Arc output problem
Grievous
Using X9, Mpmaster, operation type Helix bore (see attached mcx file)
I'm getting different values on I J and (in this case) X, when the tool is doing last pass at final depth. See below:
.N40 G00 G17 G90 G54 X-2.5 Y0. S4000 M03N45 G43 H1 Z1.N50 Z.1N55 G94 G01 Z0. F15.N60 G41 D1 X-2.5313N65 G03 X-2.4687 Z-.01 I.0313 J0.N70 X-2.5313 Z-.02 I-.0313 J0.N75 X-2.4687 Z-.03 I.0313 J0.N80 X-2.5313 Z-.04 I-.0313 J0.N85 X-2.4687 Z-.05 I.0313 J0.N90 X-2.5313 Z-.06 I-.0313 J0.N95 X-2.4687 Z-.07 I.0313 J0.N100 X-2.5313 Z-.08 I-.0313 J0.N105 X-2.4687 Z-.09 I.0313 J0.N110 X-2.5313 Z-.1 I-.0313 J0.N115 X-2.4688 Z-.11 I.0313 J0. <====???N120 X-2.5312 I-.0312 J0. <====???N125 X-2.4688 I.0312 J0. <====???N130 G01 G40 X-2.5
Anyone know why and can advice please?
PS: It's not about a workaround to this specific example (like changing tool size so its rad will get rounded at a 4th decimal or something else). I'm more into, why it this happen and how it can be fixed please.
Arc.mcx-9
you're also getting differences on
X-2.5312 vs X-2.5313
I'd just call it rounding error. ...as long as the control doesn't freak out it should be fine.
I know..that's why I said I,J, and X. ...and it's not fine at all. The code should be consistent regardless of situation, and it is not.
Any suggestion?
Change the NC precision in your control def from .0001 to .00001
Few people would ever notice that which you are seeing but if you need it that's how
I wouldn't worry about it
Sorry JP, but you're wrong.  I'm worry about it and for 2 reasons:
1. Code should be spotless up to the last 0.0001 regarding on situation. You cannot just sweep a problem under the carpet.
2. On some controllers because this type of rounding you can scrap the part. I'm always check my Sinumerik post for this type of errors
N5 G41 X-.9367
N6 G3 X-.9368 Y4.1 Z-.445 I.1827 J0. TURN=22 ;.......that's a scrap here if you don't look for it.
N7 X-.5713 Y4.1 Z-.455 I.1827 J0.
N8 X-.5713 Y4.1 I-.1827 J0.
N9 G1 G40 X-.754
So what is your NC Precision set to?
The sample file you attached to your post is using a default machine definition "5 axis table head vertical".
The default NC Precision for this control definition is the .0001" as I recomended; and I see no rounding issue when posting operation #2.
Allan
Allan
I've posted the same and get standard X,Y I & J only Z differences.
Andy.
Just that I have a slight variation on J value.
N100 G20N102 G0 G17 G40 G80 G90 G94 G98N104 G0 G28 G91 Z0.N106 G0 G28 X0. Y0.(3/8 EM |TOOL - 2|DIA. OFF. - 2|LEN. - 2|TOOL DIA. - .375)(HELIX BORE)N108 T2 M6N110 G0 G54 G90 X-.754 Y4.1 C180. B-90. S2000 M3N112 G43 H2 Z1.N114 Z.065N116 G1 Z.015 F10.N118 G41 D2 X-.9367N120 G3 X-.754 Y3.9173 Z.01 I.1827N122 X-.5713 Y4.1 Z.005 J.1827N124 X-.754 Y4.2828 Z0. I-.1827N126 X-.9367 Y4.1 Z-.005 J-.1828N128 X-.754 Y3.9173 Z-.01 I.1827N130 X-.5713 Y4.1 Z-.015 J.1827N132 X-.754 Y4.2828 Z-.02 I-.1827N134 X-.9367 Y4.1 Z-.025 J-.1828N136 X-.754 Y3.9173 Z-.03 I.1827N138 X-.5713 Y4.1 Z-.035 J.1827N140 X-.754 Y4.2828 Z-.04 I-.1827N142 X-.9367 Y4.1 Z-.045 J-.1828
Your picture shows an NC precision of .00001" 10 millionths of an inch.
The NC precision is intended to be set to the least increment the machine will take; Mills, lathes are always .0001" 1 ten thousands of an inch.
From the help menu of the NC Precision setting:
NC precision
Motion tolerance. This is used in the post to determine the precision of the machine tool. It should be equal to the smallest linear step distance on the machine tool. Use the Truncate option to control whether values are truncated or rounded.
The value of this field sets the mtol post variable.
So try setting the value to .0001" and see what you get.
Allan
That did it for the 2nd op, but on the 1st one I get again a diference
N110 G0 G54 G90 X-2.5 Y0. C0. B0. S4000 M3N112 G43 H1 Z1.N114 Z.1N116 G1 Z0. F15.N118 G41 D1 X-2.5313N120 G3 X-2.5 Y-.0313 Z-.005 I.0313N122 X-2.4687 Y0. Z-.01 J.0313N124 X-2.5 Y.0313 Z-.015 I-.0313N126 X-2.5313 Y0. Z-.02 J-.0313N128 X-2.5 Y-.0313 Z-.025 I.0313N130 X-2.4687 Y0. Z-.03 J.0313N132 X-2.5 Y.0313 Z-.035 I-.0313N134 X-2.5313 Y0. Z-.04 J-.0313N136 X-2.5 Y-.0313 Z-.045 I.0313N138 X-2.4687 Y0. Z-.05 J.0313N140 X-2.5 Y.0313 Z-.055 I-.0313N142 X-2.5313 Y0. Z-.06 J-.0313N144 X-2.5 Y-.0313 Z-.065 I.0313N146 X-2.4687 Y0. Z-.07 J.0313N148 X-2.5 Y.0313 Z-.075 I-.0313N150 X-2.5313 Y0. Z-.08 J-.0313N152 X-2.5 Y-.0313 Z-.085 I.0313N154 X-2.4687 Y0. Z-.09 J.0313N156 X-2.5 Y.0313 Z-.095 I-.0313N158 X-2.5313 Y0. Z-.1 J-.0313N160 X-2.5 Y-.0313 Z-.105 I.0313N162 X-2.4688 Y0. Z-.11 J.0313N164 X-2.5 Y.0312 Z-.11 I-.0312N166 X-2.5312 Y0. Z-.11 J-.0312N168 X-2.5 Y-.0312 Z-.11 I.0312N170 X-2.4688 Y0. Z-.11 J.0312N172 G1 G40 X-2.5
I don't know what you have different on your system. Here is your file posted.
