MACRO COUNTER HELP
I'm trying to make a macro counter that will count parts using #100 between 06.00 in the morning and 18.00 in the evening and #101 for counting nightshift parts between 18.01pm and 05.59am.
think I have the dayshift sorted but getting hung up on the nightshift counter!!
O7999(COUNTER)
(#3012 SYSTEM CLOCK)
N100
IF[[#3012GT060000]AND[#3012LT180000]]THENGOTO3
IF[[#3012LT060000]AND[#3012GT180000]]THENGOTO4
N200
N1
IF[#3012LT055959]GOTO4
N2
IF[#3012LT180000]GOTO3
GOTO300
N3
#100=#100+1(DAY COUNTER)
GOTO300
N4
#101=#101+1(NIGHT COUNTER)
N300
M99
can anybody see where I'm going wrong or even point me in the right direction
TIA
I've made counters like this in Siemens before but never in Fuhnook.
In Siemens I always had to asign the system variable for the clock to another variable to use it.
So try #103=#3012 and then use #103 in your evaluation.
Also, in my Fuhnookish experience you don't want to use #100's. Every machine I've had my hands on used that range for Renishaw or system macros. Start at #500 and go up.
jlw is right about using variables in the #100 range. You need to be careful which ones you use. Sometimes it is useful to check the macro variables prior to using a new program. If you didn't put the value in it then it is likely that variable is used by a canned cycle.
The variables in the #500+ range are better suited to your application (persistent part count across shifts) since they will survive a power cycle.
I don't see a path to N1 or N2 in your program. What are they for?
Can you describe the problem with the night shift counter?
Custom-Macro-Quick-Reference-1.pdf
This is what I figured, referencing something that is changing every second wont help!
The #500 are better, just got to work out which ones the Renishaw probe are not using. The N1and N2 were from earlier attempts.
Now have it working, with a few extra bits that should store the previous shifts count in another variable and reset the new shifts count.
O9007(COUNTER)
#105=#3012
#106=#3011
N100
IF[[#105GT060000]AND[#105LT180000]]THENGOTO3
IF[#105LT055959]GOTO4
IF[#105GT180000]GOTO4
GOTO300
N3
IF[#101EQ0.0]GOTO6
#103=#101
#101=0.0
N6
GOTO300
N4
IF[#100EQ0.0]GOTO7
#102=#100
#100=0.0
N7
N300
I have also added this to the M30 call set in the M/c parameters, i.e M30 will call and run this protected sub and then end and rewind after it is read.
I see you got it working by splitting your night shift test
I noticed on your original code, you have an "AND" where there should be an "OR" (Not sure if you can use OR in these macros, I am new to this)
But you can not be LT 0600 and GT 1800 at the same time.....
If you can combine this back together, might save the machine some processing steps.
At home so I haven't tested this but I think it will work.
O9007(COUNTER)
#105=#3012
#106=#3011
(DAY SHIFT
IF[[#105GT060000]AND[#105LT180000]] THEN #100=#100+1(DAY COUNTER)
IF[#101NE0.0] THEN #103=#101
IF[#101NE0.0] THEN #101=0.0
(NIGHT SHIFT
IF[[#105LT055959]OR[#105GT180000]] THEN #101=#101+1(NIGHT COUNTER)
IF[#100NE0.0] THEN #102=#100
IF[#100NE0.0] THEN #100=0.0
