Conditioning on ACTIVE REPORT
PcRobotic
Hello everyone,
   I'm very new in ACTIVE REPORT and I don't know where to start with writing "IF, ELSE" conditioning.  I hope you guys can point me to the right direction.
Suppose I would like to make like this:
IF TIP ANGLE>0 then APPEAR with RED color
IF TIP ANGLE = 0 or N/A then DISAPPEAR or DO NOT SHOW.
Tool Sheet Screenshot:
https://drive.google.com/file/d/0B4UZsmondnEza2owUC1sanpsRUk/view?usp=sharing
Active Report Screenshot:
https://drive.google.com/file/d/0B4UZsmondnEzQXZENllURWtRLWM/view?usp=sharing
Here is what I think it would be but I only can make it RED COLOR and I cannot make it disappear. Please see details below.  Thank you.
If (IsNumeric(txtTIP_ANGLE1.Text)) Then
    If (CDbl(txtTIP_ANGLE1.Text) > 0) Then
        txtTIP_ANGLE1.Forecolor = Color.Red
        Label6.Forecolor = Color.Red
    Else
        txtTIP_ANGLE1.Forecolor = Color.LightGray
        txtTIP_ANGLE1.Text = "0"
       Label6.Forecolor = Color.LightGray
End If
Try something like:
int TipAngle;
int.TryParse(txtLabelTipAngle.Text, out TipAngle);
// TipAngle will be 0 if TryParse failed
If (TipAngle > 0) {
    txtLabelTipAngle.Forecolor = Color.Red
} else {
    txtLabelTipAngle.Visible = false
Hi Themachinist,
   I tried your codes and it had so many error.  Do you think I should add some new codes into my existing codes?
If (IsNumeric(txtTIP_ANGLE1.Text)) Then  =========> It's working now
   If (CDbl(txtTIP_ANGLE1.Text) > 0) Then   =========> It's working now
      txtTIP_ANGLE1.Forecolor = Color.Red  =========> It's working now
     Label6.Forecolor = Color.Red                   =========> It's working now
End If                                                               =========> It's working now
If (IsNumeric(txtTIP_ANGLE1.Text) <= 0 ) Then    =========> It's NOT working now
    If (CDbl(txtTIP_ANGLE1.Text) <= 0) Then        =========> It's NOT working now
            txtTIP_ANGLE1.Text = "0"                       =========> It's NOT working now
            txtTIP_ANGLE1.Forecolor = Color.Blue  =========> It's NOT working now
          Label6.Forecolor = Color.Blue                  =========> It's NOT working now
End If
Try something like:
int TipAngle;
If (TipAngle > 0) {
} else {
Hi TheMachinist,
   First of all, thank you for your help.  After 2 days of figure things out.  This is what I came up with and it is perfect as I wanted.  I hope that if someone who has the same problem as I have, this is "IT" to write conditioning IF, ELSE...
If (IsNumeric(txtTIP_ANGLE1.Text) = 0) Then
     End If
End If
     txtTIP_ANGLE1.Forecolor = Color.Black
    DEG.Forecolor = Color.Black
   Else
     DEG.Forecolor = Color.LightGray
End If
Hi PcRobotic,
Sorry I was not able to get back to you quickly after you asked me to make the additional changes to your report code.
Instead of:
Else
End If
Try:
    txtTIP_ANGLE1.Visible = True
    DEG.Visible = True
Else
    txtTIP_ANGLE1.Visible = False
    DEG.Visible = False
End If
Here I tested this in AR6:
Sub ActiveReport_ReportStart
    Dim TipAngle as Integer
    ' TryParse will set TipAngle to 0 if it fails for some reason,e.g. Label1.Text not being a number or being set to null
    System.Int32.TryParse(Label1.Text, TipAngle)
    ' Because TryParse will set TipAngle to zero in all of our undesired cases we can reduce our logic to a single if statement, either the tip angle is greater than 0 or we want to hide the label
    If (TipAngle > 0) Then
        Label1.ForeColor = Color.Red
    Else
        Label1.Visible = false
    End If
End Sub
    Else
    End If
End Sub
Thank you for all of your help TheMachinist, it really helped.