:0001(ARC)
(DATE=DD-MM-YY - 09-05-16 TIME=HH:MM - 08:31)
(MCX FILE - C:\USERS\RON\APPDATA\LOCAL\TEMP\ARC.MCX-9)
(NC FILE - C:\USERS\RON\DOCUMENTS\MY MCAMX9\MILL\NC\ARC.NC)
(MATERIAL - ALUMINUM INCH - 2024)
(T1|3/16 EM |H1|D1|WEAR COMP|TOOL DIA. - .1875)
N100 G20
N104 G0 G28 G91 Z0.
N106 G0 G28 X0. Y0.
(3/16 EM |TOOL - 1|DIA. OFF. - 1|LEN. - 1|TOOL DIA. - .1875)
(HELIX BORE)
N108 T1 M6
N112 G43 H1 Z1.
N114 Z.1
N116 G1 Z0. F15.
N122 X-2.4688 Y0. Z-.01 J.0313
N130 X-2.4688 Y0. Z-.03 J.0313
N138 X-2.4688 Y0. Z-.05 J.0313
N146 X-2.4688 Y0. Z-.07 J.0313
N154 X-2.4688 Y0. Z-.09 J.0313
N164 X-2.5 Y.0313 I-.0313
N166 X-2.5313 Y0. J-.0313
N168 X-2.5 Y-.0313 I.0313
N170 X-2.4688 Y0. J.0313
N172 G1 G40 X-2.5
N174 G0 Z1.
N176 X2.5
N178 Z.1
N180 G1 Z0.
N182 G41 D1 X2.4688
N184 G3 X2.5 Y-.0313 Z-.005 I.0313
N186 X2.5313 Y0. Z-.01 J.0313
N188 X2.5 Y.0313 Z-.015 I-.0313
N190 X2.4688 Y0. Z-.02 J-.0313
N192 X2.5 Y-.0313 Z-.025 I.0313
N194 X2.5313 Y0. Z-.03 J.0313
N196 X2.5 Y.0313 Z-.035 I-.0313
N198 X2.4688 Y0. Z-.04 J-.0313
N200 X2.5 Y-.0313 Z-.045 I.0313
N202 X2.5313 Y0. Z-.05 J.0313
N204 X2.5 Y.0313 Z-.055 I-.0313
N206 X2.4688 Y0. Z-.06 J-.0313
N208 X2.5 Y-.0313 Z-.065 I.0313
N210 X2.5313 Y0. Z-.07 J.0313
N212 X2.5 Y.0313 Z-.075 I-.0313
N214 X2.4688 Y0. Z-.08 J-.0313
N216 X2.5 Y-.0313 Z-.085 I.0313
N218 X2.5313 Y0. Z-.09 J.0313
N220 X2.5 Y.0313 Z-.095 I-.0313
N222 X2.4688 Y0. Z-.1 J-.0313
N224 X2.5 Y-.0313 Z-.105 I.0313
N226 X2.5313 Y0. Z-.11 J.0313
N228 X2.5 Y.0313 I-.0313
N230 X2.4688 Y0. J-.0313
N232 X2.5 Y-.0313 I.0313
N234 X2.5313 Y0. J.0313
N236 G1 G40 X2.5
N238 G0 Z1.
N240 M5
N242 G0 G28 G91 Z0.
N244 G0 G28 X0. Y0.
N246 G28
N248 M30
I don't know either..any suggestions?
Ron, can you post both ops pls?
I think I figured out your problem. You are trying to use a Metric machine definition to post inch output. The tolerance for inch is different than metric and the difference is I used an inch machine and control definition to post inch out not a metric machine and control definition. When I use the metric I get what you are getting which I would expect due to rounding errors. Switch over to the inch machine and control definition and I think you troubles will go away.
Here are both, One your way using Metric for inch output and the other your file using an inch MMD and MCD.
:0001(ARC2)
(DATE=DD-MM-YY - 09-05-16 TIME=HH:MM - 09:12)
(MCX FILE - C:\USERS\RON\DOCUMENTS\MY MCAMX9\MCX\ARC.MCX-9)
(NC FILE - C:\USERS\RON\DOCUMENTS\MY MCAMX9\MILL\NC\ARC2.NC)
(T2|3/8 EM |H2|D2|WEAR COMP|TOOL DIA. - .375|XY STOCK TO LEAVE - .005|Z STOCK TO LEAVE - 0.)
N100 G20
N104 G0 G28 G91 Z0.
N106 G0 G28 X0. Y0.
(HELIX BORE)
N108 T2 M6
N112 G43 H2 Z1.
N114 Z.065
N116 G1 Z.015 F10.
