Gear cutting
schager
Hello
I have Mastercam 2017 and a Doosan Puma 2600Y (C & Y axis) and I am trying to do a gear for a personal project.
I am new to Mastecam, only had it for a couple of months and I can't figure out how to do the tool path.
Using a gear cutter and live tooling. like i do on the old bridgeport with a dividing head.
Hope you guys can adwise me what to use.
module 0.5
38 teeth
5 mm thick
Yes it is.
How do i repeat that movement 38 times
And Is your picture turned 90 degrees ? I would like to position the cutter at "12 a clock"
Thank's for your help
Toolpath Transform will do that for you.
Edit: Here is a quick sample, https://www.dropbox.com/s/2dvirvg04x4oy10/5038-sample.mcam?dl=0
keep in mind this is only a sample and I did not check anything so I suggest if you plan on using this as a starter file to check everything at least once as I am providing this as a sample only.
