Repeating Initial Drill points
Hi Guys!
 I have a question. I am developing apost for an old Anilam Control that the drill cycle needs the initial output of x and y repeated after the drill cycle callout. I tried inserting a pfxout, pxyout after the drill call, but then I get doubles of every x and y output for that cycle. Does anyone know how to get just the initial points to repeat?
As always thanks for the help.
Todd
*18795-NEST*N100 G20N110 *SPOT DRILL  .266 HOLES 12X*N120 T1 M06 *  1/2 SPOTDRILL*N130 S6500 M03G53 O1N140 G00 G90 X40.5845 Y19.8<----- this line needs to be repeated belowN150 H1 Z2.N160 G81 Z-.1 R.25 F6.N170 G0 Z2.<------------before this lineN180 G0 X41.872 Y22.03N190 G0 Z2.N200 G0 X44.447 Y22.03N210 G0 Z2.N220 G0 X45.7345 Y19.8N230 G0 Z2.N240 G0 X44.447 Y17.57N250 G0 Z2.N260 G0 X41.872 Y17.57N270 G0 Z2.N280 G0 X42.7875 Y8.98N290 G0 Z2.N300 G0 X44.075 Y6.75N310 G0 Z2.N320 G0 X42.7875 Y4.52N330 G0 Z2.N340 G0 X40.2125 Y4.52N350 G0 Z2.N360 G0 X38.925 Y6.75N370 G0 Z2.N380 G0 X40.2125 Y8.98N390 G0 Z2.N400 G80N410 M05N420 M2
Hi Todd,
Normally, Drill Cycles are processed using two different post blocks. The first hole is 'NCI Gcode 81', and calls 'pdrill$' for output.
Every "additional" hole is 'NCI Gcode 100', and calls 'pdrill_2$' for output.
Your post is likely so old that 'pdrill_2$' is probably setup to call 'pdrill$' for additional cycles.
Try making sure that your 'force' code is only after the cycle output in 'pdrill$', and then check 'pdrill_2$', and see what the output is there. You may have to modify 'pdrill_2$' to output what you need...
