4th axis Gear
jameszhawks
Well seeing how they are not cutting that gear correctly not sure why you would want to follow that process, but if you do then a Basic Contour will do most of the work. Then a Curve 5 Axis will be the way to make the tool curve into the part at the edges. Again I don't consider that the correct way to machine a gear kicking the tool into one side of it and the other side of it. The Radius of the tool would create a scallop that would not be correct through the entire profile of the gear. What I have done is used a gear cutter and done a simple contour toolpath. If I was worried about how much the stock the gear cutter had to cut then I might do a center cut and then come back and cut with the gear cutter. What class of gear are you trying to machine?
My understanding is that these are custom form tools from sandvik that have been designed for spur gears. The custom tools cut the gear correctly and accurately using a there InvoMilling software, do a google search on it there is some info out there. The software was developed by Sandvik together with one of the gear guru's maybe Stepan Lunin or similar
