5 Axis Post not unlocking/locking Axis'
tim_h
My 5x post isn't putting in the codes for unlocking and locking the axis' except for at the tool changes...
Is this a switch somewhere in the post processor ?
THANKS !
M11 UNLOCKS A
M69 UNLOCKS B
T1
M6
G0 G54 G90 X0. Y.6 A-30. B90. S3820 M3
T2
M10 LOCKS A
M68 LOCKS B
G43 H1 Z2. M8
Z1.4693
G1 Z1.3415 F30.
Y.75
Y1.
Y1.15
G0 Z1.4415
G0 Z2.
NOT UNLOCKING HERE
G55 X0. Y.6 Z2. A-120. B90.
NOT LOCKING HERE
Z1.4693
G1 Z1.3415
Y.75
(.031 EM / .15LOC |TOOL - 3|DIA. OFF. - 3|LEN. - 3|TOOL DIA. - .03125)
M11
M69
T3
M6
G0 G58 G90 X0. Y1.5411 A-46.5 B50. S7000 M3
T4
M10
M68
G43 H3 Z2. M8
I just discovered this issue myself today.
Lemme guess, you edited this, right;
#Work offsets
workofs$     : -1    #Initialize work offset
force_wcs    : yes$  #Force WCS output at every toolchange?
use_frst_wcs : yes$  #Use only the first WCS read and ignore all others in NCI  <-------------------If you change this to "yes" it'll work, if you change it to "no", it doesn't work.
I don't have a fix yet, but I'm looking into it.
Jay
I have now assigned wcs outputs to the planes (G54 and G55)... and I have an unlock/lock now, however I need a "M11-M10" and i'm getting "M69-M68".
M11 M10 are for the "A axis"
M69 M68 are for the "B axis"
I tried switching these from Primary Axis Lock/Unlock to Secondary Axis lock/Unlock, but get the same result.
I did try and change the use_first_wcs but it didn't make a difference. I'll play around some more later.
Thanks a bunch !
M11
M69
T1
M6
T2
M10
M68
G43 H1 Z2. M8
Z1.4693
G1 Z1.3415 F30.
G0 Z2.
M69         unlocks B
A-120.     this is an A rotation but it's still locked
M68         locks B
Y.6
  • 2 months later...
I revisited this today and still can't figure out how / where to change to get an M11 / M10 output when the A rotates and the B is still at 90 degrees...
5th axis trunnion sitting on a vertical mill.
The initial unlock/lock works fine, but not when just the A needs to re-position... getting the m-codes for B unlock/lock
Thanks in advance
tim
My guess is someone messed with the post for whatever reason and the locking unlocking isn't being updated properly.....or depending not even set to output....
I think this one will be tough without diving into the [ost itself.....
A call to your reseller woulds be in order
I am still waiting for a response to an e-mail that I sent him in last JUNE ... :thumbdown:
I appreciate your advice though.
THANKS
June? and you've never called to follow up?
then I would go right to posts at mastercam dot com