N118 G41 D2 X-.9367
N144 X-.754 Y3.9173 Z-.05 I.1827
N146 X-.5713 Y4.1 Z-.055 J.1827
N148 X-.754 Y4.2828 Z-.06 I-.1827
N150 X-.9367 Y4.1 Z-.065 J-.1828
N152 X-.754 Y3.9173 Z-.07 I.1827
N154 X-.5713 Y4.1 Z-.075 J.1827
N156 X-.754 Y4.2828 Z-.08 I-.1827
N158 X-.9367 Y4.1 Z-.085 J-.1828
N160 X-.754 Y3.9173 Z-.09 I.1827
N162 X-.5713 Y4.1 Z-.095 J.1827
N164 X-.754 Y4.2828 Z-.1 I-.1827
N166 X-.9367 Y4.1 Z-.105 J-.1828
N168 X-.754 Y3.9173 Z-.11 I.1827
N170 X-.5713 Y4.1 Z-.115 J.1827
N172 X-.754 Y4.2828 Z-.12 I-.1827
N174 X-.9367 Y4.1 Z-.125 J-.1828
N176 X-.754 Y3.9173 Z-.13 I.1827
N178 X-.5713 Y4.1 Z-.135 J.1827
N180 X-.754 Y4.2828 Z-.14 I-.1827
N182 X-.9367 Y4.1 Z-.145 J-.1828
N184 X-.754 Y3.9173 Z-.15 I.1827
N186 X-.5713 Y4.1 Z-.155 J.1827
N188 X-.754 Y4.2828 Z-.16 I-.1827
N190 X-.9367 Y4.1 Z-.165 J-.1828
N192 X-.754 Y3.9173 Z-.17 I.1827
N194 X-.5713 Y4.1 Z-.175 J.1827
N196 X-.754 Y4.2828 Z-.18 I-.1827
N198 X-.9367 Y4.1 Z-.185 J-.1828
N200 X-.754 Y3.9173 Z-.19 I.1827
N202 X-.5713 Y4.1 Z-.195 J.1827
N204 X-.754 Y4.2828 Z-.2 I-.1827
N206 X-.9367 Y4.1 Z-.205 J-.1828
N208 X-.754 Y3.9173 Z-.21 I.1827
N210 X-.5713 Y4.1 Z-.215 J.1827
N212 X-.754 Y4.2828 Z-.22 I-.1827
N214 X-.9367 Y4.1 Z-.225 J-.1828
N216 X-.754 Y3.9173 Z-.23 I.1827
N218 X-.5713 Y4.1 Z-.235 J.1827
N220 X-.754 Y4.2828 Z-.24 I-.1827
N222 X-.9367 Y4.1 Z-.245 J-.1828
N224 X-.754 Y3.9173 Z-.25 I.1827
N226 X-.5713 Y4.1 Z-.255 J.1827
N228 X-.754 Y4.2828 Z-.26 I-.1827
N230 X-.9367 Y4.1 Z-.265 J-.1828
N232 X-.754 Y3.9173 Z-.27 I.1827
N234 X-.5713 Y4.1 Z-.275 J.1827
N236 X-.754 Y4.2828 Z-.28 I-.1827
N238 X-.9367 Y4.1 Z-.285 J-.1828
N240 X-.754 Y3.9173 Z-.29 I.1827
N242 X-.5713 Y4.1 Z-.295 J.1827
N244 X-.754 Y4.2828 Z-.3 I-.1827
N246 X-.9367 Y4.1 Z-.305 J-.1828
N248 X-.754 Y3.9173 Z-.31 I.1827
N250 X-.5713 Y4.1 Z-.315 J.1827
N252 X-.754 Y4.2828 Z-.32 I-.1827
N254 X-.9367 Y4.1 Z-.325 J-.1828
N256 X-.754 Y3.9173 Z-.33 I.1827
N258 X-.5713 Y4.1 Z-.335 J.1827
N260 X-.754 Y4.2828 Z-.34 I-.1827
N262 X-.9367 Y4.1 Z-.345 J-.1828
N264 X-.754 Y3.9173 Z-.35 I.1827
N266 X-.5713 Y4.1 Z-.355 J.1827
N268 X-.754 Y4.2828 Z-.36 I-.1827
N270 X-.9367 Y4.1 Z-.365 J-.1828
N272 X-.754 Y3.9173 Z-.37 I.1827
N274 X-.5713 Y4.1 Z-.375 J.1827
N276 X-.754 Y4.2828 Z-.38 I-.1827
N278 X-.9367 Y4.1 Z-.385 J-.1828
N280 X-.754 Y3.9173 Z-.39 I.1827
N282 X-.5713 Y4.1 Z-.395 J.1827
N284 X-.754 Y4.2828 Z-.4 I-.1827
N286 X-.9367 Y4.1 Z-.405 J-.1828
N288 X-.754 Y3.9173 Z-.41 I.1827
N290 X-.5713 Y4.1 Z-.415 J.1827
N292 X-.754 Y4.2828 Z-.42 I-.1827
N294 X-.9367 Y4.1 Z-.425 J-.1828
N296 X-.754 Y3.9173 Z-.43 I.1827
N298 X-.5713 Y4.1 Z-.435 J.1827
N300 X-.754 Y4.2828 Z-.44 I-.1827
N302 X-.9367 Y4.1 Z-.445 J-.1828
N304 X-.754 Y3.9173 Z-.45 I.1827
N306 X-.5713 Y4.1 Z-.455 J.1827
N308 X-.754 Y4.2828 I-.1827
N310 X-.9367 Y4.1 J-.1828
N312 X-.754 Y3.9173 I.1827
N314 X-.5713 Y4.1 J.1827
N316 G1 G40 X-.754
N318 G0 Z1.
N320 M5
N322 G0 G28 G91 Z0.
N324 G0 G28 X0. Y0.
N326 G28 C0. B0.
N328 M30
Inch
:0001(ARC2_INCH)
(DATE=DD-MM-YY - 09-05-16 TIME=HH:MM - 09:17)
(NC FILE - C:\USERS\RON\DOCUMENTS\MY MCAMX9\MILL\NC\ARC2_INCH.NC)
N100 G20
N104 G0 G28 G91 Z0.
N106 G0 G28 X0. Y0.
(HELIX BORE)
N108 T2 M6
N112 G43 H2 Z1.
N114 Z.065
N116 G1 Z.015 F10.
N118 G41 D2 X-.9367
N124 X-.754 Y4.2827 Z0. I-.1827
N126 X-.9367 Y4.1 Z-.005 J-.1827
N132 X-.754 Y4.2827 Z-.02 I-.1827
N134 X-.9367 Y4.1 Z-.025 J-.1827
N140 X-.754 Y4.2827 Z-.04 I-.1827
N142 X-.9367 Y4.1 Z-.045 J-.1827
N148 X-.754 Y4.2827 Z-.06 I-.1827
N150 X-.9367 Y4.1 Z-.065 J-.1827
N156 X-.754 Y4.2827 Z-.08 I-.1827
N158 X-.9367 Y4.1 Z-.085 J-.1827
N164 X-.754 Y4.2827 Z-.1 I-.1827
N166 X-.9367 Y4.1 Z-.105 J-.1827
N172 X-.754 Y4.2827 Z-.12 I-.1827
N174 X-.9367 Y4.1 Z-.125 J-.1827
N180 X-.754 Y4.2827 Z-.14 I-.1827
N182 X-.9367 Y4.1 Z-.145 J-.1827
N188 X-.754 Y4.2827 Z-.16 I-.1827
N190 X-.9367 Y4.1 Z-.165 J-.1827
N196 X-.754 Y4.2827 Z-.18 I-.1827
N198 X-.9367 Y4.1 Z-.185 J-.1827
N204 X-.754 Y4.2827 Z-.2 I-.1827
N206 X-.9367 Y4.1 Z-.205 J-.1827
N212 X-.754 Y4.2827 Z-.22 I-.1827
N214 X-.9367 Y4.1 Z-.225 J-.1827
N220 X-.754 Y4.2827 Z-.24 I-.1827
N222 X-.9367 Y4.1 Z-.245 J-.1827
N228 X-.754 Y4.2827 Z-.26 I-.1827
N230 X-.9367 Y4.1 Z-.265 J-.1827
N236 X-.754 Y4.2827 Z-.28 I-.1827
N238 X-.9367 Y4.1 Z-.285 J-.1827
N244 X-.754 Y4.2827 Z-.3 I-.1827
N246 X-.9367 Y4.1 Z-.305 J-.1827
N252 X-.754 Y4.2827 Z-.32 I-.1827
N254 X-.9367 Y4.1 Z-.325 J-.1827
N260 X-.754 Y4.2827 Z-.34 I-.1827
N262 X-.9367 Y4.1 Z-.345 J-.1827
N268 X-.754 Y4.2827 Z-.36 I-.1827
N270 X-.9367 Y4.1 Z-.365 J-.1827
N276 X-.754 Y4.2827 Z-.38 I-.1827
N278 X-.9367 Y4.1 Z-.385 J-.1827
N284 X-.754 Y4.2827 Z-.4 I-.1827
N286 X-.9367 Y4.1 Z-.405 J-.1827
N292 X-.754 Y4.2827 Z-.42 I-.1827
N294 X-.9367 Y4.1 Z-.425 J-.1827
N300 X-.754 Y4.2827 Z-.44 I-.1827
N302 X-.9367 Y4.1 Z-.445 J-.1827
N308 X-.754 Y4.2827 I-.1827
N310 X-.9367 Y4.1 J-.1827
N316 G1 G40 X-.754
N318 G0 Z1.
