Looking for someone who write a post for the buffer...
Hello everyone,
   I'm looking for someone who can help me to write an extra function in the post on these following:
PS: my dealer can make this but they will lock all the codes PSB file and that I really want to avoid.  I hope someone can help me my needs with a cost that I can afford.
Thank you forum.
Original post spits out
O0258(T.NC Post REV.8)
(Source= T.MCX-8)
(Part name= Machine Group-1)
(Posted on APR.13.2015 AT 7*20AM)
(Vertical 4Axis Universial Post)
(Material type= Aluminum 6061-T6)
(Material STK= X.00 Y.00 Z.00)
(Work Offset Info:)
(TOP)
(XY0= Center here)
( Z0= Top Of Stock)
(TOOLS LIST)
(T1= .2500, 1/4 SPOTDRILL, 2FLTS, 2.000LOC, 3.00LOH)
(T2= .0938, 3/32 FLAT ENDMILL.025 , 4FLTS, 2.000LOC, 3.00LOH)
(T3= .2500, 1/4 CORNER RAD MILL.0625 , 4FLTS, 2.000LOC, 3.00LOH)
N1(.2500, 1/4 SPOTDRILL )
G0 G17 G40 G49 G53 G80 G90 Z0.
T1 M6(Testing, CUT#1)
G90 G54
X-2.7526 Y1.2443 S1069 M3
G43 H1 Z2.
T2 M8(DOC= Z-.125)
G98 G81 Z-.125 R.1 F1.07
X.1056 Y1.4932
X1.0483 Y.1131
X.7843 Y-1.4404
G80 M9
G90 G53 Z0.
M5
/G53 Y0.
M1
N2(.0938, 3/32 FLAT ENDMILL )
T2 M6(profile, CUT#2)
(.125 Per Rough Depth Cut)
(1X .0625 Finish Depth Cut)
(3x .125 Multi-Rough)
(1x .005 Multi-Finish)
G90 G54(Z STK= .015)
(XY STK= .015)
X-.0938 Y2.6009 S8000 M3
G43 H2 Z2. T3 M8(DOC= Z-.485)
Z.2
G1 Z-.1056 F100.
Y2.5072
G3 X0. Y2.4134 R.0938
(Cutting....)
G1 X0.
G3 X.0938 Y2.2522 R.0938
G1 Y2.3459
G0 Z2.
(T2= .0938, 3/32 FLAT ENDMILL )
(PROFILE 2, CUT#3)
(Z STK= .015)
(XY STK= .015)
(DOC= Z-.485)
X-.0938 Y2.4809
Z.2
G1 Z-.092 F100.
Y2.3872
(Cutting...)
G1 Y2.3459
G0 Z2. M9
G90 G53 Z0. M5
/G53 Y0.
M1
N3(.2500, 1/4 CORNER RAD MILL )
T3 M6(CORNER ROUNDER HERE, CUT#4)
(XY STK= .015)
X-.25 Y2.7365 S8000 M3
G43 H3 Z2. T2 M8(DOC= Z-.11)
Z.2
G1 Z-.11 F100.
Y2.4865
G3 X0. Y2.2365 R.25
G1 X3.4087
(Cutting...)
X-3.4087 Y2.2365
X0.
G3 X.25 Y2.4865 R.25
G1 Y2.7365
G0 Z2.
M9
G90 G53 Z0. M5
/G53 Y0.
M1
N202(.0938, 3/32 FLAT ENDMILL )
T2 M6(RADIUS TOOL HERE, CUT#5)
(.1 Per Rough Depth Cut)
(1X .025 Finish Depth Cut)
(2x .125 Multi-Rough)
(2x .005 Multi-Finish)
(XY STK= .015)
X-.0938 Y2.4809 S8000 M3
G43 H2 Z2. T1 M8(DOC= Z-.485)
Z.2
G1 Z-.092 F100.
Y2.3872
G3 X0. Y2.2934 R.0938
G1 X3.4087
(Cutting...)
G1 X0.
G3 X.0938 Y2.3872 R.0938
G1 Y2.4809
G0 Z.25
X-.0938 Y2.3559 M9
M8
Z.2
G1 Z-.092
Y2.2622
G3 X0. Y2.1684 R.0938
(Cutting...)
G1 Y2.3559
G0 Z.25
X-.0938 Y2.3509
S9000 M3
Z.2
G1 Z-.485
Y2.2572 F30.
G3 X0. Y2.1634 R.0938
(Cutting...)
G3 X.0938 Y2.2572 R.0938
G1 Y2.3509
G0 Z.25
X-.0938 Y2.3459
Z.2
G1 Z-.485 F100.
