Retrieving chains by operation
Is there a way of getting an array of chains from a given operation? I'm writing my first nethook
and am wanting to process all chains that belong to the operations that were pre-selected by the user.
I've seen:
ChainManagerMode.GetOperationChains
in the API Reference Guide, but don't know how to apply this. Any help would be appreciated. Thanks.
In the NET-Hook API Reference
I drilled down to Mastercam.Operations
Selected the Operation type I’m interested in (e.g. ContourOperation)
and in its Methods section I see GetChainArray – “This method retrieves the Chains in this operation.”
What are you trying to do with the Chains?
What type(s) of Operations are you "processing"?
I am trying to reverse the chains, and before reversing the chains, store in a variable if the operation is using
left or right cutter comp. Then after reversing the chain set the cutter comp back to what it was previously.
This is what I have so far:
Public Overrides Function Run(ByVal param As Integer) As MCamReturn
            'Make sure there are operations to modify
            Dim ops As Array = Mastercam.Support.SearchManager.GetOperations().ToArray
            If ops.Length = 0 Then
                Debug.WriteLine("There Are No Operations To Modify")
                Return MCamReturn.FunctionExit
            End If
            Dim bSelect As Boolean = False
            'Loop through all operations to see if there are any selected
            For i As Integer = 0 To UBound(ops)
                Dim op As Mastercam.Database.Operation = CType(ops(i), Mastercam.Database.Operation)
                If Not op Is Nothing Then
                    If op.Selected = True Then
                        bSelect = True
                        Exit For
                    End If
                End If
            Next i
            'If there are no selected operations then let's exit
            If bSelect = False Then
                Debug.WriteLine("There Are No Selected Operations To Modify")
            End If
            'Process all selected operations
            Dim bSuccess As Boolean = LoopThroughSelectedOps(ops)
            If bSuccess = True Then
                MsgBox("Chains Reversed And Flipped")
            Else
                MsgBox("Error Reversing Chains")
            End If
            Return MCamReturn.NoErrors
        End Function
Here is the code from my module:
Public Sub ReverseChains(ByVal OpToRegen As Mastercam.Database.Operation, ByVal chains As Array)
        If chains.Length = 0 Then Exit Sub
        For i As Integer = 0 To UBound(chains)
            Dim chain = CType(chains(i), Mastercam.Database.Chain)
            If chain.Direction = Mastercam.Database.Types.ChainDirectionType.Clockwise Then
                chain.Direction = Mastercam.Database.Types.ChainDirectionType.CounterClockwise
            ElseIf chain.Direction = Mastercam.Database.Types.ChainDirectionType.CounterClockwise Then
            End If
            OpToRegen.Commit()
            OpToRegen.Regenerate()
        Next i
    End Sub
    Public Function LoopThroughSelectedOps(ByVal OpsToProcess As Array) As Boolean
        Dim TheAnswer As Boolean = False
        If OpsToProcess.Length = 0 Then
            TheAnswer = False
            Return TheAnswer
            Exit Function
        End If
        For i As Integer = 0 To UBound(OpsToProcess)
            Dim TheOp As Mastercam.Database.Operation = CType(OpsToProcess(i), Mastercam.Database.Operation)
            If TheOp IsNot Nothing Then
                If TheOp.Selected = True Then
                    If TheOp.Type = Mastercam.Database.Types.OperationType.Contour Then
                        Dim ContourOp As Mastercam.Operations.ContourOperation = CType(TheOp, Mastercam.Operations.ContourOperation)
                        ReverseChains(TheOp, ContourOp.GetChainArray)
                        'Dim ChainArray = ContourOp.GetChainArray
                    End If 'End of Contour Operation type if
                    If TheOp.Type = Mastercam.Database.Types.OperationType.Pocket Then
                        Dim PocketOp As Mastercam.Operations.PocketOperation = CType(TheOp, Mastercam.Operations.PocketOperation)
                        ReverseChains(TheOp, PocketOp.GetChainArray)
                    End If 'End of Pocket Operation type if
                    If TheOp.Type = Mastercam.Database.Types.OperationType.SlotMill Then
                        Dim SlotMillOp As Mastercam.Operations.SlotMillOperation = CType(TheOp, Mastercam.Operations.SlotMillOperation)
                        ReverseChains(TheOp, SlotMillOp.GetChainArray)
                    End If 'End of SlotMill Operation type if
                End If 'End of TheOp being selected if
            End If 'End of TheOp being nothing if
        Next i
        Return TheAnswer
    End Function
So far I am just trying to do the reverse chain part and when I debug the current code I have
it seems to delete the chain rather than reversing it.
Thanks Mick! I was missing the "SetChainArray". Only problem I'm having is this works for when I chain
off of wire geometry that I draw myself in Mastercam or curves that I extract from the edges of the solid
model, but it doesn't work if I chain directly from the solid itself. Is there a way of checking what kind of
entity is used for the chain? Because right now it is deleting the chain if a solid edge is used.
  • 9 months later...
Here is a screenshot of the code I use in ATP to reverse a chain, let me know of this helps.
Mick,
I'm trying to use this snippet to reverse toolpaths after mirroring geometry. I'm missing some basic stuff though:
  • How is the boolean(?) <conventional> assigned? (line 801 in the screenshot)
  • How are the classes(?) <definition> and <overrides> initiated? (lines 814, 817)
I will be happy to do some homework on this, but a little nudge in the right direction could sure help.
Thanks.
Eric,
The bool conventional maps to a checkbox on the UI. The overrides are values set from the UI and whether the imported operations have depth or we are using the depth of the current drawing. You can set these to hard coded values while testing your code.
Mick
Mick,
Thanks.
