Triple Square Modified 10° thread
I'm got a part o make that called out a
Triple Square Modified 10° right hand thread
Pitch = .750
Lead = 2.250
Its basically a triple lead ID thread with a major diameter of 27.188"
The form is 3/8" wide flat bottomed with 10° angled walls
What I'm not getting is the 2.25" Lead.. what does that mean?
We don't do much threading around here
I'll have a choice between a Fanuc controlled VTL or a high Okuma 5X  mill turn
Either way, Its going to be interesting
2.25 / 3 = .75
If you ask me, most people use the term pitch when they should be using lead.
The lead is 2.25... that is what you program for a single lead... that doesn't change for this thread either... you will still program that in 3 different positions... all .75 apart... that gets you the triple lead thread.
You don't necessarily have to shift your start point for a multi-start thread.
Sometimes clearances will not allow for this.
You can use "Q" to shift the start angle.
This works with canned threading & long code threading. (G32)
So for a triple start thread you would use:
G32 ............Q0.
G32 ............Q120.
G32 ............Q240.
or;
G76X_Z_I_K_D_F_A_P_Q_;
I : Difference of radiuses at threads
K : Height of thread crest (radius)
D : Depth of the first cut (radius)
A : Angle of the tool tip (angle of ridges)
P : Method of cutting
Q: Shift angle of thread cutting start angle
Depending on your control, you may not be able to use decimal points for the "Q" value.
Q120. could need to be Q120000 or similar.
Tom, we do a lot of multiple start threads. But ours are for medical, ie: bone screws.
The 2.250 is usually the total lead of .750 pitch * 3 starts.
I tend to stay away from the G76 canned cycles, as you lose control compared to G32.
I'm thinking about milling these on our Okuma VTM
Get a form cutter built, kick the head to the correct angle
and run a helix tool path
The ID is 27" so there is plenty of room
This part has dozens of mill features and they are all timed to the
threads. I'm concerned about maintaining that timing if I turn the threads
If I mill them, that's not an issue as long as I orient my drive chains correctly
I have had timing to feature requirements before too.
I used to cut a custom thread on a 10' dia with a 4.0" lead. on a 5 meter VTL with double start threads.
Yes, 10 foot Dia.,(rock crusher parts).
Anyway, I would scribe the O.D. With stock still on, calculate my "Q" (angular) shift & go.
My requirements for this particular thread were to be within .001" every 90 degrees.
I'm just letting you know that you can thread this very accurately & faster than milling.
Another question is gaging the thread.
How do you even measure something like this??
We have tooling $$$ to build a gage, but how do you gage the gage
three "wire" method using Romer arm at the machine?
-or just romer arm against a good model. I would want to do a dry run on a gauge/blank before cutting a real part. Would be nice to test fit gauge on existing mating part, as a sanity check.
I see you're still doing the easy stuff. :blushing: Better you then me.