N320 M5
N322 G0 G28 G91 Z0.
N324 G0 G28 X0. Y0.
N326 G28 C0. B0.
N328 M30
ok. how about the 1st operation? Post both pls
That was the 1st operation that you had ghosted my 1st posting was your 2nd operation. If you compare the code you can see the differences. Once is for the one hole you had in the front operation and the other is for the 2 holes you had in the top operation. Again both were posted using an Inch Machine and Control Definition and I didn't get the difference in J you were getting. Replace the machine in the operations manager and re-post and I think you problems will go away. I never do what you are doing here. If I am working in Metric I use a Metric Machine and Control definition. If I am working in Inch I use an Inch Machine and Control definition. Sorry it has taken this long for anyone to find what is your problem, but I truly believe this is what you have been fighting with the whole time. I am trying to point you in the right direction here not diminish it. This was not a Mastercam error this was using the wrong file for the wrong units.
If you are referring to this posting here is the output from it.
O0000 (ARC_MP)
(PROGRAM   - ARC_MP.NC)
(DATE      - MAY-09-2016)
(TIME      - 9:53 AM)
(T1   - 3/16 EM              - H1   - D1   - D0.1875")
N5 G00 G17 G20 G40 G80 G90
N10 G91 G28 Z0.
N15 (HELIX BORE)
N20 (COMPENSATION TYPE - WEAR COMP)
N25 T1 M06 (3/16 EM)
N30 (MAX - Z1.)
N35 (MIN - Z-.11)
N45 G43 H1 Z1.
N50 Z.1
N60 G41 D1 X-2.5313
N65 G03 X-2.4688 Z-.01 I.0313 J0.
N75 X-2.4688 Z-.03 I.0313 J0.
N85 X-2.4688 Z-.05 I.0313 J0.
N95 X-2.4688 Z-.07 I.0313 J0.
N105 X-2.4688 Z-.09 I.0313 J0.
N120 X-2.5313 I-.0313 J0.
N125 X-2.4688 I.0313 J0.
N130 G01 G40 X-2.5
N135 G00 Z1.
N140 X2.5
N145 Z.1
N150 G01 Z0.
N155 G41 D1 X2.4688
N160 G03 X2.5313 Z-.01 I.0313 J0.
N165 X2.4688 Z-.02 I-.0313 J0.
N170 X2.5313 Z-.03 I.0313 J0.
N175 X2.4688 Z-.04 I-.0313 J0.
N180 X2.5313 Z-.05 I.0313 J0.
N185 X2.4688 Z-.06 I-.0313 J0.
N190 X2.5313 Z-.07 I.0313 J0.
N195 X2.4688 Z-.08 I-.0313 J0.
N200 X2.5313 Z-.09 I.0313 J0.
N205 X2.4688 Z-.1 I-.0313 J0.
N210 X2.5313 Z-.11 I.0313 J0.
N215 X2.4688 I-.0313 J0.
N220 X2.5313 I.0313 J0.
N225 G01 G40 X2.5
N230 G00 Z1.
N235 M05
N240 G91 G28 Z0.
N245 G28 Y0.
