Z MIN ZMAX in tool table
I need help for the post guru's.
I have been researching this forum for an answer to this. I cannot find one. I have been beating my brains out for a week with no luck. :wallbash:
My tooltable looks like this :
O1000 (VF-3 START-OP10.NC)
(OK --- 00-00-00)
(DATE- 7/14/2015 TIME - 18:36)
(CUSTOMER - S:\)
(MCX9 FILE - VF-3 START)
(MATERIAL  - 1/2" THK A36 STEEL PLASMA BLANK)
(PART NAME:)
(HOLD PART IN VISES)
(SET X ZERO ?)
(SET Y ZERO ?)
(SET Z ZERO ?)
(T1 = .1875 DIA. X 60 DEG. #2 CENTER DRILL - H1 - MAX Z = -99999.MIN Z = 99999.)  ** I cannot get this line correct it is one behind. :censored:
(T1 - TOOLHOLDER = KCV50BTGF100275 / OOH = 1.)
(T2 = .75 DIA. X 120 DEG. SPOTDRILL - H2 - MAX Z = 6.MIN Z = -.2)
(T3 = .4219 DIA. X 135 DEG. 27/64" DRILL - H3 - MAX Z = 6.MIN Z = -.3)
(T4 = .375-16 3/8-16  SPIRAL POINT TAP - H4 - MAX Z = 6.MIN Z = -.4)
(T6 = .201 DIA. REAMER - H6 - MAX Z = 6.MIN Z = -.5)
(T10 = .5 DIA. 5FL.1/2" CARB E.M. 1.25 LOC - H10/D10 - MAX Z = 6.MIN Z = -.6)
(T11 = .5 DIA. 4FL.1/2" CARB BALL EM 1. LOC - H11/D11 - MAX Z = 6.MIN Z = -.7)
(T12 = .5 DIA. 4FL. 1/2" X 45 DEG CARB CHAMFER MILL - H12/D12 - MAX Z = 6.MIN Z = -.8)
(T13 = 3.15 DIA. 6FL.X 45 DEG FACE MILL W / .039 RAD - H13/D13 - MAX Z = 6.MIN Z = -.91)
(T14 = 7. DIA. 26FL.X .87 WIDE SAW W\.38 CORNER RAD. W / .38 RAD - H14/D14 - MAX Z = 6.MIN Z = -1.)
(T15 = .115 TIP DIA. W/.125 RAD 3FL. CARB CORNER ROUNDING EM - H15/D15 - MAX Z = 6.MIN Z = -1.1)
(T16 = 1.515 DIA. 4FL.1-1/2" DIA X 3/4 LOC 60 DEG CARB DOVETAIL CUTTER .735 LOC - H16/D16 - MAX Z = 6.MIN Z = -1.2)
(T17 = .125 TIP DIA. X 30 DEG. 4 FL.EM CONICAL-U202C .5 LOC - H17/D17 MAX Z = 6.MIN Z = -1.3)
(T18 = .5 DIA. 4FL.X 3.75 SHANK GRIND HARVEY TOOL 997132-C3 .427 LOC - H18/D18 - MAX Z = 6.MIN Z = -1.4)
(T19 = .5 DIA. 5FL. 1/2" CARB E.M. 1.25 LOC - W /.03 RAD - H19/D19 - MAX Z = 6.MIN Z = -1.5)
(T20 = M12 X 1.75 SPIRAL FLUTE TAP - H20 - MAX Z = 6.MIN Z = -1.6)
(OVERALL MAX Z = Z6.)
(OVERALL MIN Z = Z-1.7)
N5G94G00G17G20G40G80G90
N10G91G28Z0.M19
N15G0G90G53Y0.
N20T1M06
(T1 = .1875 DIA. X 60 DEG. #2 CENTER DRILL - H1)
(CENTER DRILL LOCATIONS - ID # 2)
(MAX Z = 6.MIN Z = -.2) *** here the line is correct
N25G00G17G90G54X0.Y0.S1333M03
N30G43H1Z6.M08T2
The above is unedited straight from the post.
A related post : tooltable output current tool cut max/min depth error
Started by Lee1, Nov 21 2013 08:15 AM
I know its about the .txt file for the buffer
1001. 99999. -99999.< here
1002. -0.2 6. < here
1002. -0.3 6.
1002. -0.4 6.
1002. -0.5 6.
1002. -0.6 6.
1002. -0.7 6.
1002. -0.8 6.
1002. -0.91 6.
1002. -1. 6.
1002. -1.1 6.
1002. -1.2 6.
1002. -1.3 6.
1002. -1.4 6.
1002. -1.5 6.
1002. -1.6 6.
0. -1.7 6.
I just can't get it to increment correctly and not screw up the tool call up numbers.
Has this ever been solved. I know one of you BUFFER guru's has figured this out. :yes
My beer budget is taking a beating over this one. :beer:
