wire edm path for an involute spline
shazam/TPP
That's the thing about gears is that you should only need the DP, Number of teeth and Pressure angle but they always seem modified. I inputted every number you show on Esprit and can send it to you if you send me your email addy.
Did you draw in the pins and check across the pins? Since it in an odd will have to use a tri-mic if testing with a mic, but for drawing put in 3 pins and then make a circle using tangent to 3 circles and you will be able to check your shape PD.
When I inputted values it gave me a different meas over the pins by about .005 so I inputted his desired meas given on print.
I wire gears from time to time but prefer to have the mating part when I do.
between cathedral and what Ron recommended, i had to play with the "circular tooth thickness"
