Duplicate I and J
Hello Forum,
   I'm using CIRCLE MILL function and there are some duplicate I, J values.  Is there, away we can eliminate that?  Thank you for your responds.
N1(.1250, 1/8 EM, CB,)
(2FLTS .500LOC, .63LOH)
G0 G17 G40 G49 G80 G90
G53 Z0. M19
T1 M6(Rough and finish 12x c'bores, CUT#3)
(1x .005 MULTI-ROUGH)
(1x .005 MULTI-FINISH)
G90 G54
X-2.738 Y-.6598 S48869 M3
G43(D1)H1 Z1. M8(DOC= Z-.181)
G90 Z.0625
G1 Z.01 F500.
G3 X-2.738 Y-.6598 Z.0031 I-.004 J.0048 F110.
X-2.738 Y-.6598 Z-.0038 I-.004 J.0048
X-2.738 Y-.6598 Z-.0108 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0177 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0246 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0315 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0385 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0454 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0523 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0592 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0662 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0731 I-.004 J.0048 ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.08 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0869 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.0939 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1008 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1077 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1146 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1216 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1285 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1354 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1423 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1493 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1562 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.1631 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.17 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.738 Y-.6598 Z-.177 I-.004 J.0048  ==========> Duplicate "I", "J" values
X-2.746 Y-.6502 Z-.1804 R.0062
X-2.7479 Y-.6529 Z-.181 R.0062
X-2.7479 Y-.6529 I.0059 J-.0021
X-2.7155 Y-.6645 R.0172
X-2.7891 Y-.6382 R-.0391
X-2.6743 Y-.6792 R.061
X-2.8303 Y-.6234 R.0828
X-2.6331 Y-.694 R.1047
X-2.8715 Y-.6087 R-.1266
X-2.5919 Y-.7087 R.1485
X-2.9127 Y-.5939 R.1704
X-2.5508 Y-.7234 R-.1922
X-2.742 Y-.4375 R.214
Y-.8725 R.2175
Y-.4375 R.2175
X-2.8508 Y-.5463 R.1088
G1 X-2.742 Y-.655 F10.
Y-.5437
G41 D1 X-2.6307
G3 X-2.742 Y-.4325 R.1113
X-2.742 Y-.4325 J-.2225
X-2.8533 Y-.5437 R.1112
G1 G40 X-2.742
Y-.655
G0 Z1. M9
G0 G90 G53 Z0. M5
G53 Y0.
M1
G0 G90 G54 X0.
Assuming you are using the mplmaster post what you are looking for is this
#Arc output for IJK
        #If you do NOT want to force out the I,J,K values,
        #remove the "*" asterisks on the *i, *j, *k 's below...
        if plane$ = zero, iout, jout, kout #XY plane code - G17
        if plane$ = one, iout, jout, kout  #YZ plane code - G19
        if plane$ = two, iout, jout, kout  #XZ plane code - G18
        !i$, !j$, !k$
Open up the post, and search for parc. Then as is says, remove the asterisks on the I,J,K. I already took mine out
PcRobotic, if you want to cut an arc you NEED the I & J values there. Now if "I" or "J" were at zero, then you would not need whatever one was at zero...example
X-2.738 Y-.6598 Z-.0108 I0. J.5
The "I" is not necessary on most machines. on some controllers it is necessary.
What can be eliminated with your code example is the X & Y moves....
So something like this
G43 H1 Z.1
G1 Z0. F15.
G41 D1 X.125 Y.125 F25.
G3 X0. Y.25 I-.125 J0.
X0. Y.25 Z-.08 I0. J-.25
X0. Y.25 Z-.16 I0. J-.25
X0. Y.25 Z-.24 I0. J-.25
X0. Y.25 Z-.32 I0. J-.25
X0. Y.25 Z-.4 I0. J-.25
X0. Y.25 Z-.48 I0. J-.25
X0. Y.25 Z-.56 I0. J-.25
X0. Y.25 Z-.64 I0. J-.25
X0. Y.25 Z-.72 I0. J-.25
X0. Y.25 Z-.8 I0. J-.25
X0. Y.25 I0. J-.25
X-.125 Y.125 I0. J-.125
G1 G40 X0. Y0.
G0 Z.1
can be cut down to this:
G43 H1 Z.1
G1 Z0. F15.
G3 X0. Y.25 I-.125
Z-.08 J-.25
Z-.16 J-.25
Z-.24 J-.25
Z-.32 J-.25
Z-.4 J-.25
Z-.48 J-.25
Z-.56 J-.25
Z-.64 J-.25
Z-.72 J-.25
Z-.8 J-.25
J-.25
X-.125 Y.125 J-.125
G1 G40 X0. Y0.
G0 Z.1
Once again this will work on most machines but not all
Not trying to sound like an @ss...but you really should have a grasp on this stuff before you go messing with posts
G43 H1 Z.1
G1 Z0. F15.
X0. Y.25 I0. J-.25
G1 G40 X0. Y0.
G0 Z.1
G43 H1 Z.1
G1 Z0. F15.
G3 X0. Y.25 I-.125
Z-.08 J-.25
Z-.16 J-.25
Z-.24 J-.25
Z-.32 J-.25
Z-.4 J-.25
Z-.48 J-.25
Z-.56 J-.25
Z-.64 J-.25
Z-.72 J-.25
Z-.8 J-.25
J-.25
X-.125 Y.125 J-.125
G1 G40 X0. Y0.
G0 Z.1
Hi MIL-TFP,
  How may I cut down to the point as you suggest? Can you assist me how to do it?
Thank you,
   S.Luong
