Solid Model , STOP OP after re-opening file
tim_h
I keep getting this.
PK ERROR CODE 547
NON-MANIFOLD BODY OR BOUNDARY
Could be 2 faces are on top of each other and creating what is called a face imprinting error. Very hard to track down. Normally making the shape bigger or larger than need to get the desired effect helps. Both ways sometimes helps or an extra .01 of a cut or other things will do the trick.
Some times it something that should work and doesn't. Try making a solid and then doing a Boolean remove verses trying to extrude cut to remove.