N250 G90
N255 M30
Yes I replaced like you said (pic attached), and I'm getting this code
:0001(ARC)(DATE=DD-MM-YY - 09-05-16 TIME=HH:MM - 13:10)(MCX FILE - C:\USERS\COPINCA\DESKTOP\ARC.MCX-9)(NC FILE - C:\TEMP\ARC.NC)(MATERIAL - ALUMINUM INCH - 2024)(T1|3/16 EM |H1|D1|WEAR COMP|TOOL DIA. - .1875)(T2|3/8 EM |H2|D2|WEAR COMP|TOOL DIA. - .375|XY STOCK TO LEAVE - .005|Z STOCK TO LEAVE - 0.)N100 G20N102 G0 G17 G40 G80 G90 G94 G98N104 G0 G28 G91 Z0.N106 G0 G28 X0. Y0.(3/16 EM |TOOL - 1|DIA. OFF. - 1|LEN. - 1|TOOL DIA. - .1875)(HELIX BORE)N108 T1 M6N110 G0 G54 G90 X-2.5 Y0. C0. B0. S4000 M3N112 G43 H1 Z1.N114 Z.1N116 G1 Z0. F15.N118 G41 D1 X-2.5313N120 G3 X-2.5 Y-.0313 Z-.005 I.0313N122 X-2.4687 Y0. Z-.01 J.0313N124 X-2.5 Y.0313 Z-.015 I-.0313N126 X-2.5313 Y0. Z-.02 J-.0313N128 X-2.5 Y-.0313 Z-.025 I.0313N130 X-2.4687 Y0. Z-.03 J.0313N132 X-2.5 Y.0313 Z-.035 I-.0313N134 X-2.5313 Y0. Z-.04 J-.0313N136 X-2.5 Y-.0313 Z-.045 I.0313N138 X-2.4687 Y0. Z-.05 J.0313N140 X-2.5 Y.0313 Z-.055 I-.0313N142 X-2.5313 Y0. Z-.06 J-.0313N144 X-2.5 Y-.0313 Z-.065 I.0313N146 X-2.4687 Y0. Z-.07 J.0313N148 X-2.5 Y.0313 Z-.075 I-.0313N150 X-2.5313 Y0. Z-.08 J-.0313N152 X-2.5 Y-.0313 Z-.085 I.0313N154 X-2.4687 Y0. Z-.09 J.0313N156 X-2.5 Y.0313 Z-.095 I-.0313N158 X-2.5313 Y0. Z-.1 J-.0313N160 X-2.5 Y-.0313 Z-.105 I.0313N162 X-2.4688 Y0. Z-.11 J.0313N164 X-2.5 Y.0312 Z-.11 I-.0312N166 X-2.5312 Y0. Z-.11 J-.0312N168 X-2.5 Y-.0312 Z-.11 I.0312N170 X-2.4688 Y0. Z-.11 J.0312N172 G1 G40 X-2.5N174 G0 Z1.N176 X2.5N178 Z.1N180 G1 Z0.N182 G41 D1 X2.4688N184 G3 X2.5 Y-.0312 Z-.005 I.0312N186 X2.5312 Y0. Z-.01 J.0312N188 X2.5 Y.0312 Z-.015 I-.0312N190 X2.4688 Y0. Z-.02 J-.0312N192 X2.5 Y-.0312 Z-.025 I.0312N194 X2.5312 Y0. Z-.03 J.0312N196 X2.5 Y.0312 Z-.035 I-.0312N198 X2.4688 Y0. Z-.04 J-.0312N200 X2.5 Y-.0312 Z-.045 I.0312N202 X2.5312 Y0. Z-.05 J.0312N204 X2.5 Y.0312 Z-.055 I-.0312N206 X2.4688 Y0. Z-.06 J-.0312N208 X2.5 Y-.0312 Z-.065 I.0312N210 X2.5312 Y0. Z-.07 J.0312N212 X2.5 Y.0312 Z-.075 I-.0312N214 X2.4688 Y0. Z-.08 J-.0312N216 X2.5 Y-.0312 Z-.085 I.0312N218 X2.5312 Y0. Z-.09 J.0312N220 X2.5 Y.0312 Z-.095 I-.0312N222 X2.4688 Y0. Z-.1 J-.0312N224 X2.5 Y-.0312 Z-.105 I.0312N226 X2.5313 Y0. Z-.11 J.0312N228 X2.5 Y.0313 Z-.11 I-.0313N230 X2.4687 Y0. Z-.11 J-.0313N232 X2.5 Y-.0313 Z-.11 I.0313N234 X2.5313 Y0. Z-.11 J.0313N236 G1 G40 X2.5N238 G0 Z1.N240 M5N242 G0 G28 G91 Z0.N244 G28N246 M01N248 G0 G17 G40 G80 G90 G94 G98N250 G0 G28 G91 Z0.(3/8 EM |TOOL - 2|DIA. OFF. - 2|LEN. - 2|TOOL DIA. - .375)(HELIX BORE)N252 T2 M6N254 G0 G54 G90 X-.754 Y4.1 C180. B-90. S2000 M3N256 G43 H2 Z1.N258 Z.065N260 G1 Z.015 F10.N262 G41 D2 X-.9367N264 G3 X-.754 Y3.9173 Z.01 I.1827N266 X-.5713 Y4.1 Z.005 J.1827N268 X-.754 Y4.2827 Z0. I-.1827N270 X-.9367 Y4.1 Z-.005 J-.1827N272 X-.754 Y3.9173 Z-.01 I.1827N274 X-.5713 Y4.1 Z-.015 J.1827N276 X-.754 Y4.2827 Z-.02 I-.1827N278 X-.9367 Y4.1 Z-.025 J-.1827N280 X-.754 Y3.9173 Z-.03 I.1827N282 X-.5713 Y4.1 Z-.035 J.1827N284 X-.754 Y4.2827 Z-.04 I-.1827N286 X-.9367 Y4.1 Z-.045 J-.1827N288 X-.754 Y3.9173 Z-.05 I.1827N290 X-.5713 Y4.1 Z-.055 J.1827N292 X-.754 Y4.2827 Z-.06 I-.1827N294 X-.9367 Y4.1 Z-.065 J-.1827N296 X-.754 Y3.9173 Z-.07 I.1827N298 X-.5713 Y4.1 Z-.075 J.1827N300 X-.754 Y4.2827 Z-.08 I-.1827N302 X-.9367 Y4.1 Z-.085 J-.1827N304 X-.754 Y3.9173 Z-.09 I.1827N306 X-.5713 Y4.1 Z-.095 J.1827N308 X-.754 Y4.2827 Z-.1 I-.1827N310 X-.9367 Y4.1 Z-.105 J-.1827N312 X-.754 Y3.9173 Z-.11 I.1827N314 X-.5713 Y4.1 Z-.115 J.1827N316 X-.754 Y4.2827 Z-.12 I-.1827N318 X-.9367 Y4.1 Z-.125 J-.1827N320 X-.754 Y3.9173 