3d contour with arcs
jlw™
It's not surfacng. It's a perfect radius and center of ball. The middle i finish with a parallel path but the width has a -0./+.002 tolerance so i want cc. It works and outputs arc and it runs fine in the machine but backplot is whacky and verify will not run it at all.
I guess it's like axis sub, you just have to accept that it looks wrong and runs right.
Kick your tolerance down to .0001 and then move you slider to 95% and see what you get for NC output. I had .001 and was getting bad results off a sample I was putting together to show you how I would go about it. When I kicked it down to the tolerance and move the slider here is the output I got.
O0000 (Toolpath Group-2)
(MCX FILE  - T)
(PROGRAM   - Toolpath Group-2.NC)
(DATE      - FEB-24-2017)
(TIME      - 5:05 PM)
(T307 - 1/4 BALL ENDMILL     - H307 - D307 - D0.2500" - R0.1250")
G00 G17 G20 G40 G80 G90
G91 G28 Z0.
(COMPENSATION TYPE - WEAR COMP)
N0307 T307 M06
(MAX - Z13.0025)
(MIN - Z5.1609)
G00 G17 G90 G54 X4.2 Y5.125 S2139 M03
G43 H307 Z5.6609
G94 G01 G41 D307 Y5.375 F6.42
X4.
X3.7885 Z5.6608
G18 G02 X3.686 Z5.636 I.0062 K-.2499
G03 X2.497 Z5.282 I-1.686 K3.489
X1.2571 Z5.3219 I-.497 K3.843
X.3112 Z5.6373 I.7432 K3.8043
G02 X.2053 Z5.6609 I-.1059 K-.2264
G01 X0.
X-.2
G40 Y5.125
Z5.8609
G00 Z5.9109
M05
G91 G28 Z0.
G28 Y0.
G90
See if this looks like what you were trying to accomplish on the side.
https://www.dropbox.com/s/41z35o3nb9cq8fl/5th%20Axis%20Radius%20Cut%20with%20Arcs%20and%20Comp.mcam?dl=0
I would do the center like you want using the walls as check surfaces and then do the side walls like this and call it a day.
I looked at your file this morning. I posted using the .001 and got the same results you did. I changed it to .0001 regenerated the toolpaths using a Postability Post and got what I would consider good code. If you do it with .0001 and still get the same results change to a generic machine and see if you still get the same thing. Odd one you are fighting and something I would send in to your dealer or to posts (at) mastercam (dot) com as a .z2g file with mmd/cmd/pp and let either your dealer or them get to the bottom of.
Ron, Jay, Matt, thanks for the input guys.  I can not run wear, too big of a change to existing ways of the shop.  Ron, when I set it to 0.0001 I still get one op (op7) that is giving fits.  I would really like to not have to do any hand edits... I'm too freakin busy.  I'll look at it again tonight.  I did not try posting with another post.  However, posted code looks good regardless of backplot/verify.  In fact, it's been running.  I just want to know why mcam will not work properly with it.  For Ron tho, I did not get any arc until I cranked it to 0.0001in total tolerance.  That totally baffles me.  Guess I am thinking wrong about that slider.  I well play with it some tonight.
Thank you gentlemen.
