Tapping feed decimal places
Ok, fmt for "F" is 15, so fs2 15 is my feed format line, correct?
Is this statement "fs2 15  0.2 0.1", stating 2 places after the decimal in inch mode & 1 place after the decimal in metric?
If so, as understand it, I can change this to "fs2 15  0.4 0.2", and things should be good.
But is there a way that I can use 2places after for G94 feeds and 4 places after just for G95 feeds?
Yes.
#Default english/metric position format statements
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (:)
fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0     #Integer, not leading
fs2 5   2 0 2 0l    #Integer, force two leading
fs2 6   3 0 3 0l    #Integer, force three leading
fs2 7   4 0 4 0l    #Integer, force four leading
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
fs2 10  0.2 0.2     #Decimal, absolute, 2 place
fs2 11  0.3 0.3     #Decimal, absolute, 3 place
fs2 12  0.4 0.4     #Decimal, absolute, 4 place
fs2 13  0.5 0.5     #Decimal, absolute, 5 place
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place
fs2 16  0 4 0 3t    #No decimal, absolute, 4 trailing
#Default english/metric feed format statements
fs2 17  0.2 0.1     #Decimal, absolute, 2/1 place
fs2 18  0.4 0.3     #Decimal, absolute, 4/3 place
fs2 19  0.5 0.4     #Decimal, absolute, 5/4 place
fs2 20  1 0 1 0n    #Integer, forced output
fs2 22  0 4 0.3     #No decimal, absolute, 4/3 place
fs2 23  0 4 0 4lt   #no decimal, absolute, 4/4 place
fs2 25  1.4 1.3lt   #Decimal, absolute, 4/3 trailing
fs2 26  1.3 1.2lt   #Decimal, absolute, 3/2 trailing
fs2 27  0 5 0 5lt   #no decimal, absolute, 3/3 place
In this case use:
fmt  "F" 2  feed        #Feedrate
fmt  "F" 17 feed        #Feedrate
Notice that the "2" and the "17" correspond to the appropriate fs2 line.
Put this in your tapping postblock:
        if ipr_actv$ = 0,
          result = nwadrs(strf, feed)
          result = newfs (17, feed)
This will switch from fs2 2 to fs2 17 if using ipm.
Your values may be different you may need to substitute a few things to match
your post.  However, this will give the power to switch formatting on the fly
based on which mode your currently using.
Yes.
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize ( :)
In this case use:
        if ipr_actv$ = 0,
Awesome. Thanks I'm going to try this right now.
Zeke
I would not.  If you change that line you will break functionality somewhere down the road.  You can make a new one.  In this example, the last format is 27 so for instance I could make this new one on my post:
fs2 28  0.2 0.1     #Decimal, absolute, 2/1 place
        if ipr_actv$ = 0,
          result = newfs (
28, feed)
Ok, my last fmt is 22 so I created:
fs2 23  0.2 0.1      #Decimal, absolute, 2/1 place
But my tapping postblock looks like this:
ptap$            #Canned Tap Cycle
      pdrlcommonb
      result = newfs(17, feed)  # Set for tapping Feedrate format
      pcan1, pbld, n$, *sgplane, *sgdrlref, *sgdrill, prdrlout,
        prdrlrout, *feed, strcantext, e$
      pcom_movea
So do I replace the "newfs(17, feed)" section with the
if ipr_actv$ = 0,
          result = newfs (
23, feed)
section?
This postblock should do the trick for you.
       pdrlcommonb
       if ipr_actv$ = 0,
         result = newfs (23, feed)
#       result = newfs(17, feed)  # Set for tapping Feedrate format
       pcom_movea
Ok, cool, I just comment out the line, so that I can go back to my original if I break the post.
Thank you so much, I really appriciate your help.
Zeke
Whenever there is an asterisk * before a variable, it forces the post to output the value of that variable, no matter what. A lot of variables are modal and won't output if they didn't change from the last time they were called. Putting * in front of feed means it will output the feedrate on every line of the drill cycle. For example, this is what it might look like without the asterisk:
G98 G81 X0 Y0 Z-1. R.1 F25.
X1.
Y1.
G80
And this is what it will look like with the asterisk:
X1. F25.
Y1. F25.
G80
X1.
Y1.
G80
X1. F25.
Y1. F25.
G80
Thank you.
Zeke
I keep getting this error, using the above code:
PST LINE (1804) - The formula/boolean failed (general message), , Label has not been defined[26]
PST LINE (1804) - The formula/boolean does not terminate properly
What is the "strf" supposed to be defined as?
I guess it would help if I was a little more specific.
This is the code Im using that is generating the error:
       pdrlcommonb
       if ipr_actv$ = 0,
       pcom_movea
The nwadrs(strf, feed) line assigns a new string prefix to the feed variable. In order to use it, you have to define the string strf in the post.
strf         : "F"   #String for address F
  • 3 months later...