Y2.2522 F30.
G3 X0. Y2.1584 R.0938
(Cutting...)
G1 X0.
G1 Y2.3459
G0 Z2. M9
G90 G53 Z0. M5
G53 Y0.
M1
T1 M6
This is what I need
(Source= T.MCX-8)
(File Desriptor here) ==================> Please make DESCRIPTOR output here
(Work Offset Info:)
(TOP)
(XY0= Center here)
( Z0= Top Of Stock) ========> It has spaces 3 spaces and would like to remove them like this (Z0= Top Of Stock)
(TOOLS LIST)
=====> it should show (T1= .2500, 1/4 SPOTDRILL, 2FLTS, HSS, 2.000LOC, 3.00LOH)
(T2= .0938, 3/32 FLAT ENDMILL.025 , 4FLTS, 2.000LOC, 3.00LOH) ======> This comment does not show RADIUS value when I chose Corner type:,
it should show (T2= .0938, 3/32 FLAT ENDMILL, .025R, CARBIDE , 4FLTS, 2.000LOC, 3.00LOH)
(T3= .2500, 1/4 CORNER RAD MILL.0625 , 4FLTS, 2.000LOC, 3.00LOH) ======> This comment does not show RADIUS and TIP DIAMETER
it should show (T3= .2500, 1/4 CORNER RAD, .0625R, .250TIP DIA, CARBIDE, 4FLTS, 2.000LOC, 3.00LOH)
N1(.2500, 1/4 SPOTDRILL ) =====> Then here it should match (.2500, 1/4 SPOTDRILL, 2FLTS, HSS, 2.000LOC, 3.00LOH)
G90 G54
G43 H1 Z2.
T2 M8(DOC= Z-.125)
X.1056 Y1.4932
X1.0483 Y.1131
X.7843 Y-1.4404
G80 M9
G90 G53 Z0.
M5
/G53 Y0.
M1
N2(.0938, 3/32 FLAT ENDMILL, .025R, CARBIDE, 4FLTS, 2.000LOC, 3.00LOH) =====> it should match T2 from the TOOLS LIST.
(XY STK= .015)
Z.2
G1 Z-.1056 F100.
Y2.5072
(Cutting....)
G1 X0.
G1 Y2.3459
G0 Z2.
(T2= .0938, 3/32 FLAT ENDMILL, .025R, CARBIDE, 4FLTS, 2.000LOC, 3.00LOH) ============= > repeat tool name here
(PROFILE 2, CUT#3)
(.125 Per Rough Depth Cut) =======> Show here base on toolpath #2
(1X .0625 Finish Depth Cut)=======> Show here base on toolpath #2
(3x .125 Multi-Rough)=======> Show here base on toolpath #2
(1x .005 Multi-Finish)=======> Show here base on toolpath #2
(XY STK= .015)
X-.0938 Y2.4809
Z.2
G1 Z-.092 F100.
Y2.3872
(Cutting...)
G1 Y2.3459
G0 Z2. M9
G90 G53 Z0. M5
/G53 Y0.
M1
N3(.2500, 1/4 CORNER RAD MILL ) ==== it should match like this (T3= .2500, 1/4 CORNER RAD, .0625R, .250TIP DIA, CARBIDE, 4FLTS, 2.000LOC, 3.00LOH)
(XY STK= .015)
Z.2
G1 Z-.11 F100.
Y2.4865
G3 X0. Y2.2365 R.25
G1 X3.4087
(Cutting...)
X-3.4087 Y2.2365
X0.
G1 Y2.7365
G0 Z2.
M9
G90 G53 Z0. M5
/G53 Y0.
M1
(XY STK= .015)
Z.2
G1 Z-.092 F100.
Y2.3872
G1 X3.4087
(Cutting...)
G1 X0.
G1 Y2.4809
G0 Z.25
X-.0938 Y2.3559
 M9 =====> Redondant coolant, please remove it
M8 =====> Redondant coolant, please remove it
Z.2
G1 Z-.092
Y2.2622
(Cutting...)
G1 Y2.3559
G0 Z.25
X-.0938 Y2.3509
S9000 M3
Z.2
G1 Z-.485
Y2.2572 F30.
(Cutting...)
G1 Y2.3509
G0 Z.25
X-.0938 Y2.3459
Z.2
G1 Z-.485 F100.
Y2.2522 F30.
(Cutting...)
G1 X0.
G1 Y2.3459
G0 Z2. M9
G90 G53 Z0. M5
G53 Y0.
M1
T1 M6
