Custom Tap
Hello everyone,
   I defined tap codes for Mitsubishi control and I did not get the second point out put, suppose I have two points to be tapped.  I think I did something wrong and I tried for the last 2 days but didn't work.  Please help, thank you.
pdrlcst$         #Custom drill cycles 8 - 19 (user option)      pdrlcommonb      #RH/LH based on spindle direction      #if rigid_tap, pbld, no_spc$, *sm29, *speed, e$           #Rigid Tapping      if depth$ < zero & refht$ < zero,        [        tdoc = depth$ + abs(refht$) #Calculate total cutting depth        ]      else, tdoc = depth$ + refht$ #Calculate total cutting depth      if tdoc <> min_depth, "(", no_spc$, *tdoc, no_spc$, ")", e$      if drillcyc$ = 8, prigid_tap      if drillcyc$ = 9, pdrlcst10 #Mitsubishi tap codes      if drillcyc$ = 10, pdrilldeep      pcom_moveapdrlcst10         #Akira Seiki custom tap      #RH/LH based on spindle direction      #"DEBUG: metvals: ", ~metvals, e$      if met_tool$,        [        if metvals, pitch = n_tap_thds$  #Metric NC Code - Metric Tap        else, pitch = (1/n_tap_thds$) * 25.4  #Metric NC Code - English Tap        ]      else, #Inch mode        [        if metvals,  pitch = (1/n_tap_thds$) * 25.4  #Metric NC Code - English Tap        else, pitch = n_tap_thds$           #English NC Code - English Tap        ]      result = nwadrs("E", pitch) #Assign 'pitch' to use letter E      if dwell$,        [        result = newfs(4, dwell$)        ]      if shftdrl$,        [        result = newfs(2, dwell$)        dwell$ = shftdrl$        ]     # if retr$, #Used for "Before Mcode"      #  [     #   result = newfs(4, retr$) #Output as Integer      #  result = nwadrs("M",retr$) #Change output string to "M"      #  ]      #pbld, no_spc$, *retr$, *speed, "(RIGID TAP)", e$      retr$ = zero      speed = sav_speed #Restore speed value, saved in ptlchg_com      pcan1, pbld, no_spc$, *sgdrlref, *sg84, pxout, pyout, pfzout,        prdrlout, *pitch, *speed, !feed, [if dwell$, *dwell$], ptapr, strcantext, e$      pcom_moveaptapr  # "R" output for Akira Seiki tap      if met_tool$, #Metric NC Code        [        if metvals, ",R1"  #Metric NC Code - Metric Tap        else, ",R1"             #Metric NC Code - English Tap        ]      else, #Inch NC Code        [        if metvals, ",R1_metric"  #English NC Code - Metric Tap        else, ",R1"             #English NC Code - English Tap        ]
 pdrlcst_2$ #Custom drill cycles 8 - 19, additional points (user option)
      #Use this postblock to customize drilling cycles 8 - 19      if drillcyc$ = 8, pdrill_2$      if drillcyc$ = 9, pdrlcst10 # Mitsuibishi Tap Second Point      if drillcyc$ = 10, pdrilldeep
=========== G-CODES==================
N16(.3200, 1/8-27 NPT CUT TAP, FLAT BOTTOM, HSS,)
(4FLTS .775LOC, 1.25LOH)
G0 G17 G40 G49 G80 G90
G53 Z0. M19
T16 M6(TAP 2X 1/8-27 PIPE THREAD, CUT#69)
G90 G54 M45(MIST BUSTER ON)
X.8 Y-1.1125  ==========> This location is GOOD
G43 H16 Z1. /M8(DOC= Z-.625)
(TDOC= -.5938)
G98 G84 Z-.625 R.0313 E27. S269 ,R1
G98 G84 Z-.625 E27. S269 ,R1 ==========> This should be another location of X and Y value instead of "G98 G84 Z-.625 E27. S269 ,R1"
G80 M9
G90 G53 Z0.
G53 Y0.
G54 X0.
