIPTOR comments of which contains in the white window.
I looked that it is the line as:
      if sof & gcode$ = 1054, scomm_fx_arg = scomm$, pcomment_out  #File Descriptor
I try to output as this line but not succeeded, can you guys point out what I did wrong?
#String and string selector definitions for NC output
scomm_fx_arg     : ""    #Comment temp string (always set 'scomm_fx_arg' before calling pcomment_out)
pcomment_out #Check comment length, truncate/shorten if necessary
      comm_len = strlen(scomm_str + scomm_end) #Get length of comment begin and end strings
      if comment_mode < two,
        scomm_out = comment_fx(maxnccomment$ - comm_len, scomm_fx_arg, comment_mode)
        scomm_str, no_spc$, scomm_out, no_spc$, scomm_end, e$ #Output truncated comment
      else, #Break comment into multiple lines of output. Must set 'max nc comment' length in CD to 256, so MP won't truncate the string
         #Search 'scomm_fx_arg' for break character
        str_brk = no$ #Set breaking to zero
        if smatch <> sblank, str_brk = strstr(smatch, scomm_fx_arg)
        if str_brk, #the break character is present.
          #Use this block to parse scomm_fx_arg into separate strings to output
          #The next line outputs a blank line to the NC code file, and the line after is the horizontal seperator
          #These IF statements set the 'scomm_type' to report on the type of comment being broken.
          # This is mostly for debugging purposes, to tell you the programmer which comment type is being broken.
          # Even if you remove the message output below with a pound sign, le
          if gcode$ = 1005, scomm_type = "MANUAL ENTRY COMMENT"
          #if gcode$ = 1008, scomm_type = "OPERATION COMMENT"
          if gcode$ = 1051, scomm_type = "MACHINE NAME COMMENT"
          if gcode$ = 1052, scomm_type = "MACHINE GROUP COMMENT"
          if gcode$ = 1053, scomm_type = "GROUP NAME COMMENT"
          if gcode$ = 1054, scomm_type = "FILE DESCRIPTOR COMMENT"
          #The next two lines are just a message. Add a pound sign (#) in front of the lines to remove
          #scomm_str, no_spc$, "STRING BREAKING CHARACTER DETECTED IN A", scomm_type, no_spc$, scomm_end, e$
          #scomm_str, no_spc$, "YOUR COMMENTS HAVE BEEN BROKEN AT THE", smatch, "CHARACTER", no_spc$, scomm_end, e$
          #The next line converts all comments to uppercase characters
          scomm_fx_arg = (scomm_fx_arg)
          #The following 'while' loop breaks the comment into multiple strings, using the 'smatch' character.
          #The default 'smatch' character is the tilde (~), but you can edit the 'smatch' variable definition,
          #  if you wish to change the character used to break the string. For example, replace the "~" with "|" to use the pipe symbol.
          scomm_out = scomm_fx_arg #assign string to scomm_out
          while str_brk > zero,
            stemp1 = brksps(str_brk, scomm_out) #Break string at specified position
            scomm_str, no_spc$, scomm_out, no_spc$, scomm_end, e$ #Output broken comment
            stemp2 = brksps(two, stemp1) #Remove 'smatch' character from front of string
            scomm_out = stemp2 #Set 'scomm_out' back to stemp1, so that it can be broken again
            str_brk = strstr(smatch, scomm_out)
            str_len = strlen(scomm_out)
            if str_brk = zero & str_len > zero, scomm_str, no_spc$, scomm_out, no_spc$, scomm_end, e$ #Output broken comment
          #These two lines output a horizontal separator, then a blank line to the NC file
          scomm_str, no_spc$, shoriz, no_spc$, scomm_end, e$
        else, #This code reads the string, and breaks using a string length parameter
          comm_brk_len = comm_brk_len - comm_len #subtract comment begin/end strings
          str_len = strlen(scomm_fx_arg) #Get length of comment string
          str_brk = int(str_len / comm_brk_len) #Get number of broken output strings
          if frac(str_len / comm_brk_len), str_brk = str_brk + one #Add one more output if not even division
          while str_brk > zero, #Output broken comments
            stemp1 = brksps(comm_brk_len, scomm_out) #Break string at specified position
            scomm_out = stemp1 #Set 'scomm_out' back to stemp1, so it can be broken again in while loop
            str_brk = str_brk - one #Decrement counter
        scomm_out = sblank #Reset scomm_out
