Cutter comp restriction
I need to restrict our cutter comp to a linear move. Our Mazaks do not allow cutter comp to be set on a circular interpolation move (G41 or G42 on these machines). Does anyone know how I can create this restriction in our post? This is our Cutter comp section of the post:
pccdia          #Cutter Compensation
      #Force Dxx#
      if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
      sccomp
      if cc_pos$, tloffno$
      !cc_pos$
Zeke
On the helix bores, if you have a perpendicular entry checked it won't have an issue with the start of the cutter comp.  The only way I know to fix it at the end is hand edit.  Or, you could use a ramp contour in place of the helix bore and as long as your lead in lead out isn't too big you won't have an issue. Same should prove true for 2D contours.  As long as you have ample space for the lead in and lead out, you shouldn't have it placing cutter comp values on arcs.
  • 1 month later...
One quick thought about this, If you remove the pccdia command from your arc move wont that remove your cc entirely, and doesn't that make the whole thing meaning less?
I only ask because I am having the same issue and tried to delete my cc from the arc line and then force cc in the next line but it never came.
I program for nothing but mazaks, 3 to 6 axis.
Don't mess with your post, handle this in the tool path. For helix bore, do perpendicular entry.
For 2d contours do perpendicular and you can still put a radius on it and it will work. Make sure your lead in is enough to absorb cc on and off.
helix cutter comp setting
start at center
change arc on from 180 degrees to 90 degrees
you'll get at straight line from the center followed by an arc into the cut
I have trouble with helix bores & 2D contours.
Trick I learned on here for using 2d contour.
(hole diameter-endmill diameter)/2 x .4142= both length and radius
use a 135 degree entry angle and select tangent
Puts the tool in the center of the hole and has a nice straight lead in/out for cc before arcing onto the chain.