Z-.13 I.1827N322 X-.5713 Y4.1 Z-.135 J.1827N324 X-.754 Y4.2827 Z-.14 I-.1827N326 X-.9367 Y4.1 Z-.145 J-.1827N328 X-.754 Y3.9173 Z-.15 I.1827N330 X-.5713 Y4.1 Z-.155 J.1827N332 X-.754 Y4.2827 Z-.16 I-.1827N334 X-.9367 Y4.1 Z-.165 J-.1827N336 X-.754 Y3.9173 Z-.17 I.1827N338 X-.5713 Y4.1 Z-.175 J.1827N340 X-.754 Y4.2827 Z-.18 I-.1827N342 X-.9367 Y4.1 Z-.185 J-.1827N344 X-.754 Y3.9173 Z-.19 I.1827N346 X-.5713 Y4.1 Z-.195 J.1827N348 X-.754 Y4.2827 Z-.2 I-.1827N350 X-.9367 Y4.1 Z-.205 J-.1827N352 X-.754 Y3.9173 Z-.21 I.1827N354 X-.5713 Y4.1 Z-.215 J.1827N356 X-.754 Y4.2827 Z-.22 I-.1827N358 X-.9367 Y4.1 Z-.225 J-.1827N360 X-.754 Y3.9173 Z-.23 I.1827N362 X-.5713 Y4.1 Z-.235 J.1827N364 X-.754 Y4.2827 Z-.24 I-.1827N366 X-.9367 Y4.1 Z-.245 J-.1827N368 X-.754 Y3.9173 Z-.25 I.1827N370 X-.5713 Y4.1 Z-.255 J.1827N372 X-.754 Y4.2827 Z-.26 I-.1827N374 X-.9367 Y4.1 Z-.265 J-.1827N376 X-.754 Y3.9173 Z-.27 I.1827N378 X-.5713 Y4.1 Z-.275 J.1827N380 X-.754 Y4.2827 Z-.28 I-.1827N382 X-.9367 Y4.1 Z-.285 J-.1827N384 X-.754 Y3.9173 Z-.29 I.1827N386 X-.5713 Y4.1 Z-.295 J.1827N388 X-.754 Y4.2827 Z-.3 I-.1827N390 X-.9367 Y4.1 Z-.305 J-.1827N392 X-.754 Y3.9173 Z-.31 I.1827N394 X-.5713 Y4.1 Z-.315 J.1827N396 X-.754 Y4.2827 Z-.32 I-.1827N398 X-.9367 Y4.1 Z-.325 J-.1827N400 X-.754 Y3.9173 Z-.33 I.1827N402 X-.5713 Y4.1 Z-.335 J.1827N404 X-.754 Y4.2827 Z-.34 I-.1827N406 X-.9367 Y4.1 Z-.345 J-.1827N408 X-.754 Y3.9173 Z-.35 I.1827N410 X-.5713 Y4.1 Z-.355 J.1827N412 X-.754 Y4.2827 Z-.36 I-.1827N414 X-.9367 Y4.1 Z-.365 J-.1827N416 X-.754 Y3.9173 Z-.37 I.1827N418 X-.5713 Y4.1 Z-.375 J.1827N420 X-.754 Y4.2827 Z-.38 I-.1827N422 X-.9367 Y4.1 Z-.385 J-.1827N424 X-.754 Y3.9173 Z-.39 I.1827N426 X-.5713 Y4.1 Z-.395 J.1827N428 X-.754 Y4.2827 Z-.4 I-.1827N430 X-.9367 Y4.1 Z-.405 J-.1827N432 X-.754 Y3.9173 Z-.41 I.1827N434 X-.5713 Y4.1 Z-.415 J.1827N436 X-.754 Y4.2827 Z-.42 I-.1827N438 X-.9367 Y4.1 Z-.425 J-.1827N440 X-.754 Y3.9173 Z-.43 I.1827N442 X-.5713 Y4.1 Z-.435 J.1827N444 X-.754 Y4.2827 Z-.44 I-.1827N446 X-.9367 Y4.1 Z-.445 J-.1827N448 X-.754 Y3.9173 Z-.45 I.1827N450 X-.5713 Y4.1 Z-.455 J.1827N452 X-.754 Y4.2827 Z-.455 I-.1827N454 X-.9367 Y4.1 Z-.455 J-.1827N456 X-.754 Y3.9173 Z-.455 I.1827N458 X-.5713 Y4.1 Z-.455 J.1827N460 G1 G40 X-.754N462 G0 Z1.N464 M5N466 G0 G28 G91 Z0.N468 G0 G28 X0. Y0.N470 G28 C0. B0.N472 M30
Arc.mcx-9
Yep...did that and I'm getting this (look at 2nd op)
%:0001(ARC)(DATE=DD-MM-YY - 09-05-16 TIME=HH:MM - 14:02)(MCX FILE - C:\USERS\COPINCA\DESKTOP\ARC.MCX-9)(NC FILE - C:\TEMP\ARC.NC)(MATERIAL - ALUMINUM INCH - 2024)(T1|3/16 EM |H1|D1|WEAR COMP|TOOL DIA. - .1875)(T2|3/8 EM |H2|D2|WEAR COMP|TOOL DIA. - .375|XY STOCK TO LEAVE - .005|Z STOCK TO LEAVE - 0.)N100 G20N102 G0 G17 G40 G80 G90 G94 G98N104 G0 G28 G91 Z0.N106 G0 G28 X0. Y0.(3/16 EM |TOOL - 1|DIA. OFF. - 1|LEN. - 1|TOOL DIA. - .1875)(HELIX BORE)N108 T1 M6N110 G0 G54 G90 X-2.5 Y0. C0. B0. S4000 M3N112 G43 H1 Z1.N114 Z.1N116 G1 Z0. F15.N118 G41 D1 X-2.5313N120 G3 X-2.5 Y-.0313 Z-.005 I.0313N122 X-2.4688 Y0. Z-.01 J.0313N124 X-2.5 Y.0313 Z-.015 I-.0313N126 X-2.5313 Y0. Z-.02 J-.0313N128 X-2.5 Y-.0313 Z-.025 I.0313N130 X-2.4688 Y0. Z-.03 J.0313N132 X-2.5 Y.0313 Z-.035 I-.0313N134 X-2.5313 Y0. Z-.04 J-.0313N136 X-2.5 Y-.0313 Z-.045 I.0313N138 X-2.4688 Y0. Z-.05 J.0313N140 X-2.5 Y.0313 Z-.055 I-.0313N142 X-2.5313 Y0. Z-.06 J-.0313N144 X-2.5 Y-.0313 Z-.065 I.0313N146 X-2.4688 Y0. Z-.07 J.0313N148 X-2.5 Y.0313 Z-.075 I-.0313N150 X-2.5313 Y0. Z-.08 J-.0313N152 X-2.5 Y-.0313 Z-.085 I.0313N154 X-2.4688 Y0. Z-.09 J.0313N156 X-2.5 Y.0313 Z-.095 I-.0313N158 X-2.5313 