Outpotting tool length
I'm updating a post from X6 to X9. Generic Fanuc 5X Router.pst. Using G10 L10 to set tool length and I'm missing something. Please help.
I'm trying to call from nci 20007 line, parameters 12 and 13. For the first tool change the nci is:
20007
0. 2.65 2.65 2.65 0.261 1.055 0.9 0 100. 26. 0 2.65 4.45
Posted code is:
(T5 .261 DAGGER DRILL)
(TOOL HEIGHT = 3.55) ---------------- should be 7.1--from holders parameters NCI 20007 12 & 13
(T1 3/16 OSG BNC)
(TOOL HEIGHT = 2.) ---------------- should be 5.873
G90
G10L2P1X85.662Y16.653Z-65.634B0C0
G10 L10 P5 R3.55 (.261 DAGGER DRILL) ----------------should be R7.1
G10 L10 P1 R2. (3/16 OSG BNC) ---------------- should be 5.873
From the post:
# Parameter Data
tmp1 : 0 # Holder and Overall Tool Length Values
tmp2 : 0
tmp3 : 0 # Overall Value
tmp4 : 0
tmp5 : 0
tmp6 : 0
tmp7 : 0 # Holder Value
fmt "" 2 set_length # Tool Set Length Holder + tool overall
pwrtt$ #Pre-read NCI file
if t$ > zero & t$ <> prv_t$,
t_n = t$
spaces$ = zero
sopen_prn, *t_n, 32, *strtool$, sclose_prn, e$
if str_mfgcode <> sblank,
str_mfgcode = ucase(str_mfgcode)
sopen_prn, *str_mfgcode, sclose_prn, e$
str_mfgcode = sblank
if str_chuck <> sblank,
str_chuck = ucase(str_chuck)
sopen_prn, *str_chuck, sclose_prn, e$
str_chuck = sblank
set_length = (tmp3 + tmp7)
subout$ = three
g10_p = tempf10
g10_r = set_length + tool_set
"G10 L10", 32, *g10_p, 32, *g10_r, 32, sopen_prn, *strtool$, sclose_prn, e$
subout$ = zero
sopen_prn, "TOOL HEIGHT = ", *set_length, sclose_prn, e$
*e$
spaces$ = prv_spaces$
!t$
pwrttparam$ #Pre-read parameter data
#"pwrttparam", ~prmcode$, ~sparameter$, e$
if prmcode$ = 20007 & use_tl_hldr, tmp1 = rpar(sparameter$, 13)
if prmcode$ = 20002, str_mfgcode = sparameter$
if prmcode$ = 20003, str_chuck = sparameter$
if prmcode$ = 20007, tempf1 = rpar(sparameter$, 12)
pparameter$ #Parameter Read
if prmcode$ = 20007 & use_tlength = one, temp1 = rpar(sparameter$, 3)
The 'rpar' function is setup to grab a range of variables and put them into an implied array. You are trying to grab individual parameters.
You either need to have a single line of code reading the 20007 parameter number, and setup 13 numeric variables to get all the values, or you need to use the 'rparsngl' function to grab just the individual parameter you are looking for. You aren't getting the data you think you are getting, because of the way the 'rpar' function works.
Thanks Colin. I changed the rpar to rparsngl the output values are all 0. now.
if prmcode$ = 20007 & use_tl_hldr, tmp1 = rparsngl(sparameter$, 13)
if prmcode$ = 20004, tempf1 = rparsngl(sparameter$, 12)
if prmcode$ = 20007 & use_tlength = one, temp1 = rparsngl(sparameter$, 3)
