Moving A-axis position with initial X,Y moves.
Hey Guys, my current Post positions the A-axis when I'm down on the part.  Where in the post do I move my A positioning move?    I'm using a Generic Haas Post.  I don't want to switch posts because of all the work I've done to this one.  TIA
O1112( 8606788-001-3 )
( T10 |  NO. 13 DRILL | H10 | DIA: .185 )
( T12 | COUNTER SINK - 0.5 | H12 | DIA: .5 )
( T14 | 0.155 FINE BORING TOOL | H14 | DIA: .155 )
G20
G0 G17 G40 G49 G80 G90
G91 G28 Z0 ( ROTARY X-FORM )
T10 M6 (  NO. 13 DRILL | T: 10 | D: 10 | H: 10 | DIA: .185 )
G0 G90 G55 X0. Y1.75 S2581 M3   <-------------TO HERE
G43 H10 Z.1 T12
/M8
G98 G81 Z-.9583 A-40. R-.395 F10.324   <--------------FROM HERE
G80
M9
M5
G91 G28 Z0.
M01
N12 G91 G28 Z0
G80 G49 G40 G20 G17
Reference Link:  http://www.emastercam.com/board/topic/82193-using-my-a-axis-rotary-as-a-c-axis/
Are you sure you are using the generic Haas 4th axis post? are you using axis sub to do the drilling like this.
(TEST)
(DATE=DD-MM-YY - 07-08-15 TIME=HH:MM - 07:37)
(MCX FILE - V:\TRAINING FILES FOR CLASS'S\SAMPLE WITH PATHS\AXIS SUB.MCX-9)
(NC FILE - C:\USERS\JKRAMER\DOCUMENTS\MY MCAMX9\MILL\NC\TEST.NC)
(MATERIAL - ALUMINUM INCH - 2024)
(T1|1/4 DRILL COBOLT EXT1.|H1|D1|TOOL DIA. - .25)
N100 G20
N110 G0 G17 G40 G49 G80 G90
(DRILLING USING ROTARY AXIS POSITIONING)
N120 T1 M6
N130 G0 G90 G54 X-13. Y0. A80.14 S1833 M3
N140 G43 H1 Z13.
N150 M8
N160 G98 G83 Z4.9149 R6.25 Q.1 F14.7
N170 G80
N180 M5
N190 G91 G28 Z0. M9
N200 G28 X0. Y0. A0.
N210 M30
Yessir
No Axis sub, just X-form Toolpath>Rotate by Toolpane.  It's rotary work, but more like flat ro-tab work.  I'm basically drilling holes in a wheel, with the machine making 1 Y move to position on the bolt circle, then drilling and boring, and moving to the next hole via A-axis rotation.  We're trying to see if we can hold a tight TP this way instead of having the table move to each position.
   Is my post set-up why the A move is in with the drilling move?
Will the machine not hold the true position? If you are fighting TP because the machine just won't hold it you'll be fighting it as long as it is running that part with the scrap piling up.
Play the tolerance game, run on the LMC side to get the most out of that TP call out. Unless it's regardless of feature size.
The place you would normally move the Rotary output inside the post is the 'psof$' post block. If this is MPMaster you are using, then you might just need to "force" rotary output when working in the "Top" Plane.
Try finding this line in 'pwrtt$' and uncommenting the line...
           #sav_rot_on_x = rot_on_x    #Uncomment this line to output rotary axis value even when it's not used
Hey Guys, thanks for all the replies.  I've been hesitant to switch posts because of all the mods I've made over the years to my Generic Haas.  I switched to MP Master, and am slowly trying to add-in all the features I had with my old post.  BTW, A-axis output works now   :guitar:   I'll start a new thread on some help I need with this post.