Y0. Z-.1 J-.0313N160 X-2.5 Y-.0313 Z-.105 I.0313N162 X-2.4688 Y0. Z-.11 J.0313N164 X-2.5 Y.0313 Z-.11 I-.0313N166 X-2.5313 Y0. Z-.11 J-.0313N168 X-2.5 Y-.0313 Z-.11 I.0313N170 X-2.4688 Y0. Z-.11 J.0313N172 G1 G40 X-2.5N174 G0 Z1.N176 X2.5N178 Z.1N180 G1 Z0.N182 G41 D1 X2.4688N184 G3 X2.5 Y-.0313 Z-.005 I.0313N186 X2.5313 Y0. Z-.01 J.0313N188 X2.5 Y.0313 Z-.015 I-.0313N190 X2.4688 Y0. Z-.02 J-.0313N192 X2.5 Y-.0313 Z-.025 I.0313N194 X2.5313 Y0. Z-.03 J.0313N196 X2.5 Y.0313 Z-.035 I-.0313N198 X2.4688 Y0. Z-.04 J-.0313N200 X2.5 Y-.0313 Z-.045 I.0313N202 X2.5313 Y0. Z-.05 J.0313N204 X2.5 Y.0313 Z-.055 I-.0313N206 X2.4688 Y0. Z-.06 J-.0313N208 X2.5 Y-.0313 Z-.065 I.0313N210 X2.5313 Y0. Z-.07 J.0313N212 X2.5 Y.0313 Z-.075 I-.0313N214 X2.4688 Y0. Z-.08 J-.0313N216 X2.5 Y-.0313 Z-.085 I.0313N218 X2.5313 Y0. Z-.09 J.0313N220 X2.5 Y.0313 Z-.095 I-.0313N222 X2.4688 Y0. Z-.1 J-.0313N224 X2.5 Y-.0313 Z-.105 I.0313N226 X2.5313 Y0. Z-.11 J.0313N228 X2.5 Y.0313 Z-.11 I-.0313N230 X2.4688 Y0. Z-.11 J-.0313N232 X2.5 Y-.0313 Z-.11 I.0313N234 X2.5313 Y0. Z-.11 J.0313N236 G1 G40 X2.5N238 G0 Z1.N240 M5N242 G0 G28 G91 Z0.N244 G28N246 M01N248 G0 G17 G40 G80 G90 G94 G98N250 G0 G28 G91 Z0.(3/8 EM |TOOL - 2|DIA. OFF. - 2|LEN. - 2|TOOL DIA. - .375)(HELIX BORE)N252 T2 M6N254 G0 G54 G90 X-.754 Y4.1 C180. B-90. S2000 M3N256 G43 H2 Z1.N258 Z.065N260 G1 Z.015 F10.N262 G41 D2 X-.9367N264 G3 X-.754 Y3.9173 Z.01 I.1827N266 X-.5713 Y4.1 Z.005 J.1827N268 X-.754 Y4.2828 Z0. I-.1827N270 X-.9367 Y4.1 Z-.005 J-.1828N272 X-.754 Y3.9173 Z-.01 I.1827N274 X-.5713 Y4.1 Z-.015 J.1827N276 X-.754 Y4.2828 Z-.02 I-.1827N278 X-.9367 Y4.1 Z-.025 J-.1828N280 X-.754 Y3.9173 Z-.03 I.1827N282 X-.5713 Y4.1 Z-.035 J.1827N284 X-.754 Y4.2828 Z-.04 I-.1827N286 X-.9367 Y4.1 Z-.045 J-.1828N288 X-.754 Y3.9173 Z-.05 I.1827N290 X-.5713 Y4.1 Z-.055 J.1827N292 X-.754 Y4.2828 Z-.06 I-.1827N294 X-.9367 Y4.1 Z-.065 J-.1828N296 X-.754 Y3.9173 Z-.07 I.1827N298 X-.5713 Y4.1 Z-.075 J.1827N300 X-.754 Y4.2828 Z-.08 I-.1827N302 X-.9367 Y4.1 Z-.085 J-.1828N304 X-.754 Y3.9173 Z-.09 I.1827N306 X-.5713 Y4.1 Z-.095 J.1827N308 X-.754 Y4.2828 Z-.1 I-.1827N310 X-.9367 Y4.1 Z-.105 J-.1828N312 X-.754 Y3.9173 Z-.11 I.1827N314 X-.5713 Y4.1 Z-.115 J.1827N316 X-.754 Y4.2828 Z-.12 I-.1827N318 X-.9367 Y4.1 Z-.125 J-.1828N320 X-.754 Y3.9173 Z-.13 I.1827N322 X-.5713 Y4.1 Z-.135 J.1827N324 X-.754 Y4.2828 Z-.14 I-.1827N326 X-.9367 Y4.1 Z-.145 J-.1828N328 X-.754 Y3.9173 Z-.15 I.1827N330 X-.5713 Y4.1 Z-.155 J.1827N332 X-.754 Y4.2828 Z-.16 I-.1827N334 X-.9367 Y4.1 Z-.165 J-.1828N336 X-.754 Y3.9173 Z-.17 I.1827N338 X-.5713 Y4.1 Z-.175 J.1827N340 X-.754 Y4.2828 Z-.18 I-.1827N342 X-.9367 Y4.1 Z-.185 J-.1828N344 X-.754 Y3.9173 Z-.19 I.1827N346 X-.5713 Y4.1 Z-.195 J.1827N348 X-.754 Y4.2828 Z-.2 I-.1827N350 X-.9367 Y4.1 Z-.205 J-.1828N352 X-.754 Y3.9173 Z-.21 I.1827N354 X-.5713 Y4.1 Z-.215 J.1827N356 X-.754 Y4.2828 Z-.22 I-.1827N358 X-.9367 Y4.1 Z-.225 J-.1828N360 X-.754 Y3.9173 Z-.23 I.1827N362 X-.5713 Y4.1 Z-.235 J.1827N364 X-.754 Y4.2828 Z-.24 I-.1827N366 X-.9367 Y4.1 Z-.245 J-.1828N368 X-.754 Y3.9173 Z-.25 I.1827N370 X-.5713 Y4.1 Z-.255 J.1827N372 X-.754 Y4.2828 Z-.26 I-.1827N374 X-.9367 Y4.1 Z-.265 J-.1828N376 X-.754 Y3.9173 Z-.27 I.1827N378 X-.5713 Y4.1 Z-.275 J.1827N380 X-.754 Y4.2828 Z-.28 I-.1827N382 X-.9367 Y4.1 Z-.285 J-.1828N384 X-.754 Y3.9173 Z-.29 I.1827N386 X-.5713 Y4.1 Z-.295 J.1827N388 X-.754 Y4.2828 Z-.3 I-.1827N390 X-.9367 Y4.1 Z-.305 J-.1828N392 X-.754 Y3.9173 Z-.31 I.1827N394 X-.5713 Y4.1 Z-.315 J.1827N396 X-.754 Y4.2828 Z-.32 I-.1827N398 X-.9367 Y4.1 Z-.325 J-.1828N400 