Odd feedrates in triangle mesh path
So not a Guru
I'm trying to use the triangle mesh toolpaths, but I keep getting weird problems.
This program is using the parallel cut path, but when I code it I get 368 instanse of the feedrate =0.
Can someone code this on a %-axis machine & see if this is a problem with the path or just my post?
Oops 5-axis
I ran this through our Zimmerman gantry mill post
It posted OK and there are no F0's, but  I can't figure out where the F1. is coming from
; TOOL - 100 ... 1/4" 4 FLUTE BALL 2.0 EXT
G0 G17 G40 G90 G94
TC
T100;N100A
M6
D1
TRAFO
TOL(.0075)
JERK(1.)
G54
G0 S3438 M3
G0 G90 X-.18 Y.1539 C4.358 A-50.347
Z1.2719 M8
G1 Y.1537 Z1.2718 F1.
X-.1792 Y.1382 Z1.2565 F2.
X-.1771 Y.1218 Z1.2422
X-.1737 Y.1047 Z1.2292
X-.169 Y.0869 Z1.2174
X-.1631 Y.0687 Z1.207
X-.1561 Y.0501 Z1.1981
X-.1479 Y.0313 Z1.1907
X-.1386 Y.0124 Z1.1848
X-.1284 Y-.0064 Z1.1806
X-.1172 Y-.0249 Z1.178
X-.1052 Y-.0431 Z1.1771
X-.0925 Y-.0608 Z1.1779
X-.0791 Y-.0779 Z1.1803
X-.0652 Y-.0941 Z1.1844
X-.0508 Y-.1095 Z1.1901
X-.0361 Y-.1239 Z1.1974
X-.0212 Y-.1372 Z1.2063
X-.0062 Y-.1492 Z1.2165
X-.0018 Y-.1525 Z1.2198 F16.5
X.0026 Y-.1561 Z1.2228
I tried this in MC2017 also
On the Utilities page I enabled Rapid Feedrates and set it to 399
That changed the F1 to F399..... but this did not work in X9
I think there must be a post issue causing the multiple F0's
I'm only getting 4 feedrates in the entire file
Mmm, looks like my post sucks on this path. I'm using X9
I tried the utility feedrate change, bit it made no difference in my code.
The path ignores my tool axis control point too.
how old is your post?
I've got some old v9 lathe posts that have been updated all the way to MC2017 and they work fine
but an old mill post is another story
a really old post probably doesn't have the necessary parameters to support the advanced 5X stull
at some point you have to bite the bullet and get a modern post
edit
the post I tried this on in X9 and MX2017 is the same post, just updated for the newer version
and changing Fast Feedrate  setting had no effect in X9.. so it's not all post issues here
There are differences between X9 and MC2017
edit
My post is just over a year old. Just outside of support :pc:
