Canned drill cycle wont output Q
Hi all!
I'm trying to get my post to ouput depth of cut on a canned drill cycle, I've not been successful in doing so.
Here's my postblock for my canned drilling cycle:
ldrill$          #Canned drill cycle, lathe
      #Use this postblock to customize lathe drilling cycles 0 - 7
      pdrlcommonb
      pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout,
      prdrlout, dwell$, pffr, strcantext, e$
      pcom_movea
      pcanceldcl
 This is the result code:
G98 G83 Z-.052 R.1 F.01
Guest MTB Technical Services
Hi all!
      pdrlcommonb
      pcom_movea
      pcanceldcl
You aren't getting the proper output because you don't have the variable for the peck amount.
The required variable used to be peck1 .
Grafdude
Look for these lines:
fs2 16  0 4 0 3t    #No decimal, absolute, 4 trailing
fmt  "Q" 16  peck1$     #First peck increment (positive)
I would create a new fs2 so that nothing else is effected.
fs2 xx  0 5 0 4t    #No decimal, absolute, 5 trailing               add this line, use the next available number in your fs2 definitions for xx
fmt  "Q" xx  peck1$     #First peck increment (positive)        change your peck1 format,  xx to match the xx number assigned in your format statements
ipr_actv$ = 0
Add this into the beginning your peck drilling post block for IPM.  1 is for IPR.
mpeck$         #Canned peck drill cycle, mill
      ipr_actv$ = 0
      pdrlcommonb
        pcout, pindexdrl, prdrlout, *peck1$, dwell$, pfr, strcantext, e$   #pfclampon,
      pcom_movea
Thank you bd41612, that did the trick! Right now my post outputs feed on my peck drill cycle in inch per rev, I need them to be in inch per minute, any ideas?
That's actually controlled by the operation parameter itself.
You can force it in the post to be either way but I would check your op data.