X-.754 Y3.9173 Z-.33 I.1827N402 X-.5713 Y4.1 Z-.335 J.1827N404 X-.754 Y4.2828 Z-.34 I-.1827N406 X-.9367 Y4.1 Z-.345 J-.1828N408 X-.754 Y3.9173 Z-.35 I.1827N410 X-.5713 Y4.1 Z-.355 J.1827N412 X-.754 Y4.2828 Z-.36 I-.1827N414 X-.9367 Y4.1 Z-.365 J-.1828N416 X-.754 Y3.9173 Z-.37 I.1827N418 X-.5713 Y4.1 Z-.375 J.1827N420 X-.754 Y4.2828 Z-.38 I-.1827N422 X-.9367 Y4.1 Z-.385 J-.1828N424 X-.754 Y3.9173 Z-.39 I.1827N426 X-.5713 Y4.1 Z-.395 J.1827N428 X-.754 Y4.2828 Z-.4 I-.1827N430 X-.9367 Y4.1 Z-.405 J-.1828N432 X-.754 Y3.9173 Z-.41 I.1827N434 X-.5713 Y4.1 Z-.415 J.1827N436 X-.754 Y4.2828 Z-.42 I-.1827N438 X-.9367 Y4.1 Z-.425 J-.1828N440 X-.754 Y3.9173 Z-.43 I.1827N442 X-.5713 Y4.1 Z-.435 J.1827N444 X-.754 Y4.2828 Z-.44 I-.1827N446 X-.9367 Y4.1 Z-.445 J-.1828N448 X-.754 Y3.9173 Z-.45 I.1827N450 X-.5713 Y4.1 Z-.455 J.1827N452 X-.754 Y4.2828 Z-.455 I-.1827N454 X-.9367 Y4.1 Z-.455 J-.1828N456 X-.754 Y3.9173 Z-.455 I.1827N458 X-.5713 Y4.1 Z-.455 J.1827N460 G1 G40 X-.754N462 G0 Z1.N464 M5N466 G0 G28 G91 Z0.N468 G0 G28 X0. Y0.N470 G28 C0. B0.N472 M30%
Arc.mcx-9
You only paid attention to one place. Here it is again and notice the arrow pointing to everything changed, not just one place.
O0000 (ARC_MP2)
(PROGRAM   - ARC_MP2.NC)
(TIME      - 11:06 AM)
(T2   - 3/8 EM               - H2   - D2   - D0.3750")
(OVERALL MAX - Z1.)
(OVERALL MIN - Z-.455)
N10 G91 G28 Z0.
N15 (HELIX BORE)
N30 (MAX - Z1.)
N35 (MIN - Z-.11)
N40 G00 G17 G90 G54 A0. X-2.5 Y0. S4000 M03
N45 G43 H1 Z1.
N50 Z.1
N60 G41 D1 X-2.5313
N130 G01 G40 X-2.5
N135 G00 Z1.
N140 X2.5
N145 Z.1
N150 G01 Z0.
N155 G41 D1 X2.4688
N225 G01 G40 X2.5
N230 G00 Z1.
N235 M05
N240 G91 G28 Z0.
N245 M01
N250 (HELIX BORE)
N255 (COMPENSATION TYPE - WEAR COMP)
N260 T2 M06 (3/8 EM)
N265 (MAX - Z1.)
N270 (MIN - Z-.455)
N275 G00 G17 G90 G55 A90. X-4.1 Y-.754 S2000 M03
N280 G43 H2 Z1.
N285 Z.065
N290 G94 G01 Z.015 F10.
N295 G41 D2 Y-.9367
N300 G03 Y-.5713 Z.005 I0. J.1827
N305 Y-.9367 Z-.005 I0. J-.1827
N310 Y-.5713 Z-.015 I0. J.1827
N315 Y-.9367 Z-.025 I0. J-.1827
N320 Y-.5713 Z-.035 I0. J.1827
N325 Y-.9367 Z-.045 I0. J-.1827
N330 Y-.5713 Z-.055 I0. J.1827
N335 Y-.9367 Z-.065 I0. J-.1827
N340 Y-.5713 Z-.075 I0. J.1827
N345 Y-.9367 Z-.085 I0. J-.1827
N350 Y-.5713 Z-.095 I0. J.1827
N355 Y-.9367 Z-.105 I0. J-.1827
N360 Y-.5713 Z-.115 I0. J.1827
N365 Y-.9367 Z-.125 I0. J-.1827
N370 Y-.5713 Z-.135 I0. J.1827
N375 Y-.9367 Z-.145 I0. J-.1827
N380 Y-.5713 Z-.155 I0. J.1827
N385 Y-.9367 Z-.165 I0. J-.1827
N390 Y-.5713 Z-.175 I0. J.1827
N395 Y-.9367 Z-.185 I0. J-.1827
N400 Y-.5713 Z-.195 I0. J.1827
N405 Y-.9367 Z-.205 I0. J-.1827
N410 Y-.5713 Z-.215 I0. J.1827
N415 Y-.9367 Z-.225 I0. J-.1827
N420 Y-.5713 Z-.235 I0. J.1827
N425 Y-.9367 Z-.245 I0. J-.1827
N430 Y-.5713 Z-.255 I0. J.1827
N435 Y-.9367 Z-.265 I0. J-.1827
N440 Y-.5713 Z-.275 I0. J.1827
N445 Y-.9367 Z-.285 I0. J-.1827
N450 Y-.5713 Z-.295 I0. J.1827
N455 Y-.9367 Z-.305 I0. J-.1827
N460 Y-.5713 Z-.315 I0. J.1827
N465 Y-.9367 Z-.325 I0. J-.1827
N470 Y-.5713 Z-.335 I0. J.1827
N475 Y-.9367 Z-.345 I0. J-.1827
N480 Y-.5713 Z-.355 I0. J.1827
N485 Y-.9367 Z-.365 I0. J-.1827
N490 Y-.5713 Z-.375 I0. J.1827
N495 Y-.9367 Z-.385 I0. J-.1827
N500 Y-.5713 Z-.395 I0. J.1827
N505 Y-.9367 Z-.405 I0. J-.1827
N510 Y-.5713 Z-.415 I0. J.1827
N515 Y-.9367 Z-.425 I0. J-.1827
N520 Y-.5713 Z-.435 I0. J.1827
N525 Y-.9367 Z-.445 I0. J-.1827
N530 Y-.5713 Z-.455 I0. J.1827
N535 Y-.9367 I0. J-.1827
N540 Y-.5713 I0. J.1827
N545 G01 G40 Y-.754
N550 G00 Z1.
N555 M05
N560 G91 G28 Z0.
N565 G28 Y0. A0.
N570 G90
N575 M30
Here you go with arrows:
