Need help with my SET file
I have changed an mill.set for my setup sheet, now it's nearly what i want.
Need some hel with the finishing touch.
  • I added an diameter output for an helixbore and an threading cycle.
Line 973 - 990
  • The header tells:    # This post supports output for 3 and 4 axis milling.
In my 5 axis pgm's the output is OK, but i get errors:
09 Jul 2015 02:33:55 PM - RUN TIME -OPID(51)- Only single-axis rotation is allowed!  Angles may be incorrect.
How to avoid these errors?
BTW the X-style coolant you see in not yet working, but that's an next step
Setup.zip
Hi Henk,
The MP Language has some 'command variables' that setup the internal processing for Tool Planes, to derive the rotary address from the Tool Plane Matrix.
Add this variable to the end of the variables in "Factory set and program switches":
rotaxtyp$ := c9k
That will fix the "only single axis rotation is allowed" error messages...
